  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 92.4k Views 37 Watching
    @sundberg84
    Instead of the 10k resistor, do you think I could use a potentiometer to "adjust" sensitivity? I would like to avoid messing up the readings with lights entering when opening the cabinet door where the meter is located
    @flopp
    Do you mind sharing your wiring? 940nm, isn't it infrared?
    @gohan - a potentiometer is just a variable resistor so why not? Good idea if you have one laying around.
    As i said before though, the try with the transistor is just a try - im not that good with transistors yet and dont know how they work exactly. After this i read somewhere that the base resistor should be bigger to protect the transistor... dont know how to calculate that.
      @sundberg84
      @flopp
      F
      F
      flopp
      wrote on last edited by flopp
      #62
      @gohan said in 💬 Power Meter Pulse Sensor:
      @sundberg84
      @flopp
      I connected the photo resistor directly to the LM393.
      I don't know if that is IR.
      • moumout31M
        moumout31M
        moumout31
        First, thanks for this tutorial !
        I used the code defined in tutorial but I have the following message for "void receive(const MyMessage &message)" :
        'MyMessage' does not name a type
        Do you know what can be the cause of this error please ?
        Thanks in advance for your help
        • moumout31M moumout31
          #64
          @moumout31 do you have void receive(const MyMessage &message) somewhere in your code or where does it come from?
          Could you post the full error message?
          Have you installed the MySensors library?
          moumout31M 1 Reply Last reply
            moumout31M
            moumout31M
            moumout31
            wrote on last edited by moumout31
            #65
            @mfalkvidd void receive(const MyMessage &message) is in the code.
            MySensors library is installed, I already use it in other nodes.
            It's strange because it works in another computer...
            The full error messages, in french beacause I'm french are :
            Arduino : 1.8.0 (Windows 7), Carte : "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
            _02_Main_loop:271: error: 'MyMessage' does not name a type
            In file included from C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/MySensors.h:257:0,
                             from C:\Users\Anne-Laure\Dropbox\Maison\A récupérer sur OneDrive\my_teleinfo_light\_02_Main_loop.ino:118:
            C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp: In function 'void transportProcessMessage()':
            C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp:745:14: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool'
               if (receive) {
            C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp:811:15: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool'
                if (receive) {
            exit status 1
            Bibliothèque non valide trouvée dans C:\Users\Anne-Laure\Documents\Arduino\libraries\MySensors : C:\Users\Anne-Laure\Documents\Arduino\libraries\MySensors
            Ce rapport pourrait être plus détaillé avec
            l'option "Afficher les résultats détaillés de la compilation"
            activée dans Fichier -> Préférences.
            Thanks for your help
                 if (receive) {
                  if (receive) {
              exit status 1
              @moumout31 My guess is that MyMessage is defined in your sketch, overriding the definition in the MySensors library. Could you post your sketch?
                moumout31M
                moumout31M
                moumout31
                @mfalkvidd It's strange... It works with an older version of Arduino software... Thus, the problem is solved ! Thanks
                • moumout31M
                  moumout31M
                  moumout31
                  I don't understand why, but my power meter sensor gives a higher index than the real power meter index after 2 days.
                  I think that it counts more pulses than pulses provided by the power meter...
                  Does anybody encounter this problem ?
                  Can it be cause to bounce for example ?
                  Thank you
                  gohanG F 2 Replies Last reply
                    Thank you
                    @moumout31
                    could it be getting some light from another source?
                      Thank you
                      F
                      F
                      flopp
                      @moumout31
                      I had same issue, check here for my solution
                      https://forum.mysensors.org/topic/4716/two-energy-meter/4
                      • Fat FlyF
                        Fat FlyF
                        Fat Fly
                        Hei.
                        How to connect arduino to electricity meter pulse out. Not to led.
                          @moumout31
                          moumout31M
                          moumout31M
                          moumout31
                          @gohan No, the light is always switched off in this room and I tried, when I switch on the light, there is no pulse from the sensor.
                          @flopp Thanks for your help. What I see in your topic is that you increase from 10000µs to 40000µs the interval to avoid corrupted interrupts, is that correct ?
                          Thank you
                          F 1 Reply Last reply
                            Thank you
                            F
                            F
                            flopp
                            @moumout31
                            Yes correct.
                            When I checked with Serial Monitor and some serial.print in different places I could see that arduino registered double interrupts
                            moumout31M 3 Replies Last reply
                            • F flopp
                              @moumout31
                              Yes correct.
                              moumout31M
                              moumout31M
                              moumout31
                              @flopp Thanks a lot, I will try this solution and check if it's better !
                              • F flopp
                                @moumout31
                                Yes correct.
                                moumout31M
                                moumout31M
                                moumout31
                                @flopp It seems to work, index on Domoticz is still consistent with the real index... I will see in a few days if it's still the case.
                                Thanks a lot for your help !
                                • F flopp
                                  @moumout31
                                  Yes correct.
                                  moumout31M
                                  moumout31M
                                  moumout31
                                  @flopp After a few days, I confirm you that the index is consistent with power meter index.
                                  However, instant power in watt is not correcly calculated.
                                  For example, when power meter indicates 550W, about 1500W is calculated by the sketch. Do you know how I can resolve this problem please ?
                                  Thanks a lot !
                                    Thanks a lot !
                                    F
                                    F
                                    flopp
                                    @moumout31
                                    Watt calculation is using time between two interrupts.
                                    How often do you send watt?
                                    Did you measure watt with a measurement tool How did you get 500 watts from power meter?
                                    When you send watt you need to measure exact same second otherwise it will not be correct.
                                    • F flopp
                                      @moumout31
                                      moumout31M
                                      moumout31M
                                      moumout31
                                      @flopp Watt is sent every 20 seconds (as done in the original sketch).
                                      500 watts is the power indicated on the screen of the power meter.
                                      • NiklasON
                                        NiklasON
                                        NiklasO
                                        wrote on last edited by NiklasO
                                        #79
                                        Just changed from 1-wire counter to MySensors for logging my power consumption. Using the same LED detector as I did when using 1-wire. Also changed watt limit to 20 000 (my heat pump likes to use 9-10kW sometimes). The wires from the old 1-wire net now provide power for the new MySensors-sensor. I have 10 000 led blinks per kWh. Had som crazy counter values with 1-wire that totally messed up the graphs and haven't seen anything like that with this sketch. Let's hope it stays that way. ;) Dumping data to Domoticz. This sensor gives me higher resolution as a bonus. The 1-wire counter was read every minute, this every 20-sec. ;-)
                                        My old 1-wire counter with one crazy value messing upp all the graphs:
                                        I know that you can hold shift and click the value that is crazy to make the graphs show up good but you loose the data for the full day. That's not good. ;-)
                                        henninneH 1 Reply Last reply
                                        • S
                                          Samuel235
                                          I seem to be getting a connection to my gateway, while monitoring the two topics for the gateway i only seem to see any activity regarding this sensor on the gateway-out topic, and it keeps sending out a type 2 message (req). The serial monitor of the sensors is showing:
                                          104198 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          114199 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          124200 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          134201 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          144202 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          154203 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          164204 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          174205 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          184206 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          194207 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          So it seems to be sending a request package, but i don't see it on the gateway-in topic and i see other sensors sending data to the gateway-in topic so i'm not subscribed to the wrong one. Is this a structural request message or is this the feature that requests the last known message from the gateway? Either way, there doesn't seem to be any sensor data being sent from the node to the gateway.
                                          MySensors 2.1.1
