  3. Best way to combine two sketches using interrupt and sleep time?
2 Posts 2 Posters 1.3k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I want to combine the soil-moisture and the temp sketch into one. But they use different methods to sleep between redings. The soil-moisture-sketch uses interrupt and the temp sleeps for a specific time.
    What would be the best way to combine those two to be able to save as much battery power as possible? If I would be fine with them both reading the sensor-values for example every 5 min, can I just copy the loop block from the moisture sketch into the bottom of the loop of the temp sensor sketch?
    • L
      L
      LastSamurai
      You can actually combine both I think. Search for sleep. There is a sleep function
      bool sleep(int interrupt, int mode, unsigned long ms=0);
      that both listenes to an interrupt and wakes up after a certain time. The return boolean value indicates which one.
