  3. mysensors node attiny841 and nrf24l01+
3 Posts 3 Posters 664 Views 3 Watching
  • D
    D
    drummin89
    I created a number of mini sensor node boards using an attiny841 and a nrf24l01+. Originally I was going to write my own program using the RF24 library but just recently decided to use mysensors. Below is my code for a simple door/window sensor.
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #define MY_RADIO_RF24
    #include <Bounce2.h>
    #define CHILD_ID 5
    #define REED_SWITCH_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
      // Setup the button
      pinMode(REED_SWITCH_PIN,INPUT);
      // Activate internal pull-up
      digitalWrite(REED_SWITCH_PIN,HIGH);
      debouncer.attach(REED_SWITCH_PIN);
      debouncer.interval(2);
    void presentation() {
      sendSketchInfo("Garage Door Sensor", "1.0");
      present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    In the arduino IDE, I am getting the following errors when I try to compile. Before I start digging into the library files, is it possible to use mysensors with the nrf24l01 on the attiny841?
    In file included from C:\Users\cdrum\Documents\Arduino\libraries\MySensors/MySensors.h:64:0,
    from C:\Users\cdrum\Desktop\MySensors Sketches\WindowDoorSwitch_attiny\WindowDoorSwitch_attiny.ino:36:
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'void clearPendingInterrupt(uint8_t)':
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:73:2: error: 'EIFR' was not declared in this scope
    EIFR = _BV(interrupt);
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:73:2: note: suggested alternative: 'GIFR'
    GIFR
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'void hwPowerDown(uint8_t)':
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:96:19: error: 'WDCE' was not declared in this scope
    WDTCSR |= (1 << WDCE) | (1 << WDIE);
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:96:19: note: suggested alternative: 'WDIE'
    WDIE
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:117:18: error: 'WDCE' was not declared in this scope
    WDTCSR |= (1 << WDCE) | (1 << WDE);
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:117:18: note: suggested alternative: 'WDIE'
    WDIE
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'bool hwUniqueID(uint8_t (*)[16])':
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:277:31: error: 'OSCCAL' was not declared in this scope
    *((uint8_t *)uniqueID + 3) = OSCCAL;
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:277:31: note: suggested alternative: 'OSCCAL0'
    OSCCAL0
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'uint16_t hwCPUVoltage()':
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:299:2: error: 'ADMUX' was not declared in this scope
    ADMUX = (_BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1));
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:299:2: note: suggested alternative: 'ADMUXA'
    ADMUXA
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'uint16_t hwCPUFrequency()':
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:336:18: error: 'WDCE' was not declared in this scope
    C:\Users\cdrum\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:336:18: note: suggested alternative: 'WDIE'
    WDIE
    exit status 1
    Error compiling for board ATtiny441/841 (No bootloader).
    Thank You!
    • D drummin89
      #define CHILD_ID 5
      int oldValue=-1;
        // Setup the button
        debouncer.update();
           oldValue = value;
      GIFR
      WDIE
      WDIE
      OSCCAL0
      ADMUXA
      WDIE
      exit status 1
      Thank You!
      Welcome to the community @drummin89
      It might be possible with enough work, for code that uses very little ram and flash. But many users are struggling to make MySensors sketches work on atmega328, which has 4x more ram and 2.5x more flash.
      There are some forum threads on the same topic, for example https://forum.mysensors.org/topic/333/attiny-supported/1?_=1607318133104 and https://forum.mysensors.org/topic/6922/running-mysensors-on-attiny85/5?_=1607317730360
      • A
        A
        alb12
        You can use this solution.
        I use this with attiny84 and attiny84A, for temperature sensor and opening sensor.
        http://domotique-diy.overblog.com/
