  3. Gateway MQTTClient and Mosquitto debug
4 Posts 2 Posters 1.6k Views 2 Watching
  • AndrewZA
    AndrewZA
    AndrewZ
    Hello everyone!
    Just installed Mosquitto on RPi and I've adapted GatewayW5100MQTTClient example to use the ENC28J60 module I have. Should it work, BTW?
    Mosquitto seems to be working, but I cannot get any debug from it... So I'm curious how can I check that my Gateway is talking with Mosquitto?
    Thank you!
      We're using the pubsubclient library which doesn't support the ENC28J60 module according to the documentation
      https://github.com/knolleary/pubsubclient
      They instead they suggest using NanodeMQTT for the ENC-module
      https://github.com/njh/NanodeMQTT
      But I haven't tried it or adopted MySensors for using that library. Guess it would require some tweaking to get it in.
      AndrewZA 1 Reply Last reply
        AndrewZA
        AndrewZA
        AndrewZ
        @hek , thanks for that. I'll try again once I get another module.
        Andrew
        • AndrewZA
          AndrewZA
          AndrewZ
          wrote on last edited by AndrewZ
          I'm now using W5100 Ethernet, this is what I have on startup:
          0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
          0;255;3;0;9;Init complete, id=0, parent=0, distance=0
          0;255;3;0;9;MQTT connected
          With the following request I was able control my 1st relay:
          mygateway1-in/0/1/1/0/2 , value is either 0 or 1
          Seems to be working!
