  3. Enabling signing (Development branch)?
8 Posts 2 Posters 2.7k Views 1 Watching
  • T Offline
    T Offline
    tomkxy
    Driven by the latest patch with respect to repeater nodes in combination with signing I tried to move one of my nodes who is supposed to act as repeater to the latest version of the development branch.
    My nodes are using for signing the ATSHA204. The node I wanted to update since it is supposed to be a repeater worked before.
    After the upgrade it doesn't seem to sign messages anymore.
    Messages are sent out, but there is no nonce request sent out or anything related to the SHA204 protocol. The messages are received on the gateway, but but are reported "no sign".
    I inserted the define
    #define MY_SIGNING_ATSHA204
    It seems that is not sufficient. Any help is appreciated. Please find below the full sketch.
    IRSendActuator
    Author: Thomas Krebs, thkrebs@gmx.de
    This transforms the payload into IR signals for the supported IR receivers. Currently, only the Denon receiver on child id 1 is supported
    The expected payload format is:
      cmd1,cmd2[,repetition]
    cmd1 and cmd2 are tranformed into the proper Denon IR protocol
    The cmd1, cmd2 sequence will be sent consecutively <repetition> times. If not provided a default will be used.
    The IR led is to be connected on pin 3
    #define MY_REPEATER_FEATURE
    //#define MY_DEBUG_VERBOSE
    #include <IRLib.h>
    #include <avr/power.h>
    #include <dht.h>
    #define VERSION           "1.2"
    #define SKETCH_NAME       "IRSendActuator"
    //#define BAUD_RATE         115200
    // Pin definitions
    #define LED_PIN            4
    // The pin the ATSHA204 is connected on
    #define ATSHA204_PIN A3 // A3
    // TV Sense Pin
    #define LIGHT_SENSE_PIN  A0  // currently not in use
    // Temp Sensor pin
    #define DHTPIN         5
    // How many milli seconds between each measurement
    #define MEASURE_INTERVAL 120000
    // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
    #define FORCE_TRANSMIT_INTERVAL 30
    // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
    // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
    // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
    // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
    #define HUMI_TRANSMIT_THRESHOLD 1.0
    #define TEMP_TRANSMIT_THRESHOLD 0.5
    #define LIGHT_THRESHOLD         450   // threshold which determine ON or OFF state
    // Define a static node address, remove if you want auto address assignment
    #define MY_NODE_ID          24
    #define TEMP_CHILD_ID       1
    #define HUM_CHILD_ID        2
    #define IR_DENON_CHILD_ID   3
    #define IR_SAMSUNG_CHILD_ID 4
    #define LIGHT_CHILD_ID      5
    // Comment
    //#define DEBUG
    //#undef DEBUG
    // IR Sender
    IRsend mySender;
    int defaultRepeats  = 7;   // default value for repetitions send
    int delayBetweenSent= 20;  // delay between two send
    int khz=38; //NB Change this default value as neccessary to the correct carrier frequency
    char payload[64];
    // Temp Sensor
    dht DHT;
    int measureCount = 0;
    boolean isMetric = true;
    // Storage of old measurements
    float lastTemperature    = -100;
    float lastHumidity       = -100;
    int   last_light_status  = -1;
    unsigned long prevMillis = 0;
    // Sensor messages
    MyMessage msgTemp(TEMP_CHILD_ID,V_TEMP);
    MyMessage msgHum(HUM_CHILD_ID,V_HUM);
    MyMessage msgLight(LIGHT_CHILD_ID, V_STATUS);
      pinMode(LED_PIN, OUTPUT);
     blink(5,150,50);
      delay(500);
      Serial.print(F(SKETCH_NAME));
      Serial.println(VERSION);
      Serial.flush();
      delay(500);
      Serial.flush();
      Serial.println(F(" - Online!"));
      sendSketchInfo(SKETCH_NAME, VERSION);
      present(TEMP_CHILD_ID, S_TEMP);
      present(HUM_CHILD_ID, S_HUM);
      present(IR_DENON_CHILD_ID, S_IR);
    //  gw.present(LIGHT_CHILD_ID, S_BINARY);
      isMetric = getConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      delay(5000);
      sendTempHumidityMeasurements(false);
      bool forceTransmit = false;
      if (currentMillis - prevMillis > MEASURE_INTERVAL) {
        prevMillis = currentMillis;
        measureCount++;
        if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
          forceTransmit = true;
          measureCount = 0;
      // Light is checked in each loop; making sure we determine changes immediately
    //  sendLightStatus(forceTransmit);
      Serial.print(F("Received message of type: ")); Serial.println(message.type);
      Serial.print(F("Payload: ")); Serial.println(message.getString());
      blink(5,150,50);
      if (message.type==V_IR_SEND) {
        /* parse payload */
        strncpy(payload, message.getString(), sizeof(payload));
        payload[sizeof(payload)-1]=0;
        char *str, *p;
        unsigned long cmd1, cmd2;
        int repeats = -1;
        uint8_t i = 0;
        if (message.sensor == IR_DENON_CHILD_ID) {
          cmd1= strtoul(payload,&p,16);
          cmd2= strtoul(p,&p,16);
          repeats = atoi(p);
          if (repeats <= 0)  {
            repeats = defaultRepeats;
          Serial.print("cmd1: "); Serial.println(cmd1,HEX);
          Serial.print("cmd2: "); Serial.println(cmd2,HEX);
          Serial.print("repeats:"); Serial.println(repeats);
          for (int i=0; i<repeats; i++) { /* changed khz was 0 before */
              mySender.IRsendBase::sendGeneric(cmd1,15,0,0,275,275,1900,775,khz,true,46060);
              mySender.IRsendBase::sendGeneric(cmd2,15,0,0,275,275,1900,775,khz,true,46060);
              delay(20);
        else if (message.sensor == IR_SAMSUNG_CHILD_ID) {
          cmd1 = strtoul(payload,&p,16);
          repeats = atoi(p);
          if (repeats <= 0)  {
              mySender.IRsendBase::sendGeneric(cmd1,32,4500,4500,560,560,1690,560,khz,true,0);
              delay(20);
        else {
            blink(5,25,50);
    void blink(int nr, int high, int low) {
      for (int i=0; i<nr; i++) {
        digitalWrite(LED_PIN, HIGH);
        delay(high);
        digitalWrite(LED_PIN,LOW);
        delay(low);
     * Sends temperature and humidity from DHT sensor
     * Parameters
     * - force : Forces transmission of a value (even if it's the same as previous measurement)
    void sendTempHumidityMeasurements(bool force)
        bool tx = force;
        int ret = DHT.read22(DHTPIN);
        if (ret != DHTLIB_OK) {
          Serial.print(F("Error reading DHT22 :")); Serial.println(ret);
          return;
        float hum = DHT.humidity;
        float temp = DHT.temperature;
        Serial.print(F("lastTemperature: ")); Serial.println(lastTemperature);
        Serial.print(F("lastHumidity: ")); Serial.println(lastHumidity);
        float diffTemp = abs(lastTemperature - temp);
        float diffHum = abs(lastHumidity - hum);
        Serial.print(F("TempDiff :"));Serial.println(diffTemp);
        Serial.print(F("HumDiff  :"));Serial.println(diffHum);
        if (isnan(diffHum)) tx = true;
        if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
        if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
        if (tx) {
          measureCount = 0;
          Serial.print(F("Temperature: "));Serial.println(temp);
          Serial.print(F("Humidity: "));Serial.println(hum);
          send(msgTemp.setSensor(TEMP_CHILD_ID).set(temp,1));
          send(msgHum.setSensor(HUM_CHILD_ID).set(hum,1));
          lastTemperature = temp;
          lastHumidity = hum;
    void sendLightStatus(bool force)
      bool tx = force;
      int avg = 0;
      int level = 0; // I don't care about rounding errors
      int light_status;
      // Take 5 samples
      for (int i = 0; i < 5; i++) {
        level = analogRead(LIGHT_SENSE_PIN);
        avg = avg + (level - avg)/(i+1);
      light_status = (avg > LIGHT_THRESHOLD) ? 1 : 0;
      if (light_status != last_light_status) tx= true;
      Serial.print(F("Light Status: ")); Serial.print(level); Serial.print(F("/")); Serial.println(light_status);
      if (tx) {
        send(msgLight.setSensor(LIGHT_CHILD_ID).set(light_status,1));
        last_light_status = light_status;
    • hekH Online
      hekH Online
      @tomkxy
      Move the inclusion of MySensor.h below all MY_* defines.
      • T Offline
        T Offline
        tomkxy
        @hek: That's what I have. See attached sketch.
        • T Offline
          T Offline
          tomkxy
          @hek I just saw that there is a another define MY_SIGNING_FEATURE. I defined that as well. Now, I receive a compile error, see below:
          erwende die Bibliothek MySensors im Ordner: /Users/tom/Documents/Arduino/libraries/MySensors
          Verwende die Bibliothek IRLib im Ordner: /Users/tom/Documents/Arduino/libraries/IRLib (legacy)
          Verwende die Bibliothek SPI im Ordner: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
          Verwende die Bibliothek DHTlib im Ordner: /Users/tom/Documents/Arduino/libraries/DHTlib (legacy)
          /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Users/tom/Documents/Arduino/libraries/MySensors -I/Users/tom/Documents/Arduino/libraries/IRLib -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI -I/Users/tom/Documents/Arduino/libraries/DHTlib /var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build3975560794087132630.tmp/IRSendActuator.cpp -o /var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build3975560794087132630.tmp/IRSendActuator.cpp.o
          In file included from /Users/tom/Documents/Arduino/libraries/MySensors/MySensor.h:23:0,
                           from IRSendActuator.ino:24:
          /Users/tom/Documents/Arduino/libraries/MySensors/core/MySensorCore.h:28:27: fatal error: MySigningNone.h: No such file or directory
           #include "MySigningNone.h"
          compilation terminated.
          Fehler beim Kompilieren.```
          • hekH Online
            hekH Online
            The MY_SIGNING_FEATURE should be enabled automatically when when defining MY_SIGNING_ATSHA204
            https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.h#L74
            Does it work when disabling REPEATER-feature?
            • T Offline
              T Offline
              tomkxy
              @hek Disabling the REPEATER feature was one of the first things I tried. That does not work, either.
              But anyway, I cannot find the header file MySigningNone.h which the compiler tries to include.
              • hekH Online
                hekH Online
                Yes, the MySigningNone.h include shouldn't be there.
                Strange that SecureActuator example isn't failing when compiling.. need to investigate this a bit.
                • T Offline
                  T Offline
                  tomkxy
                  @hek I got it working after inserting the define
                  The same applies for soft signing which I tried as well.
                  For an actuator it makes sense only to process signed messages.
                  However, I thought that in general this feature was intended to be specified independently.
