  3. Buzzer when door opened longer than X seconds
3 Posts 2 Posters 2.0k Views 3 Watching
  • ChakkieC
    ChakkieC
    Chakkie
    wrote on last edited by Chakkie
    Hi All,
    I have got the buzzer module today and I want to use it on my exist frigde door contact sensor. What I want to do is when one of the fridge door is open more than 30 seconds the buzzer will turn on. And when door is closed the buzz stops.
    The full code is here below:
    #include <Bounce2.h>
    #define CHILD_ID_Koel 31
    #define CHILD_ID_Vries 32
    #define BUTTON_PIN_Koel  7  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_Vries  8  // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT BUTTON_PIN_Koel -2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define INTERRUPT BUTTON_PIN_Vries -2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define buzzPin 2 // I/O-pin from buzzer connects here
    Bounce debouncerKoel = Bounce();
    Bounce debouncerVries = Bounce();
    int oldValueKoel = -1;
    int oldValueVries = -1;
    int buzz = 0;
    unsigned long DoorDelay = 30000;
    unsigned long DoorMillis;
    MyMessage msgKoel(CHILD_ID_Koel, V_TRIPPED);
    MyMessage msgVries(CHILD_ID_Vries, V_TRIPPED);
      gw.begin(NULL, 204, false, 0);
      // Setup the button
      pinMode(BUTTON_PIN_Koel, INPUT);
      pinMode(BUTTON_PIN_Vries, INPUT);
      //Buzz pin
      pinMode(buzzPin, OUTPUT);
      digitalWrite(buzzPin, HIGH);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_Koel, HIGH);
      digitalWrite(BUTTON_PIN_Vries, HIGH);
      debouncerKoel.attach(BUTTON_PIN_Koel);
      debouncerVries.attach(BUTTON_PIN_Vries);
      debouncerKoel.interval(5);
      debouncerVries.interval(5);
      gw.present(CHILD_ID_Koel, S_DOOR);
      gw.present(CHILD_ID_Vries, S_DOOR);
      debouncerKoel.update();
      // Get the update value
      int valueKoel = debouncerKoel.read();
      if (valueKoel != oldValueKoel) {
        // Send in the new value
        gw.send(msgKoel.set(valueKoel == HIGH ? 0 : 1)); // change this value to if NC then 0 : 1; if NO then 1 : 0
        oldValueKoel = valueKoel;
      debouncerVries.update();
      int valueVries = debouncerVries.read();
      if (valueVries != oldValueVries) {
        gw.send(msgVries.set(valueVries == HIGH ? 0 : 1)); // change this value to if NC then 0 : 1; if NO then 1 : 0
        oldValueVries = valueVries;
        buzz = digitalRead(BUTTON_PIN_Vries);
        Serial.println(buzz);
        if (buzz == HIGH) {
          digitalWrite(buzzPin, buzz); // Tone OFF
          Serial.println("Buzzer off");
        if (buzz == LOW) {
          DoorMillis = millis();
          Serial.println("Counter start");
          Serial.println(DoorMillis);
        if ((millis() - DoorMillis) > DoorDelay) {
          digitalWrite(buzzPin, buzz); // Tone ON
          Serial.println("Buzzer triggerd");
      //  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      //  Serial.println("sleep");
    Below is part of the code where I tired to get the code work. I think I am doing something wrong.
        if (buzz == HIGH) {
        if (buzz == LOW) {
    Does anyone know how the code should look like
    Raspberry Pi 2
    Domoticz
    RFXCOM
    ZWAVE Aeon stick
    Coming soon Arduino mysensors GW
    • Boots33B
      Boots33B
      Boots33
      wrote on last edited by Boots33
      Hi
      I think your problem is where you have the code
      you have it nested inside the valueVries if statement which means it will only excecute when a change of state is detected. This means when the switch is first activated the timeout will not have expired and then it will not be retested until the switch state has changed, which will then have turned off.
      you need to move that code to the main loop so it is continually tested and try something like
      if ((millis() - DoorMillis) > DoorDelay && buzz == LOW) {
      ChakkieC 1 Reply Last reply
      • Boots33B Boots33
        Hi
        ChakkieC
        ChakkieC
        Chakkie
        @Boots33 Thanks for the help. The main problem was how to set the time when the doors are opened. I have tried several attempts and everytime the timer is reset. Therefore the buzzer will never be triggered because the timer and the current time is always the same.
        I have solved this problem. The working script is here below:
        unsigned long currentMillisKoel;
        unsigned long currentMillisVries;
        int KoelBuzz = 0;
        int VriesBuzz = 0;
        unsigned long DoorDelay = 5000UL;
        unsigned long KoelTimer = 0UL;
        unsigned long VriesTimer = 0UL;
          // Setup the button
          //Buzz pin
          // Fridge door script
            KoelBuzz = digitalRead(BUTTON_PIN_Koel);
            Serial.println(KoelBuzz);
            if (KoelBuzz == LOW) { //Door is open.
              KoelTimer = millis(); //  Set the time.
              Serial.println(KoelTimer);
          // check how long the doors are opened
          unsigned long currentMillisKoel = millis();
          if ((currentMillisKoel - KoelTimer) >= DoorDelay && KoelBuzz == LOW) {
        //    Serial.println("Counter start");
        //    Serial.println(KoelTimer);
        //    Serial.println(currentMillisKoel);
            digitalWrite(buzzPin, KoelBuzz); // Tone ON
        //    Serial.println("Buzzer triggerd");
        // Freezer door script
            VriesBuzz = digitalRead(BUTTON_PIN_Vries);
            Serial.println(VriesBuzz);
            if (VriesBuzz == LOW) { //Door is open.
              VriesTimer = millis(); //  Set the time.
              Serial.println(VriesTimer);
          if (VriesBuzz && KoelBuzz == HIGH) {
            digitalWrite(buzzPin, VriesBuzz); // Tone OFF
          unsigned long currentMillisVries = millis();
          if ((currentMillisVries - VriesTimer) >= DoorDelay && VriesBuzz == LOW) {
        //    Serial.println(VriesTimer);
        //    Serial.println(currentMillisVries);
            digitalWrite(buzzPin, VriesBuzz); // Tone ON
        Raspberry Pi 2
        Domoticz
        RFXCOM
        ZWAVE Aeon stick
