  3. Error when restarting Homeassistant (mysensors-error)
8 Posts 2 Posters 1.8k Views 2 Watching
  • B
    B
    Branther
    i need help again.
    when i want to restart or quickly reboot my homeassistant i get the error.
    configuration could not be started
    "error calling the service homeassistant/reload_all. 'mysensors'"
    so i can only do a complete restart.
    has something changed in homeassistant in version Core 6.1 regarding MySensors?
    best regards
    • E
      E
      eiten
      Hi @Branther
      Could you please post the error log for this error? You'll find it under "Einstellungen" -> "System" -> "Protokolle"
      • B
        B
        Branther
        Hi, thank you for your feedback.
        here are the 2 protocols that concern mysensors:
        First:
        Logger: homeassistant.components.websocket_api.http.connection
        Source: helpers/check_config.py:184
        Integration: Home Assistant WebSocket API (documentation, issues)
        First occurred: 11:20:17 (1 occurrences)
        Last logged: 11:20:17
        [547863234576] 'mysensors'
        Traceback (most recent call last):
        File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 205, in handle_call_service
        await hass.services.async_call(
        File "/usr/src/homeassistant/homeassistant/core.py", line 1910, in async_call
        task.result()
        File "/usr/src/homeassistant/homeassistant/core.py", line 1950, in _execute_service
        await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
        File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 887, in admin_handler
        await result
        File "/usr/src/homeassistant/homeassistant/components/homeassistant/init.py", line 311, in async_handle_reload_all
        if errors := await conf_util.async_check_ha_config_file(hass):
        File "/usr/src/homeassistant/homeassistant/config.py", line 982, in async_check_ha_config_file
        res = await check_config.async_check_ha_config_file(hass)
        File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 184, in async_check_ha_config_file
        result[domain] = config[domain]
        KeyError: 'mysensors'
        and the second:
        Logger: homeassistant.components.mysensors
        Source: helpers/config_validation.py:867
        Integration: MySensors (documentation, issues)
        First occurred: 11. Juni 2023 um 18:35:52 (2 occurrences)
        The 'mysensors' option near /config/configuration.yaml:2 has been removed, please remove it from your configuration
        The 'mysensors' option has been removed, please remove it from your configuration
        unfortunately my knowledge is not sufficient to understand that:confused:
        thanx
        branther
        • B
          B
          Branther
          ...or did you mean the full protocol?
          i have downloaded it. i hope it will be of help.
          sorry, i can't send upload as file or as graphic. the board always gives error.
          it always expects a graphic file.
          • E
            E
            eiten
            Hi there,
            Well, MySensors configuration has moved from configuration.yaml to the UI config (which I also don't like, because at the moment, it's impossible to change something like the IP of a gateway). So you have to remove all MySensors related Stuff from the yaml file and (if not already there) add the gateway(s) over the UI again. Do a backup before. Not sure if the entities match after that operation.
            Can you post the relevant section from your configuration.yaml?
            Btw: to post large text files, you can use something like pastebin.
            • B
              B
              Branther
              wrote on last edited by Branther
              Thanks a lot, it works.
              If I remove mysensors from the yaml I can actually call a reboot again without problems.
              i had only the serial usb-gateway in the configuration.yaml
              MySensors now works without the entry in the yaml. After a reboot all entities are listed and work. but how can i change the parameters, e.g. the serial port of the gateway?
              here the section which concerns mysensors.
              mysensors:
              gateways:
              • device: '/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0'
                optimistic: true
                persistence: true
                version: 'V2.0'
              logger:
              default: info
              logs:
              homeassistant.components.mysensors: debug
              mysensors: debug
              • E
                E
                eiten
                Hey @Branther
                Cool it works again. Regarding your question:
                Short answer:
                You can't. Thats what I ment when I said I didn't like the change to the UI config in my last post.
                Experimental answer:
                • Create a backup
                • Delete the gateway device
                • Create a new gateway device, enter the name of the old persistence file
                If you are lucky enough, all your devices will continue to work.
                Risky answer:
                YOU ARE NOT SUPPOSED TO EDIT THESE FILES, BUT IT WORKED FOR ME
                • Create a backup
                • in your config directory, you'll find a hidden folder .storage
                • in this folder, you'll find the json file core.config_entries
                • search for "domain": "mysensors", in this section you can change the settings
                With this method, I successfully changed the IP address and the API version of a gateway.
                A kind request Could you do us a favor and include things like the config excerpt in your last post into code tags (```... your code here ...```)? This makes things easier to read.
                A hint It's a good idea to use the serial devices by the symlinks in /dev/serial like you do. It's even a better idea to use a symlink to this device like ln -s /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 /mydev/mysensors. Then, you can change the device and recreate the symlink without changing the configuration.
                Regards, Edi
                • B
                  B
                  Branther
                  thanks again Edi.
                  I will first make a full backup and put it on a new ssd.
                  after that i will test your solutions as far as i can.
                  sorry, i must have overlooked the code snippets function.
                  best regards
