  3. Otabootloader upload ?
14 Posts 4 Posters 6.2k Views 2 Watching
  • ch3b7C
    ch3b7C
    ch3b7
    I can upload the bootloader using Arduino as ISP ? who i need add in a board.txt?
    im use this but give an error
    Mysensors.name=[Mysensors OTA] Arduino Uno
    Mysensors.upload.protocol=arduino
    Mysensors.upload.maximum_size=32256
    Mysensors.upload.speed=115200
    Mysensors.bootloader.low_fuses=0xff
    Mysensors.bootloader.high_fuses=0xde
    Mysensors.bootloader.extended_fuses=0x05
    Mysensors.bootloader.path=MySensorsOTA
    Mysensors.bootloader.file=MyOtaBootloader.hex
    Mysensors.bootloader.unlock_bits=0x3F
    Mysensors.bootloader.lock_bits=0x0F
    Mysensors.build.mcu=atmega328p
    Mysensors.build.f_cpu=16000000L
    Mysensors.build.core=arduino
    Mysensors.build.variant=standard
    tekkaT 1 Reply Last reply
    • daulagariD
      daulagariD
      daulagari
      What kind of error do you get?
      ch3b7C 1 Reply Last reply
      • ch3b7C ch3b7
        tekkaT
        tekkaT
        tekka
        @ch3b7 this setting is working for me (4k BL)
        proMS.name=Arduino Pro Mini (3V3 & 5V, 16 MHz) w/ ATmega328 MySensors
        proMS.upload.tool=avrdude
        proMS.upload.protocol=arduino
        proMS.upload.maximum_size=28672
        proMS.upload.maximum_data_size=2048
        proMS.upload.speed=115200
        proMS.bootloader.tool=avrdude
        proMS.bootloader.unlock_bits=0x3F
        proMS.bootloader.lock_bits=0x0F
        proMS.bootloader.low_fuses=0xFF
        proMS.bootloader.high_fuses=0xD8
        proMS.bootloader.extended_fuses=0x05
        proMS.bootloader.file=MySensors/MyOtaBootloader.hex
        proMS.build.board=AVR_PRO
        proMS.build.core=arduino
        proMS.build.variant=standard
        proMS.build.mcu=atmega328p
        proMS.build.f_cpu=16000000L
        • tekkaT tekka
          ch3b7C
          ch3b7C
          ch3b7
          @tekka dont work for me
          • daulagariD daulagari
            ch3b7C
            ch3b7C
            ch3b7
            this error:
            avrdude: WARNING: no end of file record found for Intel Hex file "G:\arduino-1.0.5-r2\hardware\arduino\bootloaders\MySensorsOTA\MyOtaBootloader.hex"
            • ch3b7C ch3b7
              this error:
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              @ch3b7 did you download/copy the entire .hex file? seems like you are missing some parts (eof)
              • ch3b7C
                ch3b7C
                ch3b7
                im downloaded from here link text im try to copy manually
                • ch3b7C ch3b7
                  tekkaT
                  tekkaT
                  tekka
                  @ch3b7 download and save from here.
                  • tekkaT tekka
                    ch3b7C
                    ch3b7C
                    ch3b7
                    thanks. now i not get the error but i cant upload sketch
                    • ch3b7C ch3b7
                      tekkaT
                      tekkaT
                      tekka
                      @ch3b7 you have to give us more information to troubleshoot. which error msg do you get?
                      • ch3b7C
                        ch3b7C
                        ch3b7
                        now it works ^^ thanks!
                        • ch3b7C ch3b7
                          tekkaT
                          tekkaT
                          tekka
                          @ch3b7 excellent :) have fun
                          D 1 Reply Last reply
                          • tekkaT tekka
                            Dheeraj
                            @tekka
                            Is OTA or MYS bootloader end to end working for you. if yes, let me know the steps that needs to be followed. i'm getting error in gateway where I_FIND_PARENT request(from sensor) response is failing and not reaching to sensor node. however, it works after fresh make load command issue..
                            • D Dheeraj
                              @tekka
                              tekkaT
                              tekkaT
                              tekka
                              @Dheeraj Did you install the most recent version of the library? There were some significant changes in the routing and find_parent parts of the code...
