  3. MySensors with Atmega8(L) ?
6 Posts 5 Posters 3.9k Views 3 Watching
  • J Offline
    J Offline
    joaopaulo
    Hi guys,
    I want to control two relays using MySensors and nRF24L01+. But I wanted to do that using a ATmega8(L), it has 8Kb of flash, instead a 32Kb from mega328 of arduino. Is that possible ?
    Thanks.
    • D Offline
      Dwalt
      wrote on last edited by Dwalt
      @joaopaulo
      There has been some success using the ATtiny85 which also has 8kbytes flash. Search the forum for ATtiny.
      • A Offline
        A Offline
        axillent
        wrote on last edited by axillent
        you will probably need to hack&cut a library to reduce a required flash
        I would recommend you to reconsider usage of atmega8, otherwise you will need to spend a lot of time to fit any upgrade
        I had such an experience. I was translating Mysensors to Atmel Studio and that allows me to fit sensors & clocks into atmega8.
        But as Mysensors is under fast development it became too complicated to follow.
        sense and drive
        J 1 Reply Last reply
        • A axillent
          J Offline
          J Offline
          joaopaulo
          @axillent Yeah, I was with this same intention to port MySensors to Atmel Studio and mega8. Anyway, I think it will be less complicated if i use the common mega328p as Arduino.
          • V Offline
            V Offline
            vikmad
            // EDIT and ADD in: ...Arduino\libraries\MySensors\drivers\AVR\DigitalIO\DigitalPin.h
                #if defined(__AVR_ATmega168__)\
                ||defined(__AVR_ATmega168P__)\
                ||defined(__AVR_ATmega8__)\
                ||defined(__AVR_ATmega328P__)
                // 168 and 328 Arduinos
            // EDIT and ADD IN: ...Arduino\libraries\MySensors\drivers\AVR\DigitalWriteFast\digitalWriteFast.h
             #elif defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_DUEMILANOVE) || defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega8__) || defined(__AVR_ATmega328PB__)
            // ADD to Sketch Code:
            //Name conversion R.Wiersma
            #define UCSR0A UCSRA
            #define UDR0 UDR
            #define UDRE0 UDRE
            #define RXC0 RXC
            #define FE0 FE
            #define TIFR1 TIFR
            #define WDTCSR WDTCR
            #define WDIE 6
            #define WDCE 4
            // DISABLE debug! small memory :(
            //#define MY_DEBUG
            I did not test on HW, I just tried to compile it (DimmableLEDActuator):
            • gregaouG Offline
              gregaouG Offline
              gregaou
              @vikmad
              Impressive, the same thing will work for an attiny84/85 ?
              12.2k
