  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • AnticimexA Anticimex
    @ximinez the SenseBender you have patched/cut needs atsha personalization, so no SOFT anything. But you need to have the same hmac key stored on the atsha on the SenseBender as you have picked as soft hmac key in eeprom of your gateway (the node you have personalized for soft signing).
    ximinezX
    ximinezX
    ximinez
    @Anticimex Yeah, that's what I asked ;)
    I get:
    Writing key to slot 0...
    Data lock failed. Response: D3
    AnticimexA 1 Reply Last reply
    • ximinezX ximinez
      I get:
      AnticimexA
      AnticimexA
      Anticimex
      @ximinez locking data is a very bad idea. It will prevent you from changing the hmac key. You only need to (and should) lock configuration. Only lock data if you really know what you are doing.
      • ximinezX
        ximinezX
        ximinez
        Data not locked. Define LOCK_DATA to lock for real.
        Personalization is now complete.
        Configuration is LOCKED
        Data is UNLOCKED
        • ximinezX ximinez
          Data is UNLOCKED
          AnticimexA
          AnticimexA
          Anticimex
          @ximinez looks good. You should be done with personalization. Remember to require signatures from the SenseBender in addition to "enabling" it. You can also require signature on the GW, thus forcing all communications between them to be signed. The serial console will reveal how it goes. You can enable verbose debug (MY_DEBUG_VERBOSE_SIGNING) for the signing if you want more details on the signing parts.
          • ximinezX
            ximinezX
            ximinez
            I have the sensor sketch mostly done, but I'll have to do some soldering again tomorrow. It looks like D7 got burnt when I plugged in my ESP8266, giving ~0,5v out on that pin. Will have to work around that:
            Sôártinç óensor (RÎONA-, 2.0.0-beta)
            Raäio init æáiìåd. Ãèeck wiring.
            When that is OK, I'll look at the GW sketch.
            • ximinezX ximinez
              AnticimexA
              AnticimexA
              Anticimex
              Sounds good. Bedtime here too.
              • ximinezX
                ximinezX
                ximinez
                D3, D4 and D7 are all funky, and do not give ~3v when set high. So I'm back to the radio being on all the time.
                D5 and D6 mysteriously work just fine.
                Radio is now OK, but the sensebender reboots before it gets to setup().
                Stárting óensor (ÒÎONA-, 2.0.0-beôá)
                Ráäio init suããessæuì.
                æéîä parenô
                send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,óô=bc:
                [reboot and repeat]
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @ximinez
                  Sounds like it's on its way to the "other side"..
                  • ximinezX
                    ximinezX
                    ximinez
                    Yup. Setting up my other sensebender as a proper signing sensor and my uno as a gateway. This will have to wait until I get a couple more working sensors.
                    • ximinezX
                      ximinezX
                      ximinez
                      Ok. I set up my GW, and set up my healthy sensebender as an outdoor sensor. The zombie sensor is now a working indoor sensor.
                      I have enabled signing and set up whitelisting, but enabling signing debugging makes the sketch oversize, so I can't actually check if signing works - but atleast now I have two sensors.
                      Domoticz up
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        You will still be notified without verbose logging. And if you have enabled and require signing, you won't get any data if something fails (assuming signing is properly activated).
                        ximinezX 1 Reply Last reply
                        • user2334U user2334
                          I just received two Sensebenders, but have problems getting the device to consume little power. I get totally different values as displayed above.
                          With the following sketch, I get about 5,6mA in active state and 1,6mA in sleep mode with nRF24 attached. I have compared different nRF24-chips and this one consumed the least power.
                          Without the nRF24, I get 4mA and 0,025mA (=25µA) during sleep mode.
                          #include <LowPower.h>
                          #include "RF24.h"
                          RF24 radio(9, 10);
                              delay(8000);
                              LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
                          user2334U
                          user2334U
                          user2334
                          #include "RF24.h"
                          RF24 radio(9, 10);
                              delay(8000);
                          As a follow-up to my previous posting, I can confirm, that using original nRF24-modules (best source seems to be https://www.itead.cc/nrf24l01-module.html), I get 0,023mA (=23µA) with nrf24 attached during sleep mode (no difference between the libraries JeeLib->Sleepy::loseSomeTime or LowPower->LowPower.powerDown).
                          It is quite interesting, that so many nRF24 Modules (bought from eBay, from Amazon UK) are clones with higher power consumption. Some of them use 3mA, some have electrical short, ...
                            ximinezX
                            ximinezX
                            ximinez
                            @Anticimex I've set MY_SIGNING_SOFT, MY_SIGNING_REQUEST_SIGNATURES and MY_SIGNING_NODE_WHITELIST on the GW, and reenabled (normal) debug but not signing debug since that is too big.
                            With those enabled, if the sending node does not sign, I should not get this?
                            0;255;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:6.3
                            0;255;3;0;9;read: 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:59
                            • ximinezX ximinez
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @ximinez The GW will only require signatures from a node that in turn require signatures.
                              It is the sg-flag that indicate if a message is signed, in your case, both messages are unsigned.
                              If you only have node->gw communication, both gw and node has to require signatures for you to see signed messages.
                              If you have gw->node communication, it is enough that the node require signatures, the gw will then sign them, no matter if the gw require signatures or not.
                              • ximinezX
                                ximinezX
                                ximinez
                                0;255;3;0;9;read: 3-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                0;255;3;0;9;read: 3-3-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
                                0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:57ACB4BD46843BFCC7ABA693CC5AA527F7724531F525338E8A
                                0;255;3;0;9;read: 3-3-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
                                I feel more secure now :-P
                                • ximinezX ximinez
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @ximinez Hm, good, but I still see no signed message. But at least a nonce was sent
                                    ximinezX
                                    ximinezX
                                    ximinez
                                    @Anticimex Sensor values are getting through though. And signing is requested on both ends (for one sensor so far). I can't see any other #defines that should be set to enable signing. I get the same result on both the zombie sensor and the unmodded one.
                                    I get three "sign fail" (showing up as verify fail on gw) before the sketch reaches setup(), where the ATSHA gets powered up. I will need to power the ATSHA somewhere in the mysensors library. However, once setup() is reached, the ATSHA seems to handle powering down and up just fine.
                                    I can however say that it the Si7021 doesn't like being powered off and back on again after sleep. That causes the MCU to reset.
                                    • ximinezX ximinez
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @ximinez Ah, yes, on development branch the signing backend clear the sign flag when it verifies the message. so it will always show as 0 without verbose signing debug enabled.
                                      I know there have been discussions about a "pre setup" to be used for early sketch init. You probably want to power the atsha for early handshaking as well to get the sketch name and such to propagate properly. @hek perhaps has the latest on such features.
                                        ximinezX
                                        ximinezX
                                        ximinez
                                        wrote on last edited by ximinez
                                        #439
                                        I've built a nicer-looking serial gateway instead of the rather large ethernet gateway. I thought that would basically be a "slot-in" as long as I personalize the GW it with the same SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY as the original GW. Are there more steps that need to be taken to get the sensors to connect?
                                        Serial Gateway
                                        • ximinezX
                                          ximinezX
                                          ximinez
                                          No matter what I do now, this is what I get:
                                          send: 2-2-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                          sign fail
                                          send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:26.0
                                          send: 2-2-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                          sign fail
                                          send: 2-2-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=fail:34
                                          send: 2-2-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                          sign fail
