Raspberry Pi2 GPIO interface for NRF24L01+
Sorry, had to re-save your project to get comments activated @GertSanders. It was published during forum downtime.
Cool
Is it possible this project act, as Ethernet Gateway ? And how to set?
@tiana this thread might be useful: http://forum.mysensors.org/topic/808/raspberry-pi-ethernet-gateway
Very nice, I wonder if you will be able to make an all in one "Openhab server, gateway, etc.." with the new raspberry pi 3.
@scooter217
Should be possible. The Mysensors gateway software on the Raspberry should run on the Zero and 3 as well. They all have the same GPIO pin layout.
The gateway software is independant of the controller. I use Domoticz, but you could use any controller on the raspi which supports serial mysensor gateway via a USB device.
Nice, i will try it soon. Just a thought, I am right now installing a raZberry zwave. The pins that feed your board with 5 volt, in my case it is better pointing up or have it on the downside of your board, otherwise the pins will touch raZberry board and is there other places to take 5 volt from RPi because raZberry is connect directly to pin 1-10? ahh
@flopp feeding the nrf with 5V is a bad idea. It wants 3.3V.
I was not clear enough. I have edit my text.
HI, in your list I read "IRQ 20". Don't need to be 18 instead? Thank you btw for the project. Just soldered and waiting for RPI3!
@sineverba @GertSanders sorry for quote, I did implement the IRQ on PI gateway on pin 18. Are you sure is it 20 as in description?
Of course I did print exactly your PCB and connected (with 5V with regulator and power from the 2x5V from PI) as described, but not the IRQ.
How could I test if IRQ is right and works?
Have a nice day!
irq=18 worked for me for anyone who comes along wondering
💬 Raspberry PI NRF24l01+ hat
OpenHardware.io • 20 May 2016, 13:52 • openhardware.io 14 Nov 2016, 09:35 -
Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
Hardware • 22 Nov 2015, 20:40 • mfalkvidd 10 Oct 2017, 19:43 -
nrf24 raspi gateway & controller
Troubleshooting • 20 Mar 2019, 00:43 • fipster 24 Mar 2019, 10:53 -
💬 air quality motherboard for sensor.community project
OpenHardware.io • 7 days ago • openhardware.io 7 days ago -
💬 In-wall scene controller OLED keypad
OpenHardware.io • 1 Jan 2018, 03:23 • openhardware.io 29 Feb 2024, 03:55
