  3. MQTT Gateway + Node-Red + Vis
3 Posts 2 Posters 2.7k Views 2 Watching
  • bpairB
    bpairB
    bpair
    wrote on last edited by bpair
    I have been playing around with the MQTT Gateway and Node-Red. I started with what user @Heinz did in a different forum topic however I am hoping to use MQTT.
    First of all, node-red is a dead simple way to monitor MQTT traffiction. The question I have is about the messages created form the MQTT gateway.
    I am only getting messages that "set" data. For example
    { "topic": "MyMQTT/20/0/V_HUM", "payload": "53.5", "qos": 0, "retain": false, "_msgid": "a3f256c8.5c0da8" }
    but I never see any presentation messages or ack messages. I took a look at the MQTT code but I don't know C++. Is there a difference between the serial gateway and the mqtt gateway? Meaning is there more functionality in the serial gateway?
    By the way the vis app for node-red, https://www.npmjs.com/package/node-red-vis
    , has some nice functionality. Pretty easy to add switches. I think you need your sensor IDs to be static but I think you could easily create a widget to display sensors that are new.
    • FotoFieberF
      FotoFieberF
      FotoFieber
      The 'default' MQTT Gateway doesn't support all message types.
      I hacked the MQTT Client Gateway to support:
      • sketchinfo
      • sketchversion
      • time
      • batterylevel
      http://forum.mysensors.org/topic/524/mqtt-client-gateway/27
      There are articles about the serial gateway and node-red in this forum. This could be another solution for you.
      • bpairB
        bpairB
        bpair
        Thanks - I will give it a try.
