  3. which modules to use for 434/868 mHz
6 Posts 2 Posters 2.0k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    wrote on last edited by A Former User
    I am trying to understand which module i can use to control lights and to monitor sensor data which are working on 434/868mHz.
    I tried nrf905, cc1101, but cannot find working code.
    Do you have/know some modules that can be controlled via python?
    also is it possible to connect 2.4 ghz module and 434/868mhz module at once on raspberry pi.
    i want to create one server supporting all frequency for iot modules.
    • ? A Former User
      @Vasil-Vasilev welcome to the MySensors community!
      You can use rfm69, see https://www.mysensors.org/build/connect_radio#wiring-the-rfm69-radio
      Could you explain what you mean by controlling through python? I'm not sure how that makes sense in a MySensors context.
      • ? Offline
        ? Offline
        A Former User
        thanks. but i need modules for raspberry pi.
        i want to create my own solution and cannot find suitable hardware.
        • ? A Former User
          @Vasil-Vasilev ok. Then MySensors might not be the right project for you. But maybe you can reuse some of the Raspberry Pi gateway code/ideas. it has support for RFM69.
          • ? Offline
            ? Offline
            A Former User
            thanks for replying,
            i just want to know what i am doing.
            normally if i download some code, i have to read it from beginning and to understand what it is doing, so i can improve it in future.
            and everybody know that this is impossible with other code that is 2000 files with 100000 lines of code :)
            it is like my hobby but for me it is interesting.
            I like your project also and know that there are many people that know what they are doing here that is why i wrote a post.
            I have tried many modules - maybe 20 from amazon and gave back because didnt worked and dont want to give up..
            now i understand that this module RFM69 is working only on one band not both.
            • ? A Former User
              @Vasil-Vasilev yes, you need to select which frequency (433 or 868 MHz) when you buy the radio module.
              11.8k
              113.2k
