  3. Motion controlled dimmable LED porch light
7 Posts 4 Posters 4.9k Views 4 Watching
  • pjblinkP
    pjblinkP
    pjblink
    Hi all,
    Just wanted to show you all my motion-activated LED Porch Light. Lots of 12v LED lights on here, not so many mains AC-powered bulb projects, so I thought I'd show you mine. Sketch is a standard motion sensor interrupt sketch alongside a dimming sketch, I'm sure I got it from the forums. Initially I wanted it to perform local control of the lamp via the PIR but then decided I wanted the light to come on low (33%) from dusk till dawn, and then raise to 100% when it detects motion. Because of that I've left the control logic to Vera. Below about 30% the bulb shows an obvious unstable flicker so I don't go there! Dimming and ramp up/down is beautifully smooth.
    It consists of:
    Arduino Nano
    NRF24L01 radio
    HLK-PM01 240v AC>5v DC
    HC-SR501 (PIR)
    240v AC Phase control dimming circuit: http://www.ebay.com/itm/111764492631
    4w dimmable filament LED bulb
    Wall box with blanking plate
    https://youtu.be/g7UY0zDP7zU
    sinczeS 1 Reply Last reply
    • pjblinkP pjblink
      Hi all,
      It consists of:
      Arduino Nano
      NRF24L01 radio
      HC-SR501 (PIR)
      sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      @pjblink thanks for sharing. This is exactly something I can use at my parents house. At the moment I use the security camera for motion detection ;-)
      • pjblinkP
        pjblinkP
        pjblink
        wrote on last edited by pjblink
        No problem, happy I could have been of some help!
        What's nice is that mysensors triggers so fast that it grabs a security cam image from before the camera has caught up!! Excuse the driveway...
        • 5546dug5
          5546dug5
          5546dug
          @pjblink what a great project perfect for my needs.
          Can you post the sketch please
          Thanks Doug
          pjblinkP 1 Reply Last reply
          • 5546dug5 5546dug
            Thanks Doug
            pjblinkP
            pjblinkP
            pjblink
            @5546dug Hi Doug,
            Here you go. Annoyingly my PIR seems to have died after a week or so. Hoping it's a faulty unit rather than anything to do with the circuit. I've ordered another, and will see how it holds up. It seems i can trigger it by touching the unit in places, but the PIR sensor itself is dead and not detecting anything.
            AC Light Control
            Uses up and down buttons to set levels
            makes use of a timer interrupt to set the level of dimming
            #include <TimerOne.h>
            #define SN "AC LED Porch Dimmer Control"
            #define SV "1.3"
            #define NODE_ID 30  //change to a number to assign a specific ID
            #define FADE_DELAY 20  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
            #define MOTION_CHILD 1  //ID of the motion sensor child
            #define MOTION_PIN  2  // Arduino pin tied to trigger pin on the motion sensor.
            volatile int i=0;               // Variable to use as a counter of dimming steps. It is volatile since it is passed between interrupts
            volatile boolean zero_cross=0;  // Flag to indicate we have crossed zero
            int AC_pin = 7;                 // Output to Opto Triac
            int freqStep = 75;              // This is the delay-per-brightness step in microseconds. It allows for 128 steps
                                            // If using 60 Hz grid frequency set this to 65
            //dimming
            static int currentLevel = 128;  // Current dim level...
            uint8_t fadeLevel = 128; //used to store the fade level when using the buttons
            //motion sensor
            uint8_t lastMotion = 0;
            unsigned long previousMillis = 0; // last time update //see http://stackoverflow.com/questions/10773425/performing-a-function-after-x-time for more details on this
            unsigned long motionDelay = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
            boolean metric = true;
            MyMessage dimmerMsg(AC_pin, V_DIMMER);
            MyMessage lightMsg(AC_pin, V_LIGHT);
            MyMessage motionMsg(MOTION_CHILD, V_TRIPPED);
            void setup() {  // Begin setup
              Serial.begin(115200);
              Serial.println( SN );
              gw.begin( incomingMessage,  NODE_ID, true);
              gw.present( 6, S_DIMMER );
              gw.sendSketchInfo(SN, SV);
              // Pull the gateway's current dim level - restore light level upon sendor node power-up
              gw.request( 6, V_DIMMER );
              gw.present(MOTION_CHILD, S_MOTION);
              //Setup AC PIN
              pinMode(AC_pin, OUTPUT);                          // Set the Triac pin as output
              attachInterrupt(1, zero_cross_detect, RISING);    // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
              Timer1.initialize(freqStep);                      // Initialize TimerOne library for the freq we need
              Timer1.attachInterrupt(dim_check, freqStep);      // Go to dim_check procedure every 75 uS (50Hz)  or 65 uS (60Hz)
              // Use the TimerOne Library to attach an interrupt
            void zero_cross_detect() {
              zero_cross = true;               // set flag for dim_check function that a zero cross has occured
              i=0;                             // stepcounter to 0.... as we start a new cycle
              digitalWrite(AC_pin, LOW);
            // Turn on the TRIAC at the appropriate time
            // We arrive here every 75 (65) uS
            // First check if a flag has been set
            // Then check if the counter 'i' has reached the dimming level
            // if so.... switch on the TRIAC and reset the counter
            void dim_check() {
              if(zero_cross == true) {
                if(i>=fadeLevel) {
                  digitalWrite(AC_pin, HIGH);  // turn on light
                  i=0;  // reset time step counter
                  zero_cross=false;    // reset zero cross detection flag
                else {
                  i++;  // increment time step counter
                gw.process();
              //motion sensor code
                 if(currentMillis - previousMillis > motionDelay){
                  uint8_t motionDetect = digitalRead(MOTION_PIN);
                    if(motionDetect != lastMotion){
            //        Serial.print("motionDetect Value: ");
            //        Serial.println(motionDetect);
                      gw.send(motionMsg.set(motionDetect));  // Send tripped value to gw
                      if(motionDetect == 1){
                      previousMillis = currentMillis;  //"Tripped" delay
                      else{
                      previousMillis = currentMillis - motionDelay + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
                  lastMotion = motionDetect;
              if (message.type == V_LIGHT || message.type == V_DIMMER) {
                requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
                // Clip incoming level to valid range of 0 to 100
                float percent_level;
                percent_level = 128 - (requestedLevel * 1.28);
                fadeToLevel( percent_level );
                Serial.print( "Changing level to " );
                Serial.print( ", from " );
                Serial.println( currentLevel );
                //gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
                // hek comment: Is this really nessesary?
                // gw.send( dimmerMsg.set(requestedLevel) );
             *  This method provides a graceful fade up/down effect
            void fadeToLevel( int toLevel ) {
             Serial.print("currentLevel Value: ");
             Serial.println(currentLevel);
             Serial.print("toLevel Value: ");
             Serial.println(toLevel);
              int delta = ( currentLevel - toLevel ) < 0 ? 1 : -1;
              Serial.print("delta Value: ");
             Serial.println(delta);
              while ( currentLevel != toLevel ) {
                currentLevel += delta;
             fadeLevel= ((int)currentLevel);
                delay( FADE_DELAY );
                //fadeLevel = toLevel;
            • 5546dug5
              5546dug5
              5546dug
              thanks @pjblink , I get lots of errors just wondering before I do anything, was this sketch wrote for 1.5or 2.0?
              this is probably my issue as I still run 1.4.1
              but thought I would run it past you first.
              thx doug
              • K
                K
                koen01
                @pjblink :
                Did you use any fuses between the 240v and the 220 > 5v module?
                Could you post a picture of the backside of your perfboard? I'm interested in how you wired everything up :)
