  3. Hardware debouncing with 74HC14?
2 Posts 2 Posters 4.0k Views 4 Watching
  • TheoLT
    TheoLT
    TheoL
    wrote on last edited by TheoL
    I spend some time on hardware debouncing circuits. As far as I've read doing this with a schmitt trigger is supposed to be the best solution. For this I found this nice IC 74HC14. Which houses 6 schmitt triggers. Maybe there are better solutions, if so just let me no. I also would like to use a combined schmitt trigger opto coupler IC but wasn't able to find one with more than one channel.
    But it's more than enough for the project I want to use it for. I just want to be able to connect 5 binary inputs. I just want to get rid of the soft debounce. It uses memory and execution time. And for it's costs it's a great addition to my node here are 10 pieces at aliexpress
    Since I'm new to schmitt triggers I googled for an example. Would this do the trick? One capacitor and 6 resistors?!
    Example circuit
    Thanx in advance
    • T
      Toyman
      http://www.jeremyblum.com/2011/03/07/arduino-tutorial-10-interrupts-and-hardware-debouncing/
      I followed this tutorial and it works flawlessly
