  3. Reset problem with ethernet gateway and a sensor
1 Posts 1 Posters 1.4k Views 1 Watching
  • H
    H
    hyla
    posted that on Domoticz, too...
    Strange thing here: I've got a MySensors sensor here (some variety of a temperature-humidity sensor).
    Gateway I'm using is the ethernet version. Whenever I reset my sensor the ethernet gateway resets too:
    2016-02-27 10:14:12.664 MySensors: Connection reset!
    2016-02-27 10:14:12.665 TCP: Reconnecting in 30 seconds...
    2016-02-27 10:14:37.607 Hardware Monitor: Fetching data (System sensors)
    2016-02-27 10:14:42.669 TCP: Reconnecting...
    2016-02-27 10:14:42.669 MySensors: connected to: 192.168.2.155:5003
    2016-02-27 10:14:43.670 MySensors: Gateway Ready...
    2016-02-27 10:14:43.670 MySensors: Gateway Version: 1.5.1
    2016-02-27 10:14:44.672 MySensors: Gateway Version: 1.5.1
    Each and every time.
    In the WireShark protocol this is reported:
    27 20.628064000 8 0 mysensors 20 Cmd:PRESENTATION, ReqAck:0, IsAck:0, Type:ARDUINO_NODE, Sns:255, Data:'1.5' [STRING]
    28 20.635184000 8 0 mysensors 18 Cmd:INTERNAL, ReqAck:0, IsAck:0, Type:CONFIG, Sns:255, Data:0 [BYTE]
    29 21.662740000 0 8 mysensors 18 Cmd:INTERNAL, ReqAck:0, IsAck:0, Type:CONFIG, Sns:255, Data:'M' [STRING]
    33 22.656000000 8 0 mysensors 25 Cmd:INTERNAL, ReqAck:0, IsAck:0, Type:SKETCH_NAME, Sns:255, Data:'Humidity' [STRING]
    34 22.658412000 8 0 mysensors 25 Cmd:INTERNAL, ReqAck:0, IsAck:0, Type:SKETCH_NAME, Sns:255, Data:'Humidity' [STRING]
    35 22.666184000 8 0 mysensors 21 Cmd:INTERNAL, ReqAck:0, IsAck:0, Type:SKETCH_VERSION, Sns:255, Data:'1.02' [STRING]
    36 22.673444000 8 0 mysensors 17 Cmd:PRESENTATION, ReqAck:0, IsAck:0, Type:HUM, Sns:0
    37 22.675600000 8 0 mysensors 17 Cmd:PRESENTATION, ReqAck:0, IsAck:0, Type:HUM, Sns:0
    38 22.682072000 8 0 mysensors 17 Cmd:PRESENTATION, ReqAck:0, IsAck:0, Type:TEMP, Sns:1
    39 22.684236000 8 0 mysensors 17 Cmd:PRESENTATION, ReqAck:0, IsAck:0, Type:TEMP, Sns:1
    40 24.701744000 8 0 mysensors 22 Cmd:SET, ReqAck:0, IsAck:0, Type:TEMP, Sns:1, Data:1102105856,000000 [FLOAT32]
    41 24.709544000 8 0 mysensors 22 Cmd:SET, ReqAck:0, IsAck:0, Type:HUM, Sns:0, Data:1109970176,000000 [FLOAT32]
    So the gateway seems to answer once (29) and then it resets.
    So far this type of sensor is the only one who does this.
    I do have another practically identical sensor who has the same effect. Both have worked before.
    Although I might have changed something in between. Other sensors work flawlessly...
    Electrically sensor and gateway are completely separated (sensor driven on a battery, gateway feeds on a 2A wall wart).
    The sensor is not detected (anymore).
    This is what I get from the serial port when connecting to that:
    send: 8-8-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 8-8-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-8 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=8, parent=0, distance=1
    send: 8-8-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Humidity
    send: 8-8-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:1.02
    send: 8-8-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 8-8-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 8-8-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:22.2
    T: 22.20
    send: 8-8-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:41.8
    H: 41.80
    Any ideas?
    Thanks,
    Christoph
