  3. Domoticz
  4. Dimmer and switches
Dimmer and switches
3 Posts 2 Posters 1.4k Views 2 Watching
  • G
    G
    Greg_2502
    Hello, I've got Raspberry PI with Domoticz, and Arduino Mega 2560 as Gateway USB.
    I want to two dimmer controling on Domoticz, and two switches (on/off) controlling on Domoticz and manual switch. My sketch don't work coretly. Switches (unit 1, 2) controlling also dimmer (unit 0). Please help why this is happening?
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // #define MY_WITH_LEDS_BLINKING_INVERSE
    // Enable inclusion mode
    #include <Bounce2.h>
    #define MY_REPEATER_FEATURE
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2  5
    #define BUTTON_PIN A1
    #define BUTTON2_PIN A2
    #define SN "DimmableLED"
    #define SV "1.1"
    #define LED_PIN 9      // Arduino pin attached to MOSFET Gate pin
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    void before() {
        pinMode(pin, OUTPUT);
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
      delay(10000);
       // Setup the button.
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      pinMode(BUTTON2_PIN, INPUT_PULLUP);
      // After setting up the button, setup debouncer.
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.attach(BUTTON2_PIN);
      debouncer2.interval(5);
       // Pull the gateway's current dim level - restore light level upon node power-up
        request( 0, V_DIMMER );
        present(sensor, S_LIGHT);
        present( 0, S_DIMMER );
        sendSketchInfo(SN, SV);
    static int16_t currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
    MyMessage msg(1, V_LIGHT);
    MyMessage msg2(2, V_LIGHT);
      if (debouncer.update()) {
        // Get the update value.
        int value = debouncer.read();
        // Send in the new value.
        if(value == LOW){
             saveState(1, !loadState(1));
             digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
             send(msg.set(loadState(1)));
      if (debouncer2.update()) {
          int value2 = debouncer2.read();
        if(value2 == LOW){
             saveState(2, !loadState(2));
             digitalWrite(RELAY_2, loadState(2)?RELAY_ON:RELAY_OFF);
             send(msg2.set(loadState(2)));
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
            requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
            // Clip incoming level to valid range of 0 to 100
            Serial.print( "Changing level to " );
            Serial.print( ", from " );
            Serial.println( currentLevel );
            fadeToLevel( requestedLevel );
            send(lightMsg.set(currentLevel > 0));
            // hek comment: Is this really nessesary?
            send( dimmerMsg.set(currentLevel) );
    void fadeToLevel( int toLevel )
        int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
        while ( currentLevel != toLevel ) {
            currentLevel += delta;
            analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
            //delay( FADE_DELAY );
    • G Greg_2502
      #define RELAY_2  5
      #define SV "1.1"
      void before() {
        delay(10000);
          if(value == LOW){
          if(value2 == LOW){
      Welcome to the forum @greg_2502 !
      The debug log will probablybe the easiest way to understand what is happening. Your sketch has several nice debug prints that show what the node receives.
      • G
        G
        Greg_2502
        wrote on last edited by Greg_2502
        Thank you for your help. It was enough to add the if condition depending on the message.sensor.
