  3. Measuring current
Measuring current
11 Posts 3 Posters 4.8k Views 2 Watching
  • F
    F
    Fredrik Carlsson
    wrote on last edited by Fredrik Carlsson
    Hello
    A somewhat stupid question
    I have a arduino 3,3 volt without step up or anything. Driven by 2 1,5V batteries.
    All positive lines (DHT22 +battery + battery measuring circuit) is connected on Vin pin and all ground cables on ground pin. So fairly simple circuit. Isnt it just to put in the multimeter somewhere in the circuit? Then i read around 4-5mA but the arduino restarts all the time, dont really know why?
    How to correctly read current on an arduino circuit?
    AWIA 1 Reply Last reply
    • T
      TimO
      Did you connect the multimeter serial to the circuit?
      +3 V --> Multimeter --> Circuit --> GND
      You can't measure the current if it is connected in parallel to the circuit.
      • F Fredrik Carlsson
        Hello
        AWIA
        AWIA
        AWI
        @Fredrik-Carlsson The probable cause is the internal resistance of your multimeter in the low amp setting. Try setting it in A or mA range if the option is there. The voltage drop over the internal resistor (ghost voltage) is probably to high. eg when the internal resistor = 200 Ohm => U=I x R => U= 0.005 x 200 = 1 Volt. When using 3V als power the arduino voltage drops to 2 V (and restarts).
        • F
          F
          Fredrik Carlsson
          Aha, that could probably be the cause then
          I have now tried with the following 2 scenarios:
          Using internal pullup, then i get the current draw 2,85 mA in sleep, which is quite high?
          I tried to deactivate the internal pullup and used a 1Mohm resistor as external pullup instead but then the sketch doesnt even start.
          As referenced to this thread: http://forum.mysensors.org/topic/1287/door-window-sensor-consuming-more-power-when-closed/3
          **Or is the cause the fact that I am using 10k/4,7k resistors for battery measurment instead of 1m/470K ? **
            AWIA
            AWIA
            AWI
            @Fredrik-Carlsson I was referring to the internal resistor of your multimeter... Did you detach the Led of the Arduino? And yes a 10k/4.7k battery measurement circuit draws I = U/R = 3V / 14.700 Ohm = ~ 0.2 mA, which is much more than a sleeping Arduino.
            • F
              F
              Fredrik Carlsson
              @AWI Hello, yes I was aware of that. So it could be possible that configuration no 2 is working, just that it is not possible to measure. .. I will try when I come home. And yes the led is detached. I will also change resistors for the measurement circuit. Just need to order some 470k resistors
              • F
                F
                Fredrik Carlsson
                Hello again.
                I just got some new 470k resistors today so i changed out the 10k/4,7k resistors on the battery circuit to 1mohm/470k
                The current draw is now 0,63mA when sleeping and 17,6mA when sending.
                Especially the sleeping current seem very high. Any ideas to why?
                  Hello again.
                  AWIA
                  AWIA
                  AWI
                  @Fredrik-Carlsson Can you post your sketch?
                  • F
                    F
                    Fredrik Carlsson
                    @awi
                    #include <DHT.h>
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    #define CHILD_ID_SWITCH 2
                    #define BUTTON_PIN  3
                    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
                    #define VBAT_PER_BITS 0.003363075 //(1mohm / 470 kohm)   Calculated volts per bit from the used battery montoring voltage divider.   Internal_ref=1.1V, res=10bit=2^10-1=1023, Eg for 3V (2AA): Vin/Vb=R1/(R1+R2)=470e3/(1e6+470e3),  Vlim=Vb/Vin*1.1=3.44V, Volts per bit = Vlim/1023= 0.003363075
                    #define VMIN 1.9  // Battery monitor lower level. Vmin_radio=1.9V
                    #define VMAX 3.3  //  " " " high level. Vmin<Vmax<=3.44
                    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    boolean metric = true;
                    int oldBatteryPcnt = 0;
                    MyMessage msg(CHILD_ID_SWITCH,V_TRIPPED);
                      analogReference(INTERNAL);
                      gw.begin();
                      gw.sendSketchInfo("Humidity", "1.0");
                       // Setup the button
                      pinMode(BUTTON_PIN,INPUT);
                      // Activate internal pull-up
                      gw.present(CHILD_ID_SWITCH, S_DOOR);
                        // Get the update value
                      int value = digitalRead(BUTTON_PIN);
                      // Send in the new value
                      gw.send(msg.set(value==HIGH ? 1 : 0));
                      if (isnan(temperature)) {
                        lastTemp = temperature;
                        if (!metric) {
                        Serial.print("T: ");
                        Serial.println(temperature);
                      if (isnan(humidity)) {
                          lastHum = humidity;
                          Serial.print("H: ");
                          Serial.println(humidity);
                      int sensorValue = analogRead(BATTERY_SENSE_PIN);    // Battery monitoring reading
                    //  Serial.println(sensorValue);
                      float Vbat  = sensorValue * VBAT_PER_BITS;
                    //  Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" V");
                     //int batteryPcnt = sensorValue / 10;
                      int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
                    //  Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
                        oldBatteryPcnt = batteryPcnt;
                      gw.sleep(BUTTON_PIN-2, CHANGE, SLEEP_TIME);
                      @awi
                      #include <DHT.h>
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                        gw.begin();
                         // Setup the button
                          if (!metric) {
                            lastHum = humidity;
                      AWIA
                      AWIA
                      AWI
                      @Fredrik-Carlsson Looks fine to me.. and you are using the below circuit?
                      upload-50fcc328-84bc-4a1c-93ac-d96a660257b1. Maybe a stupid question but do you have a radio connected?
                      • F
                        F
                        Fredrik Carlsson
                        @AWI
                        Yes i am. but there is mistake in the picture the R3 is connected between Pin 3 and VCC, not ground (pull up resistor).
                        Then that leaves me hanging a bit because that is way more than I will be comfortable with in terms off battery changes.
                        Any suggestion what to do?
