  3. Node unable to find parent
7 Posts 3 Posters 1.6k Views 3 Watching
  • E Offline
    E Offline
    ElCheekytico
    wrote on last edited by ElCheekytico
    I am trying to setup my first EasyPCB node and I am unable to get them online. Both Gateway and Node logs look OK to me other than the obvious failures. Gateway is configured in OpenHAB.
    Node battery sketch
    #define MY_DEBUG_VERBOSE_RFM69
    #define MY_RADIO_RFM69
    // Define this to enable the improved RFM69 driver
    #define MY_RFM69_NEW_DRIVER
    // The frequency to use.
    #define MY_RFM69_FREQUENCY RFM69_915MHZ
    // Define this if you are using the RFM69HW
    #define MY_IS_RFM69HW
    uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
      analogReference(INTERNAL1V1);
      analogReference(INTERNAL);
      sendSketchInfo("Battery Meter", "1.0");
      // get the battery Voltage
    #ifdef MY_DEBUG
      Serial.println(sensorValue);
    #ifdef MY_DEBUG
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
      sleep(SLEEP_TIME);
    Node log
    18:55:26.204 ->
    18:55:26.204 ->  __  __       ____
    18:55:26.204 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
    18:55:26.204 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
    18:55:26.204 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
    18:55:26.204 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
    18:55:26.204 ->         |___/                      2.3.1
    18:55:26.204 ->
    18:55:26.204 -> 16 MCO:BGN:INIT NODE,CP=RPNNA---,REL=255,VER=2.3.1
    18:55:26.204 -> 28 TSM:INIT
    18:55:26.204 -> 28 TSF:WUR:MS=0
    18:55:26.204 -> 30 RFM69:INIT
    18:55:26.204 -> 32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    18:55:26.204 -> 36 RFM69:PTX:LEVEL=5 dBm
    18:55:26.204 -> 38 TSM:INIT:TSP OK
    18:55:26.204 -> 40 TSM:FPAR
    18:55:26.204 -> 43 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
    18:55:26.204 -> 47 RFM69:CSMA:RSSI=-35
    18:55:26.378 -> 546 RFM69:CSMA:RSSI=-35
    18:55:26.378 -> 552 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    18:55:28.366 -> 2562 !TSM:FPAR:NO REPLY
    18:55:28.810 -> 2564 TSM:FPAR
    18:55:28.810 -> 2566 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
    18:55:28.810 -> 2570 RFM69:CSMA:RSSI=-36
    18:55:28.912 -> 3069 RFM69:CSMA:RSSI=-35
    18:55:28.912 -> 3076 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    18:55:30.906 -> 5085 !TSM:FPAR:NO REPLY
    18:55:30.906 -> 5087 TSM:FPAR
    18:55:31.317 -> 5089 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
    18:55:31.317 -> 5093 RFM69:CSMA:RSSI=-35
    18:55:31.317 -> 5097 RFM69:CSMA:RSSI=-35
    18:55:31.455 -> 5591 RFM69:CSMA:RSSI=-35
    18:55:31.455 -> 5597 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    18:55:33.439 -> 7606 !TSM:FPAR:NO REPLY
    18:55:33.439 -> 7608 TSM:FPAR
    18:55:33.439 -> 7610 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
    18:55:33.852 -> 7614 RFM69:CSMA:RSSI=-35
    18:55:33.988 -> 8112 RFM69:CSMA:RSSI=-35
    18:55:33.988 -> 8118 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    18:55:35.990 -> 10127 !TSM:FPAR:FAIL
    18:55:35.990 -> 10129 TSM:FAIL:CNT=1
    18:55:35.990 -> 10131 TSM:FAIL:DIS
    18:55:35.990 -> 10133 TSF:TDI:TSL
    18:55:35.990 -> 10135 RFM69:RSL
    18:55:46.444 -> 20140 TSM:FAIL:RE-INIT
    18:55:46.444 -> 20142 TSM:INIT
    18:55:46.444 -> 20144 RFM69:INIT
    18:55:46.444 -> 20146 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    18:55:46.444 -> 20150 RFM69:PTX:LEVEL=5 dBm
    18:55:46.444 -> 20152 TSM:INIT:TSP OK
    18:55:46.444 -> 20156 TSM:FPAR
    18:55:46.444 -> 20158 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
    Ethernet gateway sketch
    // RFM69 SPI chip select pin
    #define MY_RFM69_CS_PIN 6
    // Define this to override the default RFM69 IRQ pin assignment
    #define MY_RFM69_IRQ_PIN 2
    // RFM69 IRQ number
    #define MY_RFM69_IRQ_NUM 1
    #define MY_GATEWAY_W5100
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,60,200
    #define MY_IP_GATEWAY_ADDRESS 192,168,60,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 60, 2
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Gateway log
    1565 MCO:BGN:STP
    1565 MCO:BGN:INIT OK,TSP=1
    1566 TSM:READY:NWD REQ
    1566 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
    1568 RFM69:CSMA:RSSI=-102
    3569 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    359508 GWT:TSA:ETH OK
    359512 GWT:RFC:MSG=0;0;3;0;2;
    359514 GWT:RFC:MSG=
    539523 GWT:RFC:MSG=0;0;3;0;2;
    539525 GWT:RFC:MSG=
    542523 GWT:RFC:MSG=0;255;3;0;18;
    542525 GWT:RFC:MSG=
    542724 GWT:RFC:MSG=1;255;3;0;18;
    542724 !TSF:RTE:1 UNKNOWN
    542725 RFM69:SWR:SEND,TO=1,SEQ=1,RETRY=0
    542726 RFM69:CSMA:RSSI=-103
    544927 !RFM69:SWR:NACK
    544927 RFM69:SWR:SEND,TO=1,SEQ=2,RETRY=1
    544929 RFM69:CSMA:RSSI=-107
    547129 !RFM69:SWR:NACK
    547129 RFM69:SWR:SEND,TO=1,SEQ=2,RETRY=2
    547131 RFM69:CSMA:RSSI=-102
    549331 !RFM69:SWR:NACK
    549331 RFM69:SWR:SEND,TO=1,SEQ=2,RETRY=3
    549334 RFM69:CSMA:RSSI=-100
    551534 !RFM69:SWR:NACK
    551534 RFM69:SWR:SEND,TO=1,SEQ=2,RETRY=4
    551536 RFM69:CSMA:RSSI=-99
    553736 !RFM69:SWR:NACK
    553736 RFM69:SWR:SEND,TO=1,SEQ=2,RETRY=5
    553738 RFM69:CSMA:RSSI=-102
    555938 !RFM69:SWR:NACK
    555938 !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=18,pt=0,l=0,sg=0,ft=0,st=NACK:
    555939 GWT:RFC:MSG=
    @sundberg84 Any thought? I'm using rev10.
    S 1 Reply Last reply
    • E ElCheekytico
      Node battery sketch
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
        sleep(SLEEP_TIME);
      Node log
      18:55:26.204 ->
      18:55:26.204 ->
      // RFM69 IRQ number
      Gateway log
      1565 MCO:BGN:STP
      359514 GWT:RFC:MSG=
      539525 GWT:RFC:MSG=
      542525 GWT:RFC:MSG=
      555939 GWT:RFC:MSG=
      @elcheekytico - hmm, I can not seems to parse your node log - but anyways, it seems like no reply is the major error code here so it seems like its an issue with the radio communication.
      How is your hardware setup. How do you power the node and gateway?
      How did you build the gateway? Is this one starting up correctly?
      I see you define alot of things in the gatewat sketch... seems a bit strange, but maybe thats right. Im not defining that much: https://github.com/sundberg84/HomeAutomation/blob/master/Sketches MySensors RFM69 radio/RFM69gw/Rfm69gw/Rfm69gw.ino
      I dont think EasyPCB RFM Edition is wired to D6 - do you use this for the gateway or only the node?
      E 1 Reply Last reply
      • B Offline
        B Offline
        bgunnarb
        @ElCheekytico
        I cannot find that you set your NODE_ID in the beginning of the sensor sketch.
        Since OpenHAB does not hand out node-id as far as I know (I do not use the MySensors binding in OpenHAB since I connect over mqtt) you have to set NODE_ID manually.
        Note: The GW does not assign node id either.
        In your sensor sketch, start by adding
        #define MY_NODE_ID   5
        for example and see if you are able to connect.
        I have never been so busy since I retired!
        • S sundberg84
          E Offline
          E Offline
          ElCheekytico
          @sundberg84 said in Node unable to find parent:
          @sundberg84 The node, Pro Mini 3.3v, is powered by battery, but i guess still by USB while debugging. The gateway has been powered by USB while debugging and a known good power supply. The gateway is Leonardo with Ethernet shield. The gateway is the only one with RFM pin defines
          @bgunnarb said in Node unable to find parent:
          @ElCheekytico
          @bgunnarb I had a test setup with ESP8266 as gateway and node before and didn't remember specifying a node ID as I though OpenHAB would handle it. I found some documentation that said otherwise. That being said, I adding a node id, but still no luck.
          • E Offline
            E Offline
            ElCheekytico
            Ok, Really dumb, I had MY_RFM69_IRQ_PIN connected to the radio's RESET instead of DI00. I was grasping at straws and went to re-do my antenna because they were about 3mm too short when I noticed the mis-wiring. Once I fixed that swapped 3.3v and Ground and troubleshot that for a minute before I realized it. Before trying to fix the antenna I thought maybe since I didn't have a sensor defined the battery level data wasn't enough.The node is now talking to the controller with the MockMySensors sketch.
            Thanks for your help guys.
            • B bgunnarb
              @ElCheekytico
              E Offline
              E Offline
              ElCheekytico
              @ElCheekytico
              @bgunnarb I found that OpenHAB does assign node ID's even though the controller feature table somewhere on this site says it does not.
              • E ElCheekytico
                E Offline
                E Offline
                ElCheekytico
                @elcheekytico said in Node unable to find parent:
                I cleared eeprom and went back to my battery sketch and all is well.
