  3. [SOLVED] Node sending many messages
6 Posts 3 Posters 1.9k Views 3 Watching
  • J
    J
    jeti
    Hi
    i have combined IR Sending with a SI7021 temperature & humidity sensor.
    As i am still new to Mysensors and Arduino i have tweaked to send the temp & humidity once every minute but accept IR orders every 250ms which works fine. My sketch looks like this:
    // Enable debug prints
    #define MY_NODE_ID 112
    #include <IRLib.h>
    #include "Adafruit_Si7021.h"
    #include <Wire.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_IR  2  // childId
    int counter = 0;
    Adafruit_Si7021 sensor = Adafruit_Si7021();
    IRsend irsend;
    MyMessage msgIR(CHILD_ID_IR, V_VAR1);
    MyMessage msgT(CHILD_ID_TEMP, V_TEMP);
    MyMessage msgH(CHILD_ID_HUM, V_HUM);
    void presentation()  {
      sendSketchInfo("IR Sender & Temp Hum", "1.0");
      // Register a sensors to  Use binary light for test purposes.
      present(CHILD_ID_IR, S_LIGHT);
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_TEMP,S_TEMP);
      delay(500); // Allow time for radio if power useed as reset
       sensor.begin();
    smartSleep(250); // adjust sleeping time here 250ms in this case
       ServerUpdate();
       counter ++;
      if (message.type==V_LIGHT) {
         int incomingRelayStatus = message.getInt();
         if (incomingRelayStatus == 1) {
          irsend.send(NEC, 0x10C8E11E, 32); // acer Beamer Power
         } else {
          wait(1000); // Pause zwische zwei mal ausschalten
    void ServerUpdate() // used to read sensor data and send it to controller
      double T, H;
      T=sensor.readTemperature();
      H=sensor.readHumidity();
      if (counter >= 240){ // 240*250ms = 1minute
          send(msgT.set(T,1));
          send(msgH.set(H,1));
          counter = 0;
       // unmark for debuging
        //  Serial.print("T = \t"); Serial.print(T, 1); Serial.print(" degC\t");
        //  Serial.print("H = \t"); Serial.print(H, 1); Serial.println(" %\t");
    It works like it should :smiley: but in debugging mode I see that it seems to send a lot of messages like this:
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:251177
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:251739
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:252301
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:252862
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:253424
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:253984
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:254544
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:255106
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:255670
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:256231
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:256791
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:257351
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:257913
    TSP:MSG:SEND 112-112-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:258473
    so i guess it is spaming my setup, or does it?
    It would be greate to understand why these messages are sent and how to avoid this.
    and once every minute:
    TSP:MSG:SEND 112-112-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:23.1
    TSP:MSG:SEND 112-112-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:59.2
    which is fine
    thanks in advance
    Boots33B 1 Reply Last reply
    • J jeti
      Hi
      #include <IRLib.h>
      #include <Wire.h>
      int counter = 0;
      IRsend irsend;
         sensor.begin();
         ServerUpdate();
         counter ++;
           } else {
        double T, H;
            counter = 0;
      which is fine
      thanks in advance
      Boots33B
      Boots33B
      Boots33
      @jeti I think they may be the heartbeat messages from smartsleep
      • J
        J
        jeti
        ah ok, so it is generating traffic which is not needed. Is there a way of smart-sleeping without the hearteat? normal sleep does not work with the recieving part of the sketch...
        • J jeti
          @jeti without the heartbeat the controller wouldn't know when the node is awake, so the controller wouldn't know when to send the message.
          J 1 Reply Last reply
            J
            J
            jeti
            @mfalkvidd : ok thanks i think i got it now.
            As i only want to send the temperature and humidity once every x seconds/minutes, but the IR must be always ready for receiving/sending i can not use sleep (otherwise the sensor only sends when the nod is awake.
            I have now used
            wait
            which does the trick :smiley: : So temp and hum only every minute but IR signals whenever i want. Is "wait" the right tool here or a band aid?
            thanks!
            • J jeti
              I have now used
              wait
              thanks!
              @jeti wait is the correct solution.
