  3. Battery powered PIR and temp/humid sensor
22 Posts 7 Posters 10.3k Views 8 Watching
  • T
    tomkxy
    I have built a battery powered PIR temp/humidity and light sensor. I based the sketch on the Sensebender sketch which allows to control how long the sensor sleeps and how often to report measurements back. I changed the sketch now so that when the PIR is triggered an interrupt wakes up the sensor.
     gw.sleep(INTERRUPT,RISING, MEASURE_INTERVAL);
    This is all working well. However, now I lost total control over measurement intervals and send intervals. If I get it right retrieving millis will not work since they are not counted while the sensor sleeps.
    Any ideas how to solve that.
    • L
      L
      LastSamurai
      There is another sleep method which also takes a time in millis and wakes on both, intervall and interrupt. That might be a solution?!
      • T
        tomkxy
        @LastSamurai: I am using that method. My problem is that due to the fact that motion will trigger the interrupt and hence the sleep time in between measurements vary depending on movements. So when there is a lot of motion the send and measurement frequency will be much shorter and thus draining the battery faster.
          The return value from gw.sleep tells you if it woke up on timer or pin.
          So just send motions status when pin triggered. If timer triggered wakeup send temp.
          • T
            tomkxy
            @hek This will definitely help but it still means that there is no real means to control the time between temp/humid measurements. In the worst case the PIR triggers over a longer time always the interrupt and thus temp is never send. Even if I introduce some counter which when reached will trigger a temp measurement I have no glue what the interval length in between is. Or do I miss something?
            hekH 1 Reply Last reply
            • T tomkxy
              @tomkxy
              I don't understand.. the timer option will wake your board at the specified time even if no motion was detected.
              • T
                tomkxy
                @hek
                Sorry, I didn't express it well enough.
                Let's say my sketch would sleep between two measurements 60 sec and send every 30 measurements its value, which means every 30 minutes (which are the defaults of the sensebender sketch). I can increase or reduce the frequency by adjusting the sleep times and send intervals easily.
                By introducing the interrupt - which I think there is no way around -, the sleep time can be interrupted somewhere between 1 second and 60 seconds. And I don't know how long my sketch has slept. If I cannot determine the time how long my sketch was sleeping I cannot determine when I should take the next temp/humid measurement. Although I can still use the loop counter, I have no control over the elapsed time between two temp/humid measurements.
                  True, if you wake up from pin change you haven't the exact knowledge of elapsed time (< MAX-SLEEP-TIME though).
                  But in most applications I doubt it would super exact temp-send-interval would matter much... It will only diff when pin change wake-up interfere.
                  • T
                    tomkxy
                    @hek
                    Thanks! That confirms my understanding.
                    • HaakonH
                      HaakonH
                      Haakon
                      @tomkxy: Have you gathered some experiences with this setup over time? And would you mind sharing the Arduino sketch you are using?
                      I am hoping to do more or less the same with Sensebenders and PIRs, and I am new to electronics of this sort.
                      • T
                        tomkxy
                        @Haakon I have one of these sensor in place since about half a year and it is working well. Last battery change is about 4 month ago.
                        Please find the sketch below which requires some cleanup.
                        Multisensor Sketch
                        Author: Thomas Krebs, thkrebs@gmx.de
                        This sketch reads temperature, humidity, light and presence.
                        It is based on the various examples sketches from SparkFun and MySensors
                        It uses the following sensors:
                        Light           - TSL2561
                        Temp&Humidity   - HTU21D
                        Presence
                        HTU21D and TLS2561 need to connect the I2C pins (SCL and SDA) to your Arduino.
                        The pins are different on different Arduinos:
                                            SDA    SCL
                        Any Arduino         "SDA"  "SCL"
                        Uno, Redboard, Pro  A4     A5
                        Mega2560, Due       20     21
                        Leonardo            2      3
                        #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
                        #define MY_SIGNING_FEATURE
                        #define MY_SIGNING_ATSHA204
                        #define MY_NODE_ID              26
                        #define BATT_SENSOR
                        #include <TSL2561.h>
                        #include <SparkFunHTU21D.h>
                        #include <Wire.h>
                        #include <avr/power.h>
                        #define VERSION           "1.4"
                        #define SKETCH_NAME       "Multisensor A"
                        #define TEMP_CHILD_ID   1
                        #define HUM_CHILD_ID    2
                        #define LIGHT_CHILD_ID  3
                        #define MOTION_CHILD_ID 4
                        // Uncomment the line below, to transmit battery voltage as a normal sensor value
                        #define BATT_SENSOR    199
                        #define MAX_VOLTAGE    1316
                        #define MIN_VOLTAGE    890     // it seems that about 0.89 V the sensor stops working
                        // How many milli seconds between each measurement
                        #define MEASURE_INTERVAL 120000
                        // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
                        #define FORCE_TRANSMIT_INTERVAL 30
                        // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
                        // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
                        // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
                        // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
                        #define HUMI_TRANSMIT_THRESHOLD   0.5
                        #define TEMP_TRANSMIT_THRESHOLD   0.5
                        #define LIGHT_TRANSMIT_THRESHOLD  0.3    // relative change
                        // Pin definitions
                        #define LED_PIN            13            // TODO: need to check that
                        #define BATTERY_SENSE_PIN  A0            // select the input pin for the battery sense point
                        #define MOTION_SENSOR      3             // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                        #define INTERRUPT          1             // Usually the interrupt = pin -2 (on uno/nano anyway)
                        // Global settings
                        int tempMeasureCount = 0;
                        int lightMeasureCount = 0;
                        int sendBattery = 0;
                        boolean isMetric = true;
                        boolean highfreq = true;
                        boolean motionDetected = false;
                        int repeats = 2;
                        // Storage of old measurements
                        float lastTemperature = -100;
                        float lastHumidity = -100;
                        long  lastBattery = -100;
                        long  lastLight = -5000;
                        int   lastTripped = -1;
                        int   motionTrips = 0;  // count the number of cont. motion trips
                        HTU21D myHumidity;
                        TSL2561 myLight(TSL2561_ADDR_FLOAT);
                        // Sensor messages
                        MyMessage msgTemp(TEMP_CHILD_ID,V_TEMP);
                        MyMessage msgHum(HUM_CHILD_ID,V_HUM);
                        MyMessage msgLight(LIGHT_CHILD_ID,V_LEVEL);
                        MyMessage msg(MOTION_CHILD_ID, V_TRIPPED);
                        #ifdef BATT_SENSOR
                        MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                         * Setup code
                          pinMode(LED_PIN, OUTPUT);
                          Serial.print(F(SKETCH_NAME));
                          Serial.println(VERSION);
                          Serial.flush();
                        #ifdef MY_SIGNING_ATSHA204_PIN
                          // Make sure that ATSHA204 is not floating
                          pinMode(MY_SIGNING_ATSHA204_PIN, INPUT);
                          digitalWrite(MY_SIGNING_ATSHA204_PIN, HIGH);
                          analogReference(INTERNAL);
                          // setup sensors
                          setup_htu21d();
                          delay(100);
                          setup_tls2561();
                          delay(500);
                          // setup motion sensor
                          pinMode(MOTION_SENSOR, INPUT);
                          Serial.println(F("Setup complete..."));
                        void presentation()  {
                          sendSketchInfo(SKETCH_NAME, VERSION);
                          present(TEMP_CHILD_ID, S_TEMP);
                          present(HUM_CHILD_ID, S_HUM);
                        //  present(LIGHT_CHILD_ID,S_LIGHT_LEVEL);
                          present(MOTION_CHILD_ID, S_MOTION);
                        #ifdef BATT_SENSOR
                          present(BATT_SENSOR, S_POWER);
                          isMetric = getConfig().isMetric;
                        #ifdef MY_DEBUG
                          Serial.print(F("isMetric: ")); Serial.println(isMetric);
                          Serial.flush();
                          Serial.println(F(" - Online!"));
                        /* Setup HTU21d
                        void setup_htu21d() {
                          myHumidity.begin();
                        #ifdef MY_DEBUG
                          Serial.println("Setup temp/humid sensor completed");
                        /* Setup TLS2561
                        void setup_tls2561() {
                          if (myLight.begin()) {
                            Serial.println(F("Found light sensor"));
                          } else {
                            Serial.println(F("Light Sensor not found - cont. anyway"));
                          myLight.setGain(TSL2561_GAIN_0X);          // set 16x gain (for dim situations)
                          // Changing the integration time gives you a longer time over which to sense light
                          // longer timelines are slower, but are good in very low light situtations!
                          //tsl.setTiming(TSL2561_INTEGRATIONTIME_13MS);  // shortest integration time (bright light)
                          myLight.setTiming(TSL2561_INTEGRATIONTIME_101MS);  // medium integration time (medium light)
                          //tsl.setTiming(TSL2561_INTEGRATIONTIME_402MS);  // longest integration time (dim light)
                         *  Main loop function
                          tempMeasureCount++;
                          lightMeasureCount++;
                          sendBattery++;
                          bool forceTransmit = false;
                          if (motionDetected) {
                            sendMotion(false);  // do not force transmission unless motion status has changed
                          // do not enter into sensor data gathering on each motion tripped
                          if ((!motionDetected) || (motionTrips > 3)) {
                            motionTrips = 0; // avoid starvation of temp measure in case we have a lot of motion
                            // I do the battery check at the beginning
                            if (sendBattery > 60) {
                               sendBattLevel(forceTransmit); // Not needed to send battery info that often
                               sendBattery = 0;
                            if ((lightMeasureCount > FORCE_TRANSMIT_INTERVAL) || (tempMeasureCount > FORCE_TRANSMIT_INTERVAL) ) { // force a transmission
                              forceTransmit = true;
                            // Get & send sensor data
                            wait(200);
                            sendTempHumidityMeasurement(forceTransmit);
                            wait(200);
                            sendLightLevelMeasurement(forceTransmit);
                            wait(200);
                            sendMotion(forceTransmit);
                          wait(100);  // I don't know whether that is really required; however I have the impression that shutting down the radio leads to
                                         // problems in the communication when using signatures
                          Serial.println("going to sleep");
                          if (sleep(INTERRUPT,RISING, MEASURE_INTERVAL)) {
                            motionDetected = true;
                            motionTrips++;
                          Serial.print("Motion detected="); Serial.println(motionDetected);
                         * Sends state of motion sensor
                         * Parameters
                         * - force : Forces transmission of a value (even if it's the same as previous measurement)
                        void sendMotion(bool force) {
                          bool tx = force;
                          // Read digital motion value
                          bool tripped = digitalRead(MOTION_SENSOR) == HIGH;
                          Serial.print(F("Tripped: ")); Serial.println(tripped);
                          if (lastTripped != tripped) tx = true;
                          if (tx) {
                            resend(msg.set(tripped?"1":"0"),repeats);  // Send tripped value to gw
                            lastTripped = tripped;
                         * Sends temperature and humidity from HTU21D sensor
                         * Parameters
                        void sendTempHumidityMeasurement(bool force)
                            bool tx = force;
                            float hum = myHumidity.readHumidity();
                            float temp = myHumidity.readTemperature();
                            Serial.print(F("lastTemperature: ")); Serial.println(lastTemperature);
                            Serial.print(F("lastHumidity: ")); Serial.println(lastHumidity);
                            float diffTemp = abs(lastTemperature - temp);
                            float diffHum = abs(lastHumidity - hum);
                        #ifdef MY_DEBUG
                            Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                            Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                            if (isnan(diffHum)) tx = true;
                            if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                            if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
                            if (tx) {
                              resend(msgTemp.setSensor(TEMP_CHILD_ID).set(temp,1),repeats);
                              wait(20);
                              resend(msgHum.setSensor(HUM_CHILD_ID).set(hum,1),repeats);
                              lastTemperature = temp;
                              lastHumidity = hum;
                         * Sends light level from TLS6512 sensor
                         * Parameters
                        void sendLightLevelMeasurement(bool force) {
                          bool tx = force;
                          uint32_t lum = myLight.getFullLuminosity();
                          uint16_t ir, full;
                          ir = lum >> 16;
                          full = lum & 0xFFFF;
                          Serial.print(F("IR: ")); Serial.print(ir);   Serial.print(F("\t\t"));
                          Serial.print(F("Full: ")); Serial.print(full);   Serial.print(F("\t"));
                          Serial.print(F("Visible: ")); Serial.print(full - ir);   Serial.print(F("\t"));
                          double lux = myLight.calculateLux(full, ir);
                          Serial.print(F("Lux: ")); Serial.println(lux);
                          float diffLux = abs(lastLight - lux);
                        #ifdef MY_DEBUG
                            Serial.print(F("Lux difference since last measurement: ")); Serial.println((float)diffLux/abs(lastLight));
                            if (isnan(diffLux)) tx = true;
                            if (diffLux/abs(lastLight)  >= LIGHT_TRANSMIT_THRESHOLD) tx = true;
                            if (tx) {
                              resend(msgLight.setSensor(LIGHT_CHILD_ID).set(lux,1),repeats);
                              lastLight = lux;
                         * Prints error on I2C comm bus
                        void printError(byte error)
                          // If there's an I2C error, this function will
                          // print out an explanation.
                          Serial.print(F("I2C error: "));
                          Serial.print(error,DEC);
                          Serial.print(F(", "));
                          switch(error)
                            case 0:
                              Serial.println(F("success"));
                              break;
                            case 1:
                              Serial.println(F("data too long for transmit buffer"));
                              break;
                            case 2:
                              Serial.println(F("received NACK on address (disconnected?)"));
                              break;
                            case 3:
                              Serial.println(F("received NACK on data"));
                              break;
                            case 4:
                              Serial.println(F("other error"));
                              break;
                            default:
                              Serial.println(F("unknown error"));
                         * Sends battery information (battery percentage)
                         * Parameters
                        void sendBattLevel(bool force)
                          if (force) lastBattery = -1;
                          long batteryV =  analogRead(BATTERY_SENSE_PIN);
                          for (int i = 1; i<5; i++) {
                            long newSample = analogRead(BATTERY_SENSE_PIN); //readVcc();
                            batteryV -= batteryV / (i+1);
                            batteryV += newSample / (i+1);
                           // 10M, 2,86M divider across battery and using internal ADC ref of 1.1V
                           // ((10+4,7)/4,7)*1.1 = 3.4404255
                           // 3.4404255/1023 = Volts per bit = 0.003630748
                          long vcc  = batteryV * 3.3630748;
                          if (vcc != lastBattery) {
                            lastBattery = vcc;
                        #ifdef BATT_SENSOR
                            resend(msgBatt.set(vcc),repeats);
                            // Calculate on the fully charged cell. Since I have a step-up in place I go as low as possible no offset for minimum
                           sendBatteryLevel(  ((vcc-MIN_VOLTAGE)*10.0)/((MAX_VOLTAGE-MIN_VOLTAGE)*10.0) *100.0);
                         * Send message, resend on error
                         * Parameters
                         * - msg : message to send
                         * - repeats: number of repetitions
                        void resend(MyMessage &msg, int repeats)
                          int repeat = 0;
                          int repeatdelay = 0;
                          boolean sendOK = false;
                          while ((sendOK == false) and (repeat < repeats)) {
                            if (send(msg)) {
                              sendOK = true;
                            } else {
                              sendOK = false;
                              Serial.print(F("Send ERROR "));
                              Serial.println(repeat);
                              repeatdelay += random(50,200);
                            repeat++;
                            delay(repeatdelay);
                         * Internal battery ADC measuring
                        long readVcc() {
                          #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                            ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
                          #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                            ADMUX = _BV(MUX5) | _BV(MUX0);
                          #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                            ADcdMUX = _BV(MUX3) | _BV(MUX2);
                          #else
                          long result = (high<<8) | low;
                        HaakonH 1 Reply Last reply
                        • T tomkxy
                          Multisensor Sketch
                          Light           - TSL2561
                          Presence
                                              SDA    SCL
                          Mega2560, Due       20     21
                          Leonardo            2      3
                          #define BATT_SENSOR
                          #include <Wire.h>
                          // Pin definitions
                          // Global settings
                          int repeats = 2;
                          HTU21D myHumidity;
                          // Sensor messages
                          #ifdef BATT_SENSOR
                           * Setup code
                            Serial.flush();
                            // setup sensors
                            setup_htu21d();
                            delay(100);
                            setup_tls2561();
                            delay(500);
                          #ifdef BATT_SENSOR
                          #ifdef MY_DEBUG
                            Serial.flush();
                          /* Setup HTU21d
                            myHumidity.begin();
                          #ifdef MY_DEBUG
                          /* Setup TLS2561
                            } else {
                            tempMeasureCount++;
                            sendBattery++;
                                 sendBattery = 0;
                              wait(200);
                              wait(200);
                              wait(200);
                              motionTrips++;
                           * Parameters
                            bool tx = force;
                            if (tx) {
                           * Parameters
                              bool tx = force;
                          #ifdef MY_DEBUG
                              if (tx) {
                                wait(20);
                                lastHumidity = hum;
                           * Parameters
                            bool tx = force;
                            uint16_t ir, full;
                            ir = lum >> 16;
                          #ifdef MY_DEBUG
                              if (tx) {
                                lastLight = lux;
                            switch(error)
                              case 0:
                                break;
                              case 1:
                                break;
                              case 2:
                                break;
                              case 3:
                                break;
                              case 4:
                                break;
                              default:
                           * Parameters
                              lastBattery = vcc;
                          #ifdef BATT_SENSOR
                           * Parameters
                            int repeat = 0;
                              if (send(msg)) {
                                sendOK = true;
                              } else {
                                sendOK = false;
                              repeat++;
                              delay(repeatdelay);
                          long readVcc() {
                            #else
                          HaakonH
                          HaakonH
                          Haakon
                          Thanks, @tomkxy, fantastic! I will be trying it our shortly, as soon as I got those PIRs working on 3V.
                          • T
                            tomkxy
                            @Haakon Regarding the PIRs: There are a couple of postings in the Internet or I think even in this forum. For example, have a look here: http://randomnerdtutorials.com/modifying-cheap-pir-motion-sensor-to-work-at-3-3v/
                            L 1 Reply Last reply
                            • T tomkxy
                              L
                              L
                              LastSamurai
                              @tomkxy How did you power it though? I wanted to use a battery (or several ones) that might fall under 3.3V when used. So I decided to use a step-up converter but that seems to introduce too much noise, so I get false positives from the pir. From a stable 3.3V source it worked just fine.
                              • T
                                tomkxy
                                @LastSamurai I powered it through 3.3v step up with one AA battery. I cannot confirm that I get false positives.
                                martinhjelmareM L 2 Replies Last reply
                                • T tomkxy
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @tomkxy
                                  What range on the PIR do you get on 3.3 V?
                                  • T
                                    tomkxy
                                    Around 4 meters. However, this puppy is sitting in my entrance which is rather narrow.
                                    • T tomkxy
                                      L
                                      L
                                      LastSamurai
                                      Nice, what PIR and what step up did you use? Hopefully I can get the same ones too ;)
                                      • T
                                        tomkxy
                                        I used this one one which is rather expensive. I do not remember, however whether I bought really at Sparkfun or some other place. That were one of my first purchases when I started with all that crazy stuff :-)
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          wrote on last edited by Mark Swift
                                          Hi @tomkxy
                                          I'm going to add one of these sensors myself, looks like you've done the hard work...
                                          Could I ask what board you are using, perhaps a simple schematic too if you find a moment? I have a bunch of Nano's, some light sensors (BH1750) and temperature sensors (DS18B20's) - I presume I can swap over the code as required. Thankfully I also have a number of those exact step ups!
