  3. Domoticz
  4. help with serial gateway on raspberry pi
4 Posts 3 Posters 1.9k Views 3 Watching
  • fernando alvarez buyllaF
    wrote on last edited by fernando alvarez buylla
    hi guys i just make a new controller with a raspberry pi and domoticz , now im trying to add the serial gateway to my domoticz , but in order to domoticz to open the port i need to open ssh connection and use
    sudo ./bin/mysgw
    for domoticz to read the port /dev/ttyUSB020 , if i dont use ./bin/mysgw the log just said
    2019-04-21 04:31:58.747 Status: MySensors: Using serial port: /dev/ttyUSB020
    2019-04-21 04:31:58.747 Error: MySensors: Error opening serial port!
    , what im missing here
    just do the standar installaton
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
    make
    sudo make install
    sudo systemctl enable mysgw.service
    sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB020
    i dont know what im missing here, thanks for the help
    K mfalkviddM 2 Replies Last reply
    • fernando alvarez buyllaF fernando alvarez buylla
      sudo ./bin/mysgw
      make
      sudo make install
      K
      K
      kimot
      @fernando-alvarez-buylla
      I think you only need define your gateway in Domoticz.
      That Is all.
        sudo ./bin/mysgw
        make
        sudo make install
        @fernando-alvarez-buylla the link (created with the ln command) will be removed at reboot. Change my-serial-pty=/dev/ttyMySensorsGateway to my-serial-pty=/dev/ttyUSB020 and re-run all the commands.
        If you don't reboot the pi after enabling the mysgw service, you will need to start the gateway as per the instructions printed when make is finished.
          thanks guys , the solution for me was to add
          to rc.local
          but i will try your idea @mfalkvidd thanks for the help
