  3. Difficulties compiling Nodemcu 1.0 (ESP-12 module) as a 8266 Gateway.
6 Posts 4 Posters 691 Views 4 Watching
  • R
    R
    ramwal
    Some time ago with an older Mysensors Library (I don't remember which) I had a working Gateway based on this board. Now i want to give this gateway a new live, but I have compile problems I cannot solve. I miss the knowledge to get it solved. I tried some things, however without success!
    My environment is completely standard so:
    • Arduino ide: 1.8.12
    • Mysensors Library: 2.3.2
    • Board ESP8266: version 2.6.3
    • Sketch: ESP8286 wifi example completely standard; only ssid and password changed
    1. Compiling gave this error:
      fork/exec /Users/robertus/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3: no such file or directory
      Error compiling for board NodeMCU 1.0 (ESP-12E Module).
    Then I red somewhere to use board ESP8266 version: 2.5.2, so I loaded this version of ESP8266 board also, then:
    1. Compiling gave now this error:
      Arduino: 1.8.12 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    In file included from /Users/robertus/Documents/Arduino/libraries/MySensors/MySensors.h:441:0,
    from /Users/robertus/Documents/Arduino/GatewayESP8266-New/GatewayESP8266-New.ino:114:
    /Users/robertus/Documents/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: In function 'void esp_yield_within_cont()':
    /Users/robertus/Documents/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:102:36: error: 'run_scheduled_recurrent_functions' was not declared in this scope
    run_scheduled_recurrent_functions();
    /Users/robertus/Documents/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp: At global scope:
    /Users/robertus/Documents/Arduino/libraries/MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:140:27: error: expected initializer before 'ets_intr_lock'
    extern "C" void IRAM_ATTR ets_intr_lock()
    exit status 1
    option enabled in File -> Preferences.
    Can somebody shed some light on this and hopefully has a solution, because I am stuck.
    Questions:
    1. Can error 1 be solved? Probably not a my sensors thing!
    2. Why is the board version 2.5.2 of ESP giving these errors?
    3. Is there a combination of software versions, that work?
    I appreciate any help. Thanks
    • electrikE
      electrikE
      electrik
      For the third, could you try 2.4.2 ESP library?
      • R ramwal
        exit status 1
        Questions:
        @ramwal the release notes for MySensors 2.3.2 has the following:
        Important information:
        If you encounter compilation issues, update your board definitions:
        AVR 1.8.2
        ESP8266 2.6.2
        Maybe give 2.6.2 of esp8266 a try?
        R 1 Reply Last reply
          AVR 1.8.2
          ESP8266 2.6.2
          R
          R
          ramwal
          @mfalkvidd, @electrik
          Thank you for the hints. After have been looking further on the internet involving the compile problem and found the solution, that worked for me.link text.
          I inform you that it is Mac OSX python problem in the installed python version on my Mac, a broken link to the python executable.
          I simply installed the newest version 3.8.2 Python on my laptop Mac and the problem disappeared.
          So, everything is working now with all the latest firmwares (see above).
          mfalkviddM rvendrameR 2 Replies Last reply
          • R ramwal
            Nice work @ramwal
            Thanks for reporting back.
            • R ramwal
              rvendrameR
              rvendrameR
              rvendrame
              @ramwal Thanks for the hint, it made the trick here too!
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
