  3. Relay and Repeater - Just learning stuff
4 Posts 4 Posters 4.6k Views 2 Watching
  • P
    P
    punter9
    So I have several nodes going in the house. I love mysensors and really appreciate all who have made this possible.
    Today I am looking into repeaters and learning how to make my custom multi sensor nodes into repeaters. Specifically any with a relay since they process incoming messages. From what I can tell they already are. Could someone fact check me to make sure I am thinking about this correctly?
    1.) To make a repeater node you first off cannot have any sort of sleep function
    2.) You need this code to enable repeater mode, specifically I think you only need the true part.
    gw.begin(NULL, AUTO, true);
    this would also work i am thinking
    3.) This is what makes a repeater do repeater things.
    gw.process();
    • sundberg84S
      Hi!
      Not the expert, but I think you are on the right track.
      The gw.begin(incomingMessage, AUTO, true); is only needed if you have a senser expecting incoming messages.
      If its only a repeater you can use the first one.
      Br
      • TheoLT
        TheoLT
        TheoL
        wrote on last edited by TheoL
        I have never worked with the repeater but I just hacked an example for you. I'm not able to test it and I don't know if this will effect the performance of the repeater. But at least it compiles.
        For test purposes it might be better to hook an led with a 220 ohm resistor to the relay_pin.
         * Version 1.0 - Henrik Ekblad
         * Example sketch showing how to create a node thay repeates messages
         * from nodes far from gateway back to gateway.
         * It is important that nodes that has enabled repeater mode calls
         * gw.process() frequently. Repeaters should never sleep.
        #define CHILD_ID_RELAY 1   // Id of the sensor child
        #define RELAY_PIN 3 // The pin for controling the relay
          // The third argument enables repeater mode.
          gw.begin( incomingMessage, AUTO, true);
          //Send the sensor node sketch version information to the gateway
          gw.sendSketchInfo("Repeater Node", "1.0");
          pinMode (RELAY_PIN, OUTPUT );
          gw.present(CHILD_ID_RELAY, S_LIGHT);
          // By calling process() you route messages in the background
          gw.process();
          if (message.type==V_LIGHT) {
             if ( message.sensor == CHILD_ID_RELAY ) {
                digitalWrite( RELAY_PIN, message.getBool()? HIGH :LOW );
        Let me know if it works. Might be somthing I'll be needing myself ;-)
        • jl277013J
          jl277013J
          jl277013
          Do I need to link/pair the repeater node to the gateway or does it just work when I power it up?
