  3. [SOLVED] Radio Traffic leds on Repeater?
6 Posts 3 Posters 2.0k Views 3 Watching
  • YFandSY
    YFandSY
    YFandS
    On the Advanced Gateway Options page it says that you can add radio traffic leds.
    I read somewhere(?) that it is for the gateway and sensors but no mention of the repeater.
    but my question, I'm in the process of hooking up a repeater, which works great by the way,
    except for the traffic leds. Is it possible to add radio traffic leds to the repeater ?
    here is the code part I copied from the Advanced Gateway Options page and added to the repeaternote.ino sketch. And of course made sure to follow the connection instructions.
    Even reversed the whole so the leds stay on and should go off in case of transmission or error but neither versions work.
    • REVISION HISTORY
    • Version 1.0 - Henrik Ekblad
    • DESCRIPTION
    • Example sketch showing how to create a node that repeates messages
    • from nodes far from gateway back to gateway.
    • It is important that nodes that has enabled repeater mode calls
    • process() frequently. Repeaters should never sleep.
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period (in milliseconds)
    #define MY_DEFAULT_ERR_LED_PIN 4
    #define MY_DEFAULT_TX_LED_PIN 5
    #define MY_DEFAULT_RX_LED_PIN 6
    etc.
    If someone can acknowledge the possibility of adding leds to the repeater i would be grateful. If yes why don't they work ?
    Regards
    Frank
      Yes, you can activate traffic leds on any node type.
      YFandSY 1 Reply Last reply
        YFandSY
        YFandSY
        YFandS
        @hek
        Thanks for the confirmation, also an idea why it may not work ?
        I followed the connections and added the code.. ?!
        regards
        Frank
          You you're running the dev-branch, it should be enough to define the pins.. The feature-define is no longer needed.
          https://github.com/mysensors/MySensors/blob/80659ddb00b4811f8e6f9d90221ec796722b79b5/MySensors.h#L106
          • G
            G
            Ghydda
            I can confirm YFandS's findings.
            My node running in repeater mode does not flash the RX/TX/ERR leds.
            The same node running a gateway sketch happily flashes the LED's.
            Cheers.
            /Ghydda
            G 1 Reply Last reply
            • G Ghydda
              Cheers.
              /Ghydda
              G
              G
              Ghydda
              Well it came to me. Rookie mistake.
              The defines for my alternate LED port pins was listed below the MySensors.h include statement and not above it.
              Once I corrected this error, my traffic LED's blink happily.
