  3. MysensorsInformation, a NRF24 sniffer in a webpage
3 Posts 2 Posters 2.4k Views 6 Watching
  • T
    timdows
    wrote on last edited by timdows
    Recently I've created the MysensorListener and I found that Ivo had created a nice sniffer that I wanted to use within this project as well.
    The sniffer project shows raw captured NRF24 packages, just like the version of Ivo, but uses a webpage for this instead of wireshark.
    The benefits of using a website vs the output to pipe - wireshark option is that I can now match the sender, destination and sensor information against my Vera3 environment, i.e., the information shown is more understandable for me as a human ^^
    An example of the output:
    Example output
    The project can be downloaded from github and can run without any dependencies on a Windows platform.
    For Linux and Mac you will need to install .NET runtime 1.0.0-rc1-update1
    https://docs.asp.net/en/latest/getting-started/installing-on-mac.html
    https://docs.asp.net/en/latest/getting-started/installing-on-linux.html
    The settings, like serial port name and speed, can be modified in the appsettings.json file located in approot\src\MysensorsInformation.
    Setup the Arduino with NRF24L01+ as explained on my blog Setting up the Arduino NRF24Sniffer (it is almost identical as Ivo's version except that I use text output)
    From the approot folder, run the web command (web.cmd on Windows and web on linux/mac) to fire-up the application.
    Browse to http://localhost:5000 and enjoy the information flying around your ears ^^
    Complete documentation and description can be found on my blog.
      Ver nice indeed! The blog address seems to be wrong (you might need to add a http:// on the .gl address).
      • T
        timdows
        Fixed the url, didnt check it after I posted it ^^
        If someone has information how it runs on a linux/mac, please let me know. As I'm not sure if the application would run with ttyUSB1 or something like that as the serial port name.
