  3. bootloaders
bootloaders
4 Posts 3 Posters 1.2k Views 3 Watching
  • T
    Terence Faul
    Hi
    Can someone assist.
    is mysensors/MySensorsBootloaderRF24 the same as MYSbootloader?
    • T Terence Faul
      Hi
      Can someone assist.
      @terence-faul the readme says so at least ;-)
      • T
        Terence Faul
        Yep that's why I was asking.
        Anyone able to assist in getting this board into platformio?
        dirkcD 1 Reply Last reply
        • T Terence Faul
          dirkcD
          dirkcD
          dirkc
          @terence-faul any solution so far?
          I found this:
          create a file, e.g. mysensors_bootloader_130_8Mhz.json and save it to ~/.platformio/boards/
            "build": {
              "core": "arduino",
              "extra_flags": "-DARDUINO_ARCH_AVR -DARDUINO_AVR_PRO",
              "f_cpu": "8000000L",
              "mcu": "atmega328p",
              "variant": "standard"
            "frameworks": [
              "arduino"
            "fuses": {
              "efuse": "0xFE",
              "hfuse": "0xD2",
              "lfuse": "0xE2",
              "lock": "0x0F",
              "unlock": "0x3F"
            "name": "MySensorsBootloader 1.3.0 (Atmega328P@8M,3.3V)",
            "upload": {
              "maximum_ram_size": 2048,
              "maximum_size": 30720,
              "protocol": "arduino",
              "require_upload_port": true,
              "speed": 57600
            "url": "http://www.mysensors.org",
            "vendor": "MySensors"
          the platformio.ini should look like this:
          [env:mysensors_bootloader_130_8Mhz]
          platform = atmelavr
          framework = arduino
          board = MYSBootloader_8MHz.hex
          src_build_flags = -I/Users/dirk/Arduino/libraries/MySensors
          lib_deps =
            # Using a library name
          but I do not know where to store the MYSBootloader_8MHz.hex
          Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
