  3. How to verify that ethernet gateway is working without sensors
6 Posts 3 Posters 2.7k Views 2 Watching
    mathias
    I just built my first ethernetgateway on a Arduino Nano and W5100 ethernet and i have not yet got more components to build any sensors:(
    Are there any way to verify that the gateways ethernet and radio is working without having a sensor?
    I plugged in the ethernet cable and im able to ping the ip address configured for it, are there any other useful tests that can be done or i have to wait until i can connect a sensor to it?
    //Mathias
    • S
      Stric
      Connect to it and send:
      0;0;3;0;2;
      it should respond with something like:
      0;0;3;0;2;1.4.1
      (that is: "What's your version?" "1.4.1")
        mathias
        That seems to work fine and i have also received some radios to build my first sensor but im stuck and im not really sure how to troubleshoot it.
        I have my ethernet gateway can can connect to with myscontroller and putty to test to send commands.
        And i have also built a simple door sensor but i cannot see any communication. How could i start to trouble shoot if it is the gateways radio or something with the sensor or both?
        //Mathias
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          Have you looked at the serial output of the sensor node? Maybe start there and post what you see.
            mathias
            I get this from my sensor:
            sensor started, id 255
            req node id
            send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
            Does the st=fail mean that it doesnt send it or its just a part of the message sent so i can start troubleshoot the gateway?
            //Mathias
              mathias
              WHOO Everything seems to be working now:)
              //Mathias
