  3. PiSerialGateway and Domoticz
15 Posts 3 Posters 3.8k Views 3 Watching
  • raptorjrR
    raptorjrR
    raptorjr
    So I'm trying to setup PiSerialGateway with a nrf24l01+. I'm getting some output but I don't understand it. If the sensors only scream out into the air or if they are communicating?
    I know that my sketch is working, because if I attach it to my Pi3 with USB cable as a ordinary SerialGateway my sensors appear in Domoticz.
    This it the output I have from my sketch with debug turned on. Don't know where it starts or ends so I just copy a few lines.
    TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSF:MSG:FPAR RES,ID=0,D=0
    TSF:MSG:FPAR OK,ID=0,D=1
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK,ID=1
    TSM:UPL
    TSF:PING:SEND,TO=0
    TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    TSF:CHKUPL:FAIL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK,ID=1
    TSM:UPL
    TSF:PING:SEND,TO=0
    TSF:CHKUPL:FAIL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK,ID=1
    TSM:UPL
    TSF:PING:SEND,TO=0
    TSF:CHKUPL:FAIL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK,ID=1
    TSM:UPL
    TSF:PING:SEND,TO=0
    And this is what the PiSerialGateway "says":
    read: 1-1-0 s=255,c=3,t=24,pt=1,l=1:1
    read: 1-1-255 s=255,c=3,t=7,pt=0,l=0:
    send: 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,st=ok:0
    I only had 470µF capacitor, don't know if it is too big and that could be a problem?
    Also, I don't know how to get a decent log file from PiSerialGateway? The only way I can get some output is to start it manually. I've been reading as much as I can find, but don't know how I can get this to work.
    • Fat FlyF
      Fat FlyF
      Fat Fly
      Try with 10µF capacitor. 470 is too big .
      • raptorjrR
        raptorjrR
        raptorjr
        wrote on last edited by raptorjr
        Thank you. Bought some 10µF.
        But I don't see any change in the output from the sensor or the gateway. Have been waiting 5-10 minutes, but nothing appears in Domoticz. Is there anything I can do to try to find the problem? I seem to get the output described on other webpages for working sensor/gateway. But they don't seem to connect.
        And how do I get the log function to work? The few times when a log is created I only see some startup message. Nothing about the communication going on. I have to start PiSerialGateway manually to see any communication output. Or isn't that possible to see in the log file?
        Here is the sensorsketch, if I have forgotten something. Works fine with plain USB connection to my Pi.
        // Enable serial gateway
        //#define MY_GATEWAY_SERIAL
        #include <OneWire.h>
        #define TEMP_ID 1
        #define RELAY_ID 2
        //Temperatur sensor
        #define ONE_WIRE_BUS 4
        #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
        float lastTemperature = 0;
        MyMessage tempMsg(TEMP_ID, V_TEMP); // Initialize temperature message
        DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
        unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
        //Relay to water valve
        #define RELAY_PIN  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        void setup(void)
        	// start serial port
        	Serial.begin(115200);
        	pinMode(RELAY_PIN, OUTPUT);
        	sendSketchInfo("FishTank", "1.0");
        	present(TEMP_ID, S_TEMP, "Water temperature");
        	present(RELAY_ID, S_BINARY, "Water valve");
        void loop(void)
        	DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
        	// For testing purposes, reset the bus every loop so we can see if any devices appear or fall off
        	sensors.begin();
        	sensors.requestTemperatures(); // Send the command to get temperatures
        	// Search the wire for address
           if(sensors.getAddress(tempDeviceAddress, 0))
        		float tempC = sensors.getTempC(tempDeviceAddress);
        		//Serial.print("Temperature=");
        		//Serial.println(tempC);
        #if COMPARE_TEMP == 1
        		if (lastTemperature != tempC && tempC != -127.00 && tempC != 85.00)
        #else
        		if (tempC != -127.00 && tempC != 85.00)
        			send(tempMsg.set(tempC, 1));
        			lastTemperature = tempC;
        	delay(SLEEP_TIME);
        	if (message.type == V_STATUS)
        		// Change relay state
        		digitalWrite(RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
        		// Write some debug info
        		Serial.print(message.sensor);
        • Fat FlyF
          Fat FlyF
          Fat Fly
          Connect gateway to comp usb and check what happening with arduino ide serial monitor.
          raptorjrR 1 Reply Last reply
          • Fat FlyF Fat Fly
            raptorjrR
            raptorjrR
            raptorjr
            @Fat-Fly
            I don't really understand. The gateway is on a Raspberry Pi, and I have a piece of what is happening in my first post. The output from PiSerialGateway. Otherwise you have to explain a little more on how I should connect my RPi to USB and what to look for.
            • Fat FlyF
              Fat FlyF
              Fat Fly
              Connect arduino with nrf to comp. Not raspberry. And check serial monitor.
              • Fat FlyF Fat Fly
                raptorjrR
                raptorjrR
                raptorjr
                @Fat-Fly
                But the NRF is connected directly to the Raspberry. There is no Arduino on the gateway. And the output from my node (Arduino and NRF) with sensors is also shown in my first post.
                I'm really lost on what you want me to test.
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  Okay. With mysensors 2.0 not working nrf directly. Use 1.5 library.
                  • Fat FlyF Fat Fly
                    raptorjrR
                    raptorjrR
                    raptorjr
                    @Fat-Fly
                    Really? They removed that or is it a bug? Didn't think that 2.0 would be a problem. But could test, but sad to not be able to use the latest version.
                    • raptorjrR raptorjr
                      @Fat-Fly
                      @raptorjr this thread discusses an alternative implementation of the Raspberry Pi gateway, compatible with MySensors 2.0.
                      • Fat FlyF
                        Fat FlyF
                        Fat Fly
                        2.0 is compatible connect nrf directly to raspberry? I do not know and not read this. Maybe i sleep this moment when somebody writing from this. :)
                          raptorjrR
                          raptorjrR
                          raptorjr
                          @mfalkvidd
                          Thank you, will check it out. Would be sad to leave 2.0. It seems to be a big step forward in the development.
                          • Fat FlyF
                            Fat FlyF
                            Fat Fly
                            :D :) :-)
                            • raptorjrR
                              raptorjrR
                              raptorjr
                              It works =)
                              • Fat FlyF
                                Fat FlyF
                                Fat Fly
                                Beer from you.
