  3. Domoticz
  4. NodeMcu Lua WiFi gateway with RFM69HW
6 Posts 2 Posters 3.4k Views 1 Watching
  • A Offline
    A Offline
    ansh
    wrote on last edited by ansh
    All I have done here
    Pin mapping:
    RFM69HW <-> ESP8266
    DIO0 <-> GPIO4
    SCK <-> GPIO14
    MOSI <-> GPIO13
    MISO <-> GPIO12
    CS <-> GPIO15
    I added only a single line (#define MY_RFM69_FREQUENCY RF69_433MHZ) and changed the IP, LED and Password
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    // Gateway mode always enabled for ESP8266. But we add this anyway ;)
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "mySSID"
    #define MY_ESP8266_PASSWORD "myPassword"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,0,198
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,8
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    void presentation() {
      // Send locally attech sensors data here
    upload-9385a23a-641c-4f5a-9095-6f7c666f1d44
    upload-cc2ea0a1-ef66-4ef7-b528-08d5b821368a
    The gateway is connected, but I can not add to the Domoticz. How can I check RFM69HW? I have a remote COCO AYCT-102.
    • S Offline
      It looks like your gateway is connected to Domoticz: "
      Gateway ready...
      Gateway version 1.6.0-beta
      What do you want to add?
      • A Offline
        A Offline
        ansh
        I want to add any 433Rya sensor. Or to start to see the code sent to the remote 433RYA COCO AYCT-102. But when you press the buttons on the remote nothing happens ... (
        2016-01-18 16:16:07.851 New sensors allowed for 5 minutes...
        2016-01-18 16:16:58.596 MySensors: Gateway Ready...
        • S Offline
          I dont know much about the 433mhz and RFM69HW. But the 433mhz specific codes isnt coded in the mysensors gw i think.
          If you want it to appear in Domoticz i think you need to bridge the gw to understand those codes and send it to Domoticz the right way.
          At this point MySensors only knows the MySensors codes.
          There are products that has do only this (433mhz + specidic codes). For Domoticz i use RFLink, but there is Telstick and RFXCom as well.
          • A Offline
            A Offline
            ansh
            Ok. Tanks
            So I will buy RFLink
            • S Offline
              @ansh it's the cheapest diy kit. I found it great and fun. If you want a more commercial product I think rfxcom is the biggest. Check so your 433mhz components are supported before you buy.
