  3. Domoticz
  4. Temp and Relay node
Temp and Relay node
19 Posts 6 Posters 13.0k Views 5 Watching
  • M Offline
    M Offline
    mikee
    Hi Everybody,
    First of all Thanks to all of you people and Mysensor Team for creating this and sharing it to all of us.
    I’m one of „ninjasphere“ backers, and after this project crashed, I started searching some DIY possibilities and I found this. I’m running Domoticz (ver.2563) in RPi2 and serial nano GW (on 1.4 code and libraries). I successfully created Temp/Hum and multiple Temp sensors but I got stuck on Temp/Relay node. Temperatures are working just fine (5pcs. DS 18B20) but the Relay won’t work. Temp sensors are on Pin3, Relays on 5 and 6. I’m using sketch I found here on forum:
     // Example sketch showing how to send in OneWire temperature readings
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
        #include <OneWire.h>
        #define ONE_WIRE_BUS 3 // Pin where dallas sensor is connected
        #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_TEMP_SENSORS 5
        unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
        OneWire oneWire(ONE_WIRE_BUS);
        //int numSensors = 0;
        boolean metric = true;
        MyMessage msg(0, V_TEMP);
        //int offsetforrelays = 5;
          // Startup OneWire
          sensors.begin();
          gw.begin(incomingMessage, AUTO, true);        // Startup and initialize MySensors library. Set callback for incoming messages.
          gw.sendSketchInfo("Temp and Relays", "1.0");   // Send the sketch version information to the gateway and Controller
          for (int i = 0; i < NUMBER_OF_TEMP_SENSORS ; i++)
            gw.present(i, V_TEMP); // creates 0, 1 and 2
          for (int sensor = 1, pin = RELAY_1 ; sensor <= NUMBER_OF_RELAYS ; sensor++ , pin++)
            //   loop from sensor1/pin4 to sensor2/pin5 (numofrelays=2)
            gw.present(NUMBER_OF_TEMP_SENSORS + sensor, S_LIGHT); // should create 3 and 4
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor) ? RELAY_ON : RELAY_OFF);
          gw.process();
          for (int i = 0; i < NUMBER_OF_TEMP_SENSORS && i < MAX_ATTACHED_DS18B20; i++) {
            float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
            // Only send data if temperature has changed more then 1 degC and no error
            if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
              gw.send(msg.setSensor(i).set(temperature, 1));
              lastTemperature[i] = temperature;
          //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
            // Change relay state
            Serial.println(message.sensor);
            digitalWrite(message.sensor - 4 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
    When I push switch in Domoticz it just freeze up, and I have to unplug RPI and restart it. Do I need some special adjustment in Domoticz for button?
    Does anybody have working relay/temp sketch on Domoticz, or can anybody give me some advice?
    Thanks guys
    • S Offline
      It didnt work with domoticz and that version for me. The relay was just dead. I uninstalldd domotizc and running 2608 and it works.
      • M Offline
        M Offline
        mikee
        Hi sundberg84 , Thanks for your advice. I was only able to upgrade to beta 2650 (my programing skills are very poor – I followed steps in Domoticz wiki). Domoticz environment is working OK now, I can switch and icons are changing properly. Relays are still death. I replaced definition of 1/0 for relay write in arduino code so relay LED begun light. In serial monitor of node I can nicely see “incoming change for sensor” and “new status” by every command from domoticz for each relay, but there is no switching at all.
        • S Offline
          sebas
          Sounds like a problem in the arduino <-> relay communication as the Arduino is receiving data from Domoticz. Have you tested that the relay works by directly putting power on the signal pin of the relay?
          • M Offline
            M Offline
            mikee
            When I´m uploading sketch both two relays start to light and during upload switch off and when uploaded turn on.
            • M mikee
              Moshe LivneM Offline
              Moshe Livne
              @mikee The switching on and off is normal as the sketch tries to restore the last saved state of the relay.
              do this:
              first try this sketch:
                  pinMode(3, OUTPUT);
                  digitalWrite(3, HIGH);
                  delay(10000);
                  digitalWrite(3, LOW);
                  delay(10000);
                  delay(10000);
              This should turn your relay (assuming it is on pin 3) on and off twice with 10 seconds between operations. I don't have one connected now so cant check it but it does compile and should work. you can also try this on arduino with no NRF.
              Let me know if it works or not
              • M Offline
                M Offline
                mikee
                Hi Moshe,
                I´ll try this after I come home, thanks
                • R Offline
                  R Offline
                  robosensor
                  You should not query sensor temperatures every 750 ms. Try this code with proper pause between sensor readings: http://forum.mysensors.org/topic/1562/door-motion-and-temperature-sensor/34
                  Also, your code is in constant 750ms delay, so incoming messages are delayed or even skipped. You should use newer code from git with non-blocking sensor readings: https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino
                  Your code looks like this now:
                      gw.process();
                      delay(750); // 750ms of no incoming messages processing, no response to relay msgs
                  • S Offline
                    Hi @mikee.
                    It seems like the same problem in having at the moment: link
                    Domoticz send command, node recieves and the node/relay led turns on but the coil does not activate.
                    I tried with higher volatge and then the coil activated. I dont know why this happens but seems like some power issues.
                    I have measure 5v over the signal but maybe to low mA to activate? According to datasheet you need 71.4mA
                    I dont know how to measure this or if thats is more than the arduino can handle?
                    • M Offline
                      M Offline
                      mikee
                      Exactly - I tried other sketch yesterday, that worked same way - LED turned on, but contacts stayed off. I will try to power the relay board separately with raw voltage from Arduino (9V)
                      • M mikee
                        Moshe Livne
                        @mikee the relays can't take more than 5.5v.
                        @robosensor is very right. The relay sensor sketch in the examples is made to also be a repeater node. repeater nodes (and nodes that can receive incoming messages) are looping endlessly processing messages. when you merged the sketches you got a sketch that tried to loop endlessley and to pause 750ms at the same time. this won't work.... you need to use the non blocking functions and implement the delay in the sketch the way the examples he sent are doing it.
                        • S sundberg84
                          Hi @mikee.
                          Moshe Livne
                          @sundberg84 try the mini sketch above - it does not use the NRF and has no network or controller dependence so it will tell you if there is enough juice to power the relays.
                          • M Offline
                            M Offline
                            mikee
                            Thanks @robosensor , I´ll try it.
                            @Moshe Livne, Sure they can - on coil (at least mine is built so), but board must have jumpers to separate it . Input must be 5V- of course transistor would burn. I'll try your suggestions, thanks
                            • M Offline
                              M Offline
                              mikee
                              Hi Guys,
                              So after few day I´m back again :expressionless: . I started with @Moshe Livne test – worked just fine - thanks. I found more relay examples and the one from @petewill http://forum.mysensors.org/topic/775/8-lamp-outlet-smart-plug-module worked!!! Now I´m trying to merge new Dallas sketch – mentioned by robosensor with petewill s 8$ outlet:
                              //Relay
                              #define RELAY_PIN  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                              #define RELAY_CHILD 0
                              //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
                              int numSensors=0;
                              MyMessage msgT(0,V_TEMP);
                              MyMessage msg(RELAY_CHILD,V_LIGHT);
                                // Startup OneWire
                                sensors.begin();
                                gw.begin();
                                gw.sendSketchInfo("Temperature Sensor w relay", "1.0");
                                   gw.present(i, S_TEMP);
                                   gw.present(RELAY_CHILD, S_LIGHT);
                                    pinMode(RELAY_PIN, OUTPUT);
                                gw.process();
                                gw.sleep(conversionTime);
                                  if (lastTemperature[i] != temperature && temperature != -127.00) {
                                    gw.send(msgT.setSensor(i).set(temperature,1));
                                if (message.type==V_LIGHT) {
                                   digitalWrite(RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                              //     gw.saveState(message.sensor, message.getBool());
                              //     // Write some debug info
                              It compiles, temperatures are working but relay is not working, can someone help me, pls.
                              @sundberg84 next day after I switch to latest Domoticz beta system started to freeze again. I´ts only after relay switch command pushed by user or even by timer (when I checked the logs of the switch all times are loged 5-7 minutes later than the switch time). Is there any tutorial or does exist system how to switch my Domoticz to your version (2606), without installing all Domoticz manually? I was able to run SD versions only and 2606 is zip file.
                              Thanks for your time Guys
                              • A Offline
                                A Offline
                                AWI
                                You need to initialize the incoming messages in gw.begin() otherwise you will never receive a message. i.e. gw.begin(incomingMessage, AUTO, false);
                                For the update of Domoticz, switch on the beta channel in settings and push the update button. No need to reinstall.
                                • M Offline
                                  M Offline
                                  mikee
                                  HI, @AWI I tried
                                  and then
                                  gw.begin(incomingMessage, NODE_ID);
                                  After I changed #define RELAY_CHILD 0 to 6 and once (one of many tries) I turned it on, but couldn’t turn it off. In serial monitor of node is no command to switch visible.
                                  #define NODE_ID 19
                                  //Relay
                                  int numSensors=0;
                                    // Startup OneWire
                                    sensors.begin();
                                    gw.process();
                                  //Relay
                                  int numSensors=0;
                                    // Startup OneWire
                                    sensors.begin();
                                    gw.process();
                                  Is something wrong with identification of relay? Temperatures are working just fine.
                                  A 1 Reply Last reply
                                  • M mikee
                                    HI, @AWI I tried
                                    and then
                                    #define NODE_ID 19
                                    //Relay
                                    int numSensors=0;
                                      // Startup OneWire
                                      sensors.begin();
                                      gw.process();
                                    //Relay
                                    int numSensors=0;
                                      // Startup OneWire
                                      sensors.begin();
                                      gw.process();
                                    A Offline
                                    A Offline
                                    AWI
                                    @mikee how many temperature sensors are you using? The id of the relay sensor should be higher than that number (better to use a value higher than Max number. Else there is overlap.
                                    You are also presenting the relay more than once in the init loop. Once should be enough. When switching the relay from the controller it should be visible in the serial output of the node.
                                    • M Offline
                                      M Offline
                                      mikee
                                      Hi @AWI , I have 5 DS 18b20s , i chose CHILD ID 6 because of that , so I´m gonna lower max . temp sensor No.
                                      Witch line in sketch is duplicity of relay presentation (sorry for dumb questions),
                                      Thanks so much
                                      • M mikee
                                        Thanks so much
                                        A Offline
                                        A Offline
                                        AWI
                                        wrote on last edited by AWI
                                        @mikee in the setup loop for the temp sensors you are also presenting the relay. So one time for each temp sensor. You can just place it outside of the loop.
                                        It won't solve your problem but is more decent. Then try to make sure you are getting the relay input from the controller by looking at the serial output of the node
                                        12.1k
