  3. BBQ Probes for the Perfect Steak
6 Posts 3 Posters 1.9k Views 3 Watching
  • N
    N
    Newzwaver
    Hi All,
    I am developing a BBQ Sensor that will set a timer for each probe and tell me when to turn it over depending on what I am cooking (i.e 135F = rare, 2 minutes side one and 2 minutes side 2). Any idea if anyone has developed something like this already? I found the smoker files but I am BBQ fellow not a smoker.....
    • alowhumA
      alowhumA
      alowhum
      I have something like this for a smoker. A smoker arduino sketch could be easily modified to do what you want?
      N 1 Reply Last reply
      • bjacobseB
        bjacobseB
        bjacobse
        Yes anyone have developed something like this, Price US$30 so it's not worth doing it yourself, unless that you really want to do it yourself
        https://www.oregonscientificstore.com/p-12-oregon-scientific-aw131-grill-right-wireless-talking-bbqoven-thermometer.aspx
        • alowhumA alowhum
          N
          N
          Newzwaver
          @alowhum all help greatly appreciated
          • N
            N
            Newzwaver
            Hit post to quick sorry, my plan is to have 4 probes each on a timer. Press the button and put on the steak have Alexa tell you to flip after 2 minutes for rare and the another 2 minutes and she will tell you done with a temp of 125f.....
            • alowhumA
              alowhumA
              alowhum
              What you should look at is the Adafruit_MAX31855 library Then buy a K-type sensor device online.
              https://github.com/adafruit/Adafruit-MAX31855-library
              You can also use the cheaper Max6675. Watch the voltage it uses.
              You'll have so search a bit, but you can also buy meat-probe style K-type sensors at Aliexpress.
              This code may be of use:
               * PID smoker, in progress
              #include <AutoPID.h>
              //#include <PID_v1.h>
              //#define PIN_INPUT 0
              //#define RELAY_PIN 6
              //auto-pid settings and gains
              #define OUTPUT_MIN 0
              #define OUTPUT_MAX 3500 // this should not exceed the ASECOND value below.
              #define KP 6
              #define KI .1
              #define KD 10
              //Define Variables we'll be connecting to
              double setPoint, Output; // autopid
              double smokerSetpoint = 90;
              double meatSetpoint = 70;
              double temperatureA = 0;                          // Holds the temperature of the first MAX sensor.
              double temperatureB = 0;                          // Holds the temperature of the second MAX sensor.
              double temperatureC = 0;                          // Holds the temperature of the second MAX sensor.
              //Define the aggressive and conservative PID Tuning Parameters
              //double Kp=2, Ki=5, Kd=1; // the original middle of the road settings.
              //double aggKp=4, aggKi=0.2, aggKd=1; // the original aggressive settings.
              //double aggKp=2, aggKi=2, aggKd=1;
              //double consKp=1, consKi=0.05, consKd=0.25;
               * P:  the bigger the number the harder the controller pushes.
               * I:  the SMALLER the number (except for 0, which turns it off,)  the more quickly the controller reacts to load changes, but the greater the risk of oscillations.
               * D: the bigger the number  the more the controller dampens oscillations (to the point where performance can be hindered)
               * learn more: http://brettbeauregard.com/blog/2011/04/improving-the-beginners-pid-introduction/
               * 1. Get the Proportional working first. A fast and easy trick is to increase the proportional gain until oscillations start (the critical or ultimate gain) then cut the gain in half.
              //PID myPID(&temperatureA, &Output, &smokerSetpoint, aggKp, aggKi, aggKd, DIRECT);
              AutoPID myPID(&temperatureB, &smokerSetpoint, &Output, OUTPUT_MIN, OUTPUT_MAX, KP, KI, KD);
              #define ACTIVATIONTEMPERATURERANGE 10             // at what temperature delta below or above the target temperature should the PID take over the heating proces? So if the target is 100, then this would be between 70 and 130 degrees.
              #define HASOLEDSCREEN                             // Remove this line if you are not using an OLED screen on the node.
              #define DONTCHECKCONNECTION                       // Uncomment this line if you do not care if the node loses connection with the controller.
              #ifdef HASOLEDSCREEN
                #define OLED_I2C_ADDRESS 0x3C
                //#include <SPI.h>
                #include <SSD1306Ascii.h>                         // simple drivers for the screen.
                #include <SSD1306AsciiAvrI2c.h>
                SSD1306AsciiAvrI2c oled;
              // if you uncomment this, you can get test and debug updates about everything the sensor is doing by using the serial monitor tool.
              //#define MY_DEBUG
              #define MY_RADIO_NRF24                           // A 2.4Ghz transmitter and receiver, often used with MySensors.
              //#define MY_RADIO_RFM69                         // 433Mhz transmitter and reveiver.
              //#define MY_RADIO_NRF5_ESB                      // NRF5 devices
              //#define MY_RADIO_RFM95
              //#define MY_RF24_PA_LEVEL RF24_PA_MIN
              #define MY_RF24_PA_LEVEL RF24_PA_LOW              // This sets a low-power mode for the radio. Useful if you use the version with the bigger antenna, but don't want to power that from a separate power source. It can also fix problems with fake Chinese versions of the radio.
              //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
              //#define MY_RF24_PA_LEVEL RF24_PA_MAX
              // Advanced settings
              #define MY_TRANSPORT_WAIT_READY_MS 8000            // try connecting for a few seconds. Otherwise just continue.
              #define MY_SPLASH_SCREEN_DISABLED                   // saves a little memory.
              //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE      // saves a little memory.
              //#define MY_NODE_ID 100
              //#define MY_PARENT_NODE_ID 0
              //#define MY_PARENT_NODE_IS_STATIC
              //#define MY_RF24_CHANNEL 100                       // this helps to get a better reception in Europe. The default channel that MySensors uses (76) overlaps with European wifi band 13 :-(
              // Easy to use security, yay!
              //#define MY_SIGNING_SIMPLE_PASSWD   "putyourpasswordhere"
              //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A7         // setting a pin to pickup noise makes encryption more secure.
              // Choose if you want this sensor to also be a repeater.
              //#define MY_REPEATER_FEATURE                       // Just remove the two slashes at the beginning of this line to also enable this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this.
              // LIBRARIES (in the Arduino IDE go to Sketch -> Include Library -> Manage Libraries to add these if you don't have them installed yet.)
              #include "Adafruit_MAX31855.h"
              // VARIABLES YOU CAN CHANGE
              #define RELAY_ON 0                                // GPIO value to write to turn on attached relay. Some relays are reversed.
              #define RELAY_OFF 1                               // GPIO value to write to turn off attached relay Some relays are reversed.
              #define HEATER_RELAY_PIN 14                       // Arduino Digital I/O pin number for heater relay. 14 = A0, 19 = A5 (A6 and A7 are input only)
              #define MAXDOA   3                                // Pins for the two K-type sensors.
              #define MAXCSA   4                                // Pins for the two K-type sensors.
              #define MAXCLKA  5                                // Pins for the two K-type sensors.
              #define MAXDOB   6                                // Pins for the two K-type sensors.
              #define MAXCSB   7                                // Pins for the two K-type sensors.
              #define MAXCLKB  8                                // Pins for the two K-type sensors.
              #define ASECOND 4000                              // How long does a second take? (default is 1000 milliseconds)
              #define SAFEGUARD_TEMP 160                        // Maximum temperature (currently in celcius) that may be detected before the relay is shutdown.
              #define RETURNTONORMAL_TEMP 100                   // After a safeguard shutdown, at what cooled down temperature (currently in celcius) should the system go back to normal state?
              #define MAXIMUMCONNECTIONLOSSCOUNT 6              // How many safetycheck will we allow the connected to be down? (6 = 60 seconds)
              #define MAXIMUMTEMPERATURESENSORERRORS 100          // How many faulty measurements to accept per 10 second period. A faulty sensor will give one error per second.
              #define SECURITYCHECKINTERVAL 15                  // How many seconds before a new security check is performed
              //VARIABLES YOU PROBABLY SHOULDN'T CHANGE
              #define TEXT_CHILD_ID 1                            // for MySensors. Within a node each sensor/actuator should have its own ID number.
              #define THERMOSTAT_CHILD_ID 2
              #define TEMP_A_CHILD_ID 3
              #define TEMP_B_CHILD_ID 4
              #define TEMP_C_CHILD_ID 5                           // Internal temperature sensor
              #define POWER_CHILD_ID 6                            // The PID's current power output level, as a percentage.
              #define MEATTARGET_CHILD_ID 7
              byte powerPercentage = 0;                           // The PID's current power output level (relative to the output_max), recalculated as a percentage.
              boolean meatTemperatureReached = false;             // Changes to true when the meat has reached the desired temperature.
              //boolean runEverySecondThings = true;                // this moves the things that are done every second to beyond the part of the second where the device is heating.
              // initialize the Thermocouple
              Adafruit_MAX31855 thermocouple(MAXCLKA, MAXCSA, MAXDOA); // This is the enclosure thermometer. This temperature is used to safety checks.
              Adafruit_MAX31855 thermocoupleb(MAXCLKB, MAXCSB, MAXDOB); // This is the mean temperature.
              // Security variables
              boolean runSafetyCheck = true;
              boolean safetyShutdown = true;                          // Set to true if something is wrong with the system. This then turns off the relay.
              boolean targetTooHot = false;                           // A safety feature. If the device somehow gets really hot, disable the heater.
              byte connectionLossCounter = 0;                         // How often did a request to the controller not result in any response?
              byte tempSensorErrorCount = 0;                          // How often did the temperature sensor give an error?
              // Mysensors settings
              MyMessage statusMsg(TEXT_CHILD_ID,V_TEXT);              // Sets up the message format that we'll be sending to the MySensors gateway later. The first part is the ID of the specific sensor module on this node. The second part tells the gateway what kind of data to expect.
              MyMessage thermostatMsg(THERMOSTAT_CHILD_ID, V_HVAC_SETPOINT_HEAT);
              MyMessage temperatureMsg(TEMP_A_CHILD_ID, V_TEMP);
              MyMessage powerMsg(POWER_CHILD_ID, V_PERCENTAGE);       // the current powerlevel of the heater, as a percentage.
              void before()
                pinMode(HEATER_RELAY_PIN, OUTPUT);
                digitalWrite(HEATER_RELAY_PIN, RELAY_OFF);
                Serial.begin(115200); // for serial debugging.
                delay(500);
                Serial.println(F("starting smoker"));
                // autopid extra options
                myPID.setTimeStep(ASECOND);
                myPID.setBangBang(ACTIVATIONTEMPERATURERANGE);      // if temperature is more than X degrees below or above setpoint, OUTPUT will be set to min or max respectively.
                // myPID.setTimeStep(WindowSize);                      // set autoPID update interval. Currently once every loop.
                // myPID.setOutputRange(0,maxOutputTime);              // what range should the output be between? Maximum size can be the entire loop time. (perhaps this could make the cripledelay superfluous? Just set this to 60% of the window size?)
                // myPID.SetOutputLimits(0, WindowSize);               // tell the PID to range between 0 and the full window size
                oled.begin(&Adafruit128x64, OLED_I2C_ADDRESS);
                oled.setFont(Adafruit5x7);
                //oled.set2X(); // big letters
                oled.ssd1306WriteCmd(SSD1306_DISPLAYON);
                //oled.setScroll(true);
                oled.setCursor(0,0);
                oled.print(F("Smoker 1.6"));
                delay(1000);
                if(isTransportReady()){
                  Serial.println(F("Connected to gateway!"));
                  oled.setCursor(90,0);
                  oled.print(F("W"));
                  send(statusMsg.setSensor(TEXT_CHILD_ID).set( F("Smoker starting") ));
                  //send(thermostatMsg.setSensor(THERMOSTAT_CHILD_ID).set(smokerSetpoint,2));        // should that 2 be a one? Only one decimal? Hmm
                  send(powerMsg.set(powerPercentage));
                  //send(thermostatMsg.setSensor(MEATTARGET_CHILD_ID).set(meatSetpoint,2));
                  request(THERMOSTAT_CHILD_ID,V_HVAC_SETPOINT_HEAT);
                  request(MEATTARGET_CHILD_ID,V_HVAC_SETPOINT_HEAT);
                }else{
                  Serial.println(F("! NO CONNECTION"));
                sendSketchInfo("PID Smoker", "1.6");
                present(TEXT_CHILD_ID, S_INFO,"status");
                present(THERMOSTAT_CHILD_ID, S_HEATER, "SmokerSetpoint");
                present(TEMP_A_CHILD_ID, S_TEMP, "Temperature A");
                present(TEMP_B_CHILD_ID, S_TEMP, "Temperature B");
                present(TEMP_C_CHILD_ID, S_TEMP, "Temperature internal");
                present(POWER_CHILD_ID, S_DIMMER, "Powerlevel");
                present(MEATTARGET_CHILD_ID, S_HEATER, "Meat target temperature");
                // the clock
                static unsigned long lastClockTick = 0;                   // When was the last second of the clock.
                static byte secondCounter = 0;                            // How many seconds have passed
                // A.
                // CONTINUOUSLY
                // call the PID function, check if the heating element should be on or off.
                if (safetyShutdown == true) {
                  myPID.stop();
                } else {
                  myPID.run(); //autopid, call every loop, updates automatically at certain time interval
                  //if (ASECOND - (millis() - lastClockTick) < Output{
                  if ((millis() - lastClockTick) < Output){
                    digitalWrite(HEATER_RELAY_PIN, RELAY_ON);
                    Serial.print(F("|"));
                  }else{
                    Serial.print(F("_"));
                  delay(100);
                  if(temperatureB > smokerSetpoint){
                  }else{
                // B.
                // EVERY SECOND
                // check temperature, calculate new PID value, update display.
                if(millis() - lastClockTick >= ASECOND) {
                  lastClockTick = millis();
                  secondCounter++;
                  //runEverySecondThings = true;
                  Serial.println();
                  if(secondCounter > SECURITYCHECKINTERVAL){
                    secondCounter = 0;
                  Serial.print(F("#"));Serial.println(secondCounter);
                //if(runEverySecondThings == true && millis() - lastClockTick >= OUTPUT_MAX + 10){ // this moves all the calculations for getting temperature and pdating the screen to the part of the second loop after the heating is finished.
                  // output the value form the PID algorithm.
                  Serial.println();
                  Serial.print(F("output: ")); Serial.println(Output);
                  powerPercentage = map(Output, 0, OUTPUT_MAX, 0, 100);
                  Serial.print(F("power percentage: ")); Serial.println(powerPercentage);
                  // getting latest temperature data
                  double temperatureAreading = 0;//thermocouple.readCelsius();
                  double temperatureBreading = thermocoupleb.readCelsius();
                  temperatureC = thermocouple.readInternal();
                  Serial.print(F("A: "));Serial.println(temperatureA);
                  Serial.print(F("B: "));Serial.println(temperatureB);
                  Serial.print(F("Int: "));Serial.println(temperatureC);
                  // Check if the temperature values are realistic, or that they indicate a sensor problem.
                  if (isnan(temperatureAreading) || temperatureAreading == 0) {
                    tempSensorErrorCount++;
                  } else {
                    temperatureA = temperatureAreading; // avoiding NaN
                  if (isnan(temperatureBreading) || temperatureBreading == 0) {
                  } else {
                    temperatureB = temperatureBreading; // This makes sure the PID algorithms is only fed with real temperatures.
                  if (isnan(temperatureC) || temperatureC == 0) {
                // every second update the display
                  if(safetyShutdown == false){
                    //oled.set2X();
                    if(myPID.atSetPoint(ACTIVATIONTEMPERATURERANGE)){
                      oled.print(F("PID:"));
                    }else{
                      oled.print(F("PRE:"));
                    oled.print(powerPercentage); oled.print(F("%  "));
                    //}else{
                    //  if(temperatureB < smokerSetpoint){
                    //    oled.print(F("HEAT: ")); oled.print(powerPercentage); oled.print(F("% "));
                    //  }else{
                    //    oled.print(F("COOLING"));
                    // show temperature sensor values
                    oled.set2X();
                    oled.setCursor(0,2);
                    oled.print(F("Pot: ")); oled.print(temperatureB); oled.println(F("    "));
                    oled.setCursor(0,5);
                    oled.print(F("Meat:")); oled.print(temperatureA); oled.println(F("    "));
                    // show setpoint target temperatures
                    oled.set1X();
                    oled.setCursor(60,4);
                    oled.print(F("-> ")); oled.print(smokerSetpoint);
                    oled.setCursor(60,7);
                    oled.print(F("-> ")); oled.print(meatSetpoint);
                    // show wireless connection icon (if there is a connection)
                    if(connectionLossCounter > 1){ // If the connection is bad, hide the wireless icon.
                      oled.print(F(" "));
                    //show second counter
                    oled.setCursor(100,0);
                    oled.print(secondCounter); oled.print(F(" "));
                // some debug options.
                //double pulseLength = myPID.getPulseValue();
                //Serial.print(F("pulse value: ")); Serial.println(pulseLength);
                double integraal = myPID.getIntegral();
                Serial.print(F("integraal: ")); Serial.println(integraal);
                //runEverySecondThings = false;
                } // end of the part that runs every second
                // C.
                // EVERY TEN SECONDS
                // safety check, communicate with server, is the meat hot?
                if(runSafetyCheck == true){ // the second part moves this work to beyond the heating part of the cycle. This way it shouldn't influence the heating length, and this the PID calculations.
                  Serial.println(F(""));
                  Serial.println(F("STARTING SAFETY CHECK ETC"));
                  runSafetyCheck = false;
                  // A.
                  // CHECKING - Every 10 seconds we do a safety check.
                  // is the server up?
                  connectionLossCounter++;
                  if ( connectionLossCounter > 250 ) { connectionLossCounter = 251; }
                  // get latest setpoint values. (might not be required, some controllers send this when the values update.)
                  //request(THERMOSTAT_CHILD_ID,V_HVAC_SETPOINT_HEAT); // every 10 seconds, request the latest smokerSetpoint data. Also used to check if the wireless connection if still alive. In theory domoticz should now pro-actively send the new data to the node, so then this code is just useful to check the connection.
                  //request(MEATTARGET_CHILD_ID,V_HVAC_SETPOINT_HEAT);
                  // check connection
                  if(connectionLossCounter > MAXIMUMCONNECTIONLOSSCOUNT){ // connected lost for X amount of safety checks.
                    Serial.println(F("! LOST CONNECTION TO SERVER"));
                    oled.println(F("NO CONNECTION"));
                  // heater not too hot?
                  if(temperatureA > SAFEGUARD_TEMP || temperatureB > SAFEGUARD_TEMP){
                    targetTooHot = true;
                    Serial.println(F("! TOO HOT"));
                    oled.println(F("TOO HOT"));
                  // Not too many errors with the temperature sensor(s)?
                  Serial.print(F("tempSensorErrorCount:  ")); Serial.println(tempSensorErrorCount);
                  if(tempSensorErrorCount > MAXIMUMTEMPERATURESENSORERRORS){
                    Serial.println(F("TEMPERATURE SENSOR ERROR"));
                    oled.println(F("SENSOR ERROR"));
                  // B.
                  // HEALING - Some functions might return, and then the system could return to normal.
                  // It has cooled down enough
                  if(safetyShutdown == true && targetTooHot == true && temperatureB > RETURNTONORMAL_TEMP){ // For safety, the "return to normal" temperature is lower than the maximum room temperature. This avoids flip-flopping.
                    Serial.println(F("too hot, cooling down"));
                    oled.println(F("COOLING DOWN!"));
                  }else if(targetTooHot == true && temperatureB <= RETURNTONORMAL_TEMP){
                  // C.
                  // DECIDE IF OPERATION IS SAFE
              #ifdef DONTCHECKCONNECTION
                  connectionLossCounter = 0; // pretend there is no connection error, even if there is.
                  if(tempSensorErrorCount > MAXIMUMTEMPERATURESENSORERRORS || connectionLossCounter > MAXIMUMCONNECTIONLOSSCOUNT || targetTooHot == true){
                    // Decision: something is wrong, so SHUTDOWN the relay.
                    Serial.println(F("! ERROR DETECTED"));
                    if(safetyShutdown == false){ // first time that the error is detected
                      send(statusMsg.setSensor(TEXT_CHILD_ID).set( F("ERROR") ));
                    Serial.println(F("CURRENTLY IN SAFETY SHUTDOWN MODE"));
                    oled.println(F("SAFETY SHUTDOWN!"));
                  }else{
                    // Decision: everything looks OK.
                    Serial.println(F("EVERYTHING LOOKS OK"));
                    if(safetyShutdown == true){
                      send(statusMsg.setSensor(TEXT_CHILD_ID).set( F("SMOKER OK") ));
                      Serial.println(F("heater is ok again"));
                      oled.setScroll(false);              // the scrollmode causes flickering of the screen. For normal operation, the display function only redraws parts of the screen.
                    safetyShutdown = false;
                  tempSensorErrorCount = 0;               // reset for next round of counting.
                // send the temperature data to the controller
                if(!isnan(temperatureB)){
                  Serial.println(F("sending temp B to controller"));
                  send(temperatureMsg.setSensor(TEMP_B_CHILD_ID).set(temperatureB, 1));
                if(!isnan(temperatureA)){
                  Serial.println(F("sending temp A to controller"));
                  send(temperatureMsg.setSensor(TEMP_A_CHILD_ID).set(temperatureA, 1));
                if(!isnan(temperatureC)){
                  Serial.println(F("sending temp C to controller"));
                  send(temperatureMsg.setSensor(TEMP_C_CHILD_ID).set(temperatureC, 1));
                } // end of the part that runs every 10 seconds
              } // end of main loop
              void receive(const MyMessage &message){
                Serial.println(F("+++receiving message+++"));
                connectionLossCounter = 0; // reset the counter, indicating we have recently connected to the controller.
                oled.set1X();
                oled.print(F("W"));
                if (message.type == V_TEXT && message.sensor == THERMOSTAT_CHILD_ID) {
                  Serial.print(F("Received text data: "));
                  Serial.println(message.data);
                  // Not doing anything with this.
                if (message.type == V_HVAC_SETPOINT_HEAT) {
                  if(message.sensor == THERMOSTAT_CHILD_ID){
                    smokerSetpoint = atof(message.data);
                    Serial.print(F("smokerSetpoint: ")); Serial.println(smokerSetpoint);
                    send(thermostatMsg.setSensor(THERMOSTAT_CHILD_ID).set(smokerSetpoint,2)); // this fixes a bug in domoticz where the display in domoticz doesn't itself update the new setpoint.
                  if(message.sensor == MEATTARGET_CHILD_ID){
                    meatSetpoint = atof(message.data);
                    Serial.print(F("meatSetpoint: ")); Serial.println(meatSetpoint);
                    send(thermostatMsg.setSensor(MEATTARGET_CHILD_ID).set(meatSetpoint,2)); // this fixes a bug in domoticz where the display in domoticz doesn't itself update the new setpoint.
