  3. Domoticz
  4. Ethernet gateway and inclusion button not working
1 Posts 1 Posters 914 Views 1 Watching
  • T Offline
    T Offline
    TheoL
    So I've finally had the time, to build an Ethernet gateway. I just the Arduino Ethernet shield. I had an official Arduino laying around do nothing.
    Now everything works okay, except for the inclusion button. It's connected to pin 3. I measured the switch which works okay. According to the sketch it should print some debug info when pressed. But I don't see anything in the serial monitor. The led's are working okay. So I'm wondering if I missed a configuration setting.
    No I don't need the button at the moment. Because Domoticz doesn't support it. But I'm planning on making a wooden case so that it looks good in our living room. It's either that or removing the gateway to the basement ;-)
    Also another Domoticz specific question. What is the best migration plan, when going from a serial to a ethernet gateway? For sensors it isn't a back problem I can replace them with the ethernet variant. But for switches and lamps it looks like I have to check every scene and lua script that uses them.
    Help is greatly appreciated.
    12.2k
