  3. IR remote control
IR remote control
11 Posts 5 Posters 7.8k Views 3 Watching
  • ferpandoF
    ferpandoF
    ferpando
    I noticed there is an IRlib in the library.
    Is there also a hardware build for this library to use?
    Thanks in advance.
      http://www.mysensors.org/store/#light
      IR Transmitter modules
      • ferpandoF
        ferpandoF
        ferpando
        Yes, but no fun tutorial is what I meant.
          No, sorry :smile:
          • ferpandoF
            ferpandoF
            ferpando
            If I build one of these IR modules, will it appear on my VERA interface? or that's something still in development.
              I've created an very simple example here (for inspiration).
              https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/IrSensor/IrSensor.ino
              It creates an light-switch (on vera) which can control sending of two different ir-codes on the Arduino side. Any received ir-code is sent back to vera and is saved in VAR_1 of the device. This can be used (together with PLEG) to trigger scenes or actions based on received ir-code.
              ferpandoF D 2 Replies Last reply
                ferpandoF
                ferpandoF
                ferpando
                Thank you @hek
                I'll take a look at it.
                  D
                  D
                  derrij
                  wrote on last edited by derrij
                  @hek is still it works in 1.4.
                  after pressing one of light-switch buttons (on vera) next received IR code leads what sending are looped
                  and only next light-switch buttons press stops it loop
                  Vera
                  			50      03/15/15 13:36:06.195   luup_log:27: Arduino: Set variable: 10;1;1;1;2;1 <0x3073c680>
                  			50      03/15/15 13:36:21.179   luup_log:27: Arduino: Sending: 10;1;1;1;2;0 <0x2afdc000>
                  			50      03/15/15 13:36:21.216   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:21.310   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:37.509   luup_log:27: Arduino: Set variable: 10;1;1;0;24;0410a857 <0x3073c680>
                  			50      03/15/15 13:36:37.783   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:37.787   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:37.791   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:37.795   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:37.877   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:37.965   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.054   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.140   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.226   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.312   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.409   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.485   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.573   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.659   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.800   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.832   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:38.920   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.009   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.094   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.181   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.267   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.353   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.439   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.523   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.614   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.700   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.786   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.872   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:39.979   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.783   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.788   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.793   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.798   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.802   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.810   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.814   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.818   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.832   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.836   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:40.913   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.001   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.087   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.176   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.262   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.348   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.434   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.521   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.607   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.693   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.785   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.867   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:41.954   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.034   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.126   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.212   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.301   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.387   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.475   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.561   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.647   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.734   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.820   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.908   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:42.994   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:43.081   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:43.167   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  			50      03/15/15 13:36:43.253   luup_log:27: Arduino: Set variable: 10;1;1;1;2;0 <0x3073c680>
                  Arduino
                  			read: 0-0-10 s=1,c=1,t=2,pt=0,l=1:1
                  			send: 10-10-0-0 s=1,c=1,t=2,pt=0,l=1,st=ok:1
                  			read: 0-0-10 s=1,c=1,t=2,pt=0,l=1:0
                  			send: 10-10-0-0 s=1,c=1,t=2,pt=0,l=1,st=ok:0
                  			read: 0-1-10 s=1,c=1,t=2,pt=0,l=1:0
                  			Decoded NEC(1): Value:410A857 (32 bits)
                  			Raw samples(68): Gap:38608
                  			  Head: m8750  s4450
                  			0:m500 s600	1:m500 s600		 2:m450 s600	3:m500 s600
                  			4:m450 s650	5:m450 s1700		 6:m500 s600	7:m450 s600
                  			8:m500 s600	9:m450 s600		 10:m500 s600	11:m450 s1750
                  			12:m450 s600	13:m500 s600		 14:m450 s600	15:m500 s600
                  			16:m450 s1700	17:m500 s600		 18:m500 s1700	19:m500 s550
                  			20:m500 s1700	21:m500 s600		 22:m450 s600	23:m500 s600
                  			24:m450 s600	25:m500 s1700		 26:m500 s600	27:m450 s1700
                  			28:m500 s600	29:m500 s1700		 30:m450 s1700	31:m500 s1700
                  			32:m500
                  			Extent=59300
                  			Mark  min:450	 max:500
                  			Space min:550	 max:1750
                  			send: 10-10-0-0 s=1,c=1,t=24,pt=0,l=8,st=ok:0410a857
                  hekH 1 Reply Last reply
                  • D derrij
                    Vera
                    Arduino
                    			  Head: m8750  s4450
                    			32:m500
                    			Extent=59300
                    @derrij
                    Wow, that was a strange behaviour. I have no idea why it should do like this.
                    • Tomasz PazioT
                      Tomasz PazioT
                      Tomasz Pazio
                      wrote on last edited by Tomasz Pazio
                      I would like to receive IR code on pilot and based on this "value" trigger scenes for light relays etc.
                      when i use this example the only thing which i have on the monitor is
                      send: 4-4-0-0 s=3,c=1,t=24,pt=0,l=8,sg=0,st=ok:00ff30cf
                      Decoded NEC: Value:FFFFFFFF (0 bits)
                      Raw samples(4): Gap:38550
                      Head: m8700 s2300
                      0:m450
                      Extent=11450
                      Mark min:450 max:450
                      Space min:32767 max:0
                      send: 4-4-0-0 s=3,c=1,t=24,pt=0,l=8,sg=0,st=ok:ffffffff
                      Decoded NEC: Value:FF30CF (32 bits)
                      Raw samples(68): Gap:23684
                      Head: m8750 s4500
                      0:m450 s650 1:m450 s650 2:m450 s650 3:m450 s650
                      4:m450 s650 5:m450 s650 6:m450 s650 7:m450 s650
                      8:m450 s1750 9:m500 s1700 10:m500 s1750 11:m450 s1750
                      12:m450 s1750 13:m450 s1750 14:m450 s1750 15:m450 s1750
                      16:m500 s600 17:m500 s600 18:m500 s1750 19:m450 s1750
                      20:m450 s650 21:m450 s650 22:m450 s650 23:m450 s650
                      24:m450 s1750 25:m450 s1750 26:m500 s600 27:m500 s600
                      28:m500 s1700 29:m500 s1750 30:m450 s1750 31:m450 s1750
                      32:m450
                      Extent=66650
                      Space min:600 max:1750
                      on vera side there is one light sensor created only.
                      how this actually should work like?
                      • R
                        R
                        r-nox
                        Is any of this code archived someplace? Any direction to get started? I want to shut off my tv via Vera Edge.
