  3. Help parsing a string to grab a value?
4 Posts 3 Posters 1.5k Views 3 Watching
  • T
    TommySharp
    Is anyone able to help me parse a string using arduino code that is getting returned by a IP based temperature sensor?
    I have a URL that I can call and this is what is returned...
    {"temp":19.3,"id":"373650"}
    I need to just grab the 19.3 so I can store it.....
    I appreciate I may not be asking in the best forum based on this not being specifically related to MySensors but any help would be appreciated.....
    • F
      F
      flopp
      wrote on last edited by flopp
      This may help you in the correct direction
      It is a LUA script that I run in Domoticz.
      commandArray = {}
          cmd = otherdevices_svalues["!!nodename!!"]
          local watt, energy, a, b
          print(cmd)
          _,_,watt, energy, a, b = string.find(cmd, "(.+):(.+):(.+):(.+)")
          print(watt)
          print(energy)
          print(a)
          print(b)
      return commandArray
      • T TommySharp
        @TommySharp you can use a json library. Example: https://github.com/bblanchon/ArduinoJson
        StaticJsonBuffer<200> jsonBuffer;
        JsonObject& root = jsonBuffer.parseObject(thetextfromurl);
        float temp          = root["temp"];
        • T
          TommySharp
          Thanks for your help guys! I got it resolved....
