  3. [SOLVED] V_VOLTAGE
[SOLVED] V_VOLTAGE
3 Posts 2 Posters 769 Views 1 Watching
  • skywatchS
    skywatchS
    skywatch
    When I try to send V_VOLTAGE as a 'long' it works. But, I would prefer to send a float and every time I try this it fails with a compilier warning.
    Is there a list of data types that can be sent as V_VOLTAGE?
    I am using S_MULTIMETER if that helps at all......
    • skywatchS skywatch
      zboblamontZ
      zboblamontZ
      zboblamont
      @skywatch Perhaps your sketch would have helped see what is going wrong, but here is an abstract from mine, hope this helps:
      voltread = analogRead(BatteryIn);
         float voltage = (7.272 * voltread) / 1024;
         sleep(5);
         send(msg3.set(voltage,2));
      It is declared as V_VOLTAGE and S_MULTIMETER as yours, but the float is sent to 2 decimal places, as in voltage,2
      • skywatchS
        skywatchS
        skywatch
        @zboblamont Thank you! - I didn't know if it was possible to send as a float or not.
        Now it is working as expected - :)
