  3. Sensebender Micro Sketch and library files
4 Posts 3 Posters 1.3k Views 4 Watching
  • E
    E
    egrootoonk
    a year ago I bought 8 Sensebender Micro boards. I want to deploy them different, but run into different problems within the Arduino IDE environment.
    I upgraded to version 1.8.8 and use Mysensors 2.3.1 library.
    Where can I find a sketch that does Temp/Hum and door and exact what mysensors libraries do I need and where can I find them.
    When I compile the default sketch, I run into multiple problems with
    sha204_lib_return_codes
    SI7021
    RunningAverage
    • E egrootoonk
      SI7021
      RunningAverage
      @egrootoonk do you mean https://www.mysensors.org/build/humidity and https://www.mysensors.org/build/humidity_si7021 ?
      In that case, you need to install the external libraries, as described under the "Example" section on the build pages.
      If you have already installed the external libraries, posting the error messages you're getting would help tremendously.
      • E
        E
        egrootoonk
        wrote on last edited by egrootoonk
        I have IDE 1.8.8
        Mysensors lib 2.3.1
        and sketch from http://mysensors.org/hardware/micro
        I have two working SB micro with 5 nodes Temp, Hum, Bat, Door and motion. Based on mysensors lib 2.0.1 beta. It's working like a charm, but I dont have the original sketch.
        For my other SB Micro, I would like to create identical ones as described above.
        Is there a way to copy the sketch from the "working" sensor and turn it into a sketch again?
        If not, I have to make it work firs, add door and motion to it.
         * Version 1.0 - Thomas Bowman MC8rch
         * Default sensor sketch for Sensebender Micro module
         * Act as a temperature / humidity sensor by default.
         * If A0 is held low while powering on, it will enter testmode, which verifies all on-board peripherals
         * Battery voltage is as battery percentage (Internal message), and optionally as a sensor value (See defines below)
         * Version 1.3 - Thomas Bowman MC8rch
         * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
         * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
         * Version 1.4 - Thomas Bowman MC8rch
         * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
         * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
         * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
        //#define MY_DEBUG
        // Define a static node address, remove if you want auto address assignment
        //#define MY_NODE_ID 3
        // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
        #define MY_OTA_FIRMWARE_FEATURE
        #include <Wire.h>
        #include <SI7021.h>
        #ifndef MY_OTA_FIRMWARE_FEATURE
        #include "drivers/SPIFlash/SPIFlash.cpp"
        #include <EEPROM.h>
        #include <sha204_lib_return_codes.h>
        #include <sha204_library.h>
        #include <RunningAverage.h>
        //#include <avr/power.h>
        // Uncomment the line below, to transmit battery voltage as a normal sensor value
        //#define BATT_SENSOR    199
        #define RELEASE "1.4"
        #define AVERAGES 2
        // Child sensor ID's
        #define CHILD_ID_TEMP  1
        #define CHILD_ID_HUM   2
        // How many milli seconds between each measurement
        #define MEASURE_INTERVAL 60000
        // How many milli seconds should we wait for OTA?
        #define OTA_WAIT_PERIOD 300
        // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
        #define FORCE_TRANSMIT_INTERVAL 30
        // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
        // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
        // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
        // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
        #define HUMI_TRANSMIT_THRESHOLD 0.5
        #define TEMP_TRANSMIT_THRESHOLD 0.5
        // Pin definitions
        #define TEST_PIN       A0
        #define LED_PIN        A2
        #define ATSHA204_PIN   17 // A3
        const int sha204Pin = ATSHA204_PIN;
        atsha204Class sha204(sha204Pin);
        SI7021 humiditySensor;
        SPIFlash flash(8, 0x1F65);
        // Sensor messages
        #ifdef BATT_SENSOR
        MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
        // Global settings
        int measureCount = 0;
        int sendBattery = 0;
        boolean isMetric = true;
        boolean highfreq = true;
        boolean transmission_occured = false;
        // Storage of old measurements
        float lastTemperature = -100;
        int lastHumidity = -100;
        long lastBattery = -100;
        RunningAverage raHum(AVERAGES);
         * Setup code
          pinMode(LED_PIN, OUTPUT);
          digitalWrite(LED_PIN, LOW);
          Serial.begin(115200);
          Serial.print(F("Sensebender Micro FW "));
          Serial.print(RELEASE);
          Serial.flush();
          // First check if we should boot into test mode
          pinMode(TEST_PIN,INPUT);
          digitalWrite(TEST_PIN, HIGH); // Enable pullup
          if (!digitalRead(TEST_PIN)) testMode();
          // Make sure that ATSHA204 is not floating
          pinMode(ATSHA204_PIN, INPUT);
          digitalWrite(ATSHA204_PIN, HIGH);
          digitalWrite(TEST_PIN,LOW);
          digitalWrite(LED_PIN, HIGH);
          humiditySensor.begin();
          Serial.flush();
          Serial.println(F(" - Online!"));
          isMetric = getControllerConfig().isMetric;
          Serial.print(F("isMetric: ")); Serial.println(isMetric);
          raHum.clear();
          sendTempHumidityMeasurements(false);
          sendBattLevel(false);
        #ifdef MY_OTA_FIRMWARE_FEATURE
          Serial.println("OTA FW update enabled");
        void presentation()  {
          sendSketchInfo("Sensebender Micro", RELEASE);
          present(CHILD_ID_TEMP,S_TEMP);
          present(CHILD_ID_HUM,S_HUM);
        #ifdef BATT_SENSOR
          present(BATT_SENSOR, S_POWER);
         *  Main loop function
          measureCount ++;
          sendBattery ++;
          bool forceTransmit = false;
          if (measureCount >= FORCE_TRANSMIT_INTERVAL) { // force a transmission
            forceTransmit = true;
            measureCount = 0;
        /*  if (sendBattery > 60)
             sendBattLevel(forceTransmit); // Not needed to send battery info that often
             sendBattery = 0;
          if (transmission_occured) {
              wait(OTA_WAIT_PERIOD);
          sleep(MEASURE_INTERVAL);
         * Sends temperature and humidity from Si7021 sensor
         * Parameters
         * - force : Forces transmission of a value (even if it's the same as previous measurement)
        void sendTempHumidityMeasurements(bool force)
          bool tx = force;
          si7021_env data = humiditySensor.getHumidityAndTemperature();
          raHum.addValue(data.humidityPercent);
          float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
          float diffHum = abs(lastHumidity - raHum.getAverage());
          Serial.print(F("TempDiff :"));Serial.println(diffTemp);
          Serial.print(F("HumDiff  :"));Serial.println(diffHum);
          if (isnan(diffHum)) tx = true;
          if (diffTemp >= TEMP_TRANSMIT_THRESHOLD) tx = true;
          if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
          if (tx) {
            measureCount = 0;
            float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
            int humidity = data.humidityPercent;
            Serial.print("T: ");Serial.println(temperature);
            Serial.print("H: ");Serial.println(humidity);
            send(msgTemp.set(temperature,1));
            send(msgHum.set(humidity));
            lastTemperature = temperature;
            lastHumidity = humidity;
            transmission_occured = true;
            if (sendBattery > 60) {
             sendBattLevel(true); // Not needed to send battery info that often
             sendBattery = 0;
         * Sends battery information (battery percentage)
         * Parameters
        void sendBattLevel(bool force)
          if (force) lastBattery = -1;
          long vcc = readVcc();
          if (vcc != lastBattery) {
            lastBattery = vcc;
        #ifdef BATT_SENSOR
            float send_voltage = float(vcc)/1000.0f;
            send(msgBatt.set(send_voltage,3));
            // Calculate percentage
            vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
            long percent = vcc / 14.0;
            sendBatteryLevel(percent);
         * Internal battery ADC measuring
        long readVcc() {
          #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
            ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
          #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
            ADMUX = _BV(MUX5) | _BV(MUX0);
          #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
            ADcdMUX = _BV(MUX3) | _BV(MUX2);
          #else
          long result = (high<<8) | low;
         * Verify all peripherals, and signal via the LED if any problems.
        void testMode()
          uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
          uint8_t ret_code;
          byte tests = 0;
          digitalWrite(LED_PIN, HIGH); // Turn on LED.
          Serial.println(F(" - TestMode"));
          Serial.println(F("Testing peripherals!"));
          Serial.flush();
          Serial.print(F("-> SI7021 : "));
          Serial.flush();
          if (humiditySensor.begin())
            Serial.println(F("ok!"));
            tests ++;
          else
            Serial.println(F("failed!"));
          Serial.flush();
          Serial.print(F("-> Flash : "));
          Serial.flush();
          if (flash.initialize())
            tests ++;
          else
          Serial.flush();
          Serial.print(F("-> SHA204 : "));
          ret_code = sha204.sha204c_wakeup(rx_buffer);
          Serial.flush();
          if (ret_code != SHA204_SUCCESS)
            Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
          Serial.flush();
          if (ret_code == SHA204_SUCCESS)
            ret_code = sha204.getSerialNumber(rx_buffer);
              Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
            else
              Serial.print(F("Ok (serial : "));
              for (int i=0; i<9; i++)
                if (rx_buffer[i] < 0x10)
                  Serial.print('0'); // Because Serial.print does not 0-pad HEX
                Serial.print(rx_buffer[i], HEX);
              Serial.println(")");
              tests ++;
          Serial.flush();
          Serial.println(F("Test finished"));
          if (tests == 3)
            Serial.println(F("Selftest ok!"));
            while (1) // Blink OK pattern!
              delay(200);
              delay(200);
          else
            Serial.println(F("----> Selftest failed!"));
            while (1) // Blink FAILED pattern! Rappidly blinking..
        This is the error:
        C:\Users\edwin\Documents\Arduino\Sensebender_Micro_voor_mysensor-lib_2.0\Sensebender_Micro_voor_mysensor-lib_2.0.ino: In function 'void sendTempHumidityMeasurements(bool)':
        Sensebender_Micro_voor_mysensor-lib_2.0:239:23: error: 'si7021_env {aka struct si7021_env}' has no member named 'humidityPercent'
        Sensebender_Micro_voor_mysensor-lib_2.0:255:25: error: 'si7021_env {aka struct si7021_env}' has no member named 'humidityPercent'
        exit status 1
        • rushR
          rushR
          rush
          I've ported SensebenderMicro.ino to MySensors 2.3.1 and PlatformIO. You may check it here: https://gist.github.com/radek-senfeld/ac829f6ef117bd04638659709b51e9e9
          It's deployed on one of my SBMs for just a couple of minutes so.. here be dragons! :-)
