  3. motion and relay
motion and relay
12 Posts 3 Posters 6.2k Views 3 Watching
  • D
    D
    dias
    hello, I am looking for a code used 2 motion sensors and 1 relay
    is that someone saw this forum? I have do a search but I found nothing
    • D
      D
      Dalhoj
      Hey maybe you can modify this sketch:
      http://forum.mysensors.org/topic/902/relay-motion-multisensor
      • D
        D
        dias
        I have modified the code, I have no error message but:
        the relay remains on position but n not appear in domoticz
        in the logs they have the same name
        dth11 the works
        #include <Wire.h>
        #include <DHT.h>
        #include <SimpleTimer.h>
        #define CHILD_ID_HUM 1
        #define CHILD_ID_TEMP 2
        #define CHILD_ID_MOTION 3
        #define CHILD_ID_RELAY 4
        #define RELAY  3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define HUMIDITY_SENSOR_DIGITAL_PIN 4
        #define MOTION_SENSOR_DIGITAL_PIN 5
        #define MOTION_SENSOR_DIGITAL_PIN2 6
        #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
        #define RELAY_ON 0  // GPIO value to write to turn on attached relay
        #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
        unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
        DHT dht;
        SimpleTimer timer;
        float lastTemp;
        float lastHum;
        boolean lastTripped;
        boolean lastTripped2;
        boolean metric = true;
        MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
          gw.sendSketchInfo("HumTempRelayMotion", "1.0");
          // REGISTER all sensors to gw (they will be created as child devices)
          gw.present(CHILD_ID_MOTION, S_MOTION);
          gw.present(CHILD_ID_RELAY, V_LIGHT);
          pinMode(RELAY, OUTPUT);
          digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
          //Serial.begin(9600);
          timer.setInterval(30000, getMeasure);
          gw.process();
          timer.run();
          boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
          if (tripped != lastTripped) {
            lastTripped = tripped;
            Serial.print("M: ");
            Serial.println(tripped);
            gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
          boolean tripped2 = digitalRead(MOTION_SENSOR_DIGITAL_PIN2) == HIGH;   //
          if (tripped2 != lastTripped2) {
            lastTripped2 = tripped2;
            Serial.print("M2: ");
            Serial.println(tripped2);
            gw.send(msg.set(tripped2?"1":"0"));  // Send tripped value to gw   //
          if (message.type==V_LIGHT) {
             // Change relay state
             digitalWrite(message.sensor-CHILD_ID_RELAY+RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
             // Store state in eeprom
             // Write some debug info
             Serial.print(message.sensor);
        void getMeasure() {
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            Serial.print("T: ");
            Serial.println(temperature);
          if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("H: ");
              Serial.println(humidity);
        Insert Code Here
        TheoLT 1 Reply Last reply
        • D dias
          dth11 the works
          #include <Wire.h>
          #include <DHT.h>
          DHT dht;
          SimpleTimer timer;
          float lastTemp;
          float lastHum;
            gw.process();
            timer.run();
          void getMeasure() {
              if (!metric) {
                lastHum = humidity;
          Insert Code Here
          TheoLT
          TheoLT
          TheoL
          wrote on last edited by TheoL
          @dias You're presenting the relay incorrect.
          this line in the setup
          needs to be
          gw.present(CHILD_ID_RELAY, S_LIGHT);
          And then you should see the sensor in Domoticz
          • D
            D
            dias
            the relay is present in domoticz but not the more it is driven on position when I connect the Arduino
            the motion sensor works well but they have the same name in domoticz so that I have one that appears
            • D dias
              TheoLT
              TheoLT
              TheoL
              @dias I'm sorry but I really don't understand what you mean. Try to insert some Serial.println("") and check the serial monitor. That way you can debug your sensor.
              • D
                D
                dias
                I use google translation
                the relay remains stuck on walk
                2 pir sensor works well but in domoticz with the same name
                • TheoLT
                  TheoLT
                  TheoL
                  I think this might cause your problem. It's in the incommingMessage method
                  I think you copied it from the multiple relays example.
                  try changing that code to
                       digitalWrite( RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
                  In your code, you are not writing the value to the pin you've assigned to the relay.
                  • D
                    D
                    dias
                    Thank you for your help
                    it works for relay and dth11
                    always the same pir sensors
                    • D
                      D
                      dias
                      on the picture have there a motion sensor that appears
                      • D
                        D
                        dias
                        wrote on last edited by dias
                        This post is deleted!
                        • D
                          D
                          dias
                          AC works thank you for your help
                          #include <Wire.h>
                          #include <DHT.h>
                          #define MOTION_SENSOR_DIGITAL_PIN 3
                          #define RELAY  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                          DHT dht;
                          SimpleTimer timer;
                          float lastTemp;
                          float lastHum;
                            gw.process();
                            timer.run();
                          void getMeasure() {
                              if (!metric) {
                                lastHum = humidity;
                          Insert Code Here
