  3. [SOLVED] upgraded to Mysensors 2.0.0
working hardware2.0.0 upgrade
10 Posts 5 Posters 3.9k Views 4 Watching
  • Vincent GijsenV
    Vincent GijsenV
    Vincent Gijsen
    Hi Guys,
    Tried the new V2.0.0 (on actual-working hardware with V1.5), however the node and sensor won't talk to eachother, things i tried sofar:
    • adding hardcoded parent-ids'
    • changed the speed of the wireless modules (nrf24l01+)
    • added caps, cleared ..
    • With(out) inclusion mode
    • cleared both eeproms with example
    I cannot get my had arround it...
    the (example) code from my sensor:
     * Version 1.0 - Henrik Ekblad
    #define MY_REPEATER_FEATURE
    void before() {
        pinMode(pin, OUTPUT);
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    and the gateway:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_BUTTON_PIN  2
    #define MY_DEFAULT_ERR_LED_PIN 13  // Error led pin voor nanao!
    void presentation() {
    the logs (from the sensor), (which got it's node-id from earlier versions which wrote to eeprom:
    Starting repeater (RNNRA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=100)
    TSM:FPAR
    TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    goes on and on..
    the gateway is even more quite:
    (the last line is after toggleing the inclusion)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;5;1
    I'm just out of ideas now... also tried the dev-branch from git (as of 19-7-2016, 22:00)
    Any ideays how to get this gthing going?
    tekkaT 1 Reply Last reply
      Mrlynx
      I am also in the same process of upgrading my sensors and have also seen this behavior (not finding parent node).
      First I thought the radio was broken and changed radio. That got it going but the problem came back. Then I realised that problem comes from resetting the node and not turning power off completely. I had to disconnect my USB-serial adapter and power to make it work.
      http://www.sa2avr.se
      • Vincent GijsenV Vincent Gijsen
        Hi Guys,
        void before() {
        and the gateway:
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TSM:INIT
        TSM:RADIO:OK
        goes on and on..
        0;255;0;0;18;2.0.0
        0;255;3;0;5;1
        tekkaT
        tekkaT
        tekka
        To what did you change it?
        Can you confirm that you receive
        TSP:SANCHK:OK
        messages in in the GW debug log (in regular intervals)?
        Vincent GijsenV 1 Reply Last reply
        • tekkaT tekka
          TSP:SANCHK:OK
          Vincent GijsenV
          Vincent GijsenV
          Vincent Gijsen
          TSP:SANCHK:OK
          I changed it to 1 Mbps, using a define (as supposed for a nrf24l01 minus plus). however it didn't fix anything (and it worked on v1.5 beautifully.
          I did fail to mention that I use a Arduino Uno for the sensor and a nano for the gateway (don't think that matters, but who nows?)
          I do get occationally the TSP:SANCHK:OK on the gatway, so the radio is working (i guess), if I remove it's ground wire, it does register a failed radio
          • rollercontainerR
            rollercontainerR
            rollercontainer
            wrote on last edited by rollercontainer
            I had similar problems. With V1.5 normal nodes send data at a lower power level, only the gateway got full power. Now it seems to be set to high power even for nodes.[see answer below]
            Lowering the PA Power made my node send reliable again.
            • rollercontainerR rollercontainer
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @rollercontainer
              It's actually the opposite. In version 1.5 there are two separate nrf radio power settings, one for nodes set to max as default, and one for the gateway set to low as default.
              In 2.0 there's only one setting set to max as default but this is overridden to low in the gateway example sketches.
                @rollercontainer
                Vincent GijsenV
                Vincent GijsenV
                Vincent Gijsen
                Ok, tried the sugestions, but unfortunately, no communications :(
                HOWEVER , when i disconnect the gateway (so usb power physically removed ) and replug, it works! It has to e powercycled, not just reset!
                There is something weird going on when programming and resetting afterwards... very strange
                • Vincent GijsenV
                  Vincent GijsenV
                  Vincent Gijsen
                  MM
                  Ok, there is some very annoying issue. I need to poweroff all sensors. Then power-up the gateway, and connect the sensors. This works for some (limited) time. If i reset the gateway, the nodes can no longer (re)connect... so there is something weird going on.
                  • Vincent GijsenV
                    Vincent GijsenV
                    Vincent Gijsen
                    Ok, i was just blind..
                    I had my gateway wired differently (and compensated for it, in the transport init.. in my old 1.5.4 code.) Sorry guys!
                    After wielding the iron, it now works as supposed to be... damn arduino+nrf wiring diagrams, sometims they use pin 8 for ce, sometimes pin 9... something to keep in mind. Just strang that even with the faulti wired pin, it somhow works for a very breef moment...
                    • Vincent GijsenV
                      Vincent GijsenV
                      Vincent Gijsen
                      One very important note I would like to make:
                      the gateway must be CONNECTED to a serial device AND the port must be opened (e.g. arduino serial monitor or openhab) , for it to accept connections!!!!. Just powering it from an usb-hub makes it non-responsive to sensors... took some quite a lot of time to figure this out.
