  3. PiDome
  4. PiDome - Waiting for gateway
Scheduled Pinned Locked Moved PiDome
5 Posts 2 Posters 3.6k Views 2 Watching
  • E
    E
    esawyja
    Hi all
    I have a Raspberry Pi 3 running the PiDome Controller and the Raspberry Pi Serial gateway as per https://www.mysensors.org/build/raspberry
    My configuration for the Serial gateway is as follow
    root@mmm_gateway:~# cd /opt/temp/mmm_gateway/MySensors/examples_linux/
    root@mmm_gateway:/opt/temp/mmm_gateway/MySensors/examples_linux# cat mysGateway.cpp
    #include <iostream>
    #include <cstdio>
    #include <unistd.h>
    // For more options run ./configure --help
    // Config file
    //#define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
    #define MY_GATEWAY_MAX_CLIENTS 10
    // Serial config
    // Enable this if you are using an Arduino connected to the USB
    //#define MY_LINUX_SERIAL_PORT "/dev/ttyACM0"
    // Enable this if you need to connect to a controller running on the same device
    #define MY_IS_SERIAL_PTY
    // Choose a symlink name for the PTY device
    #define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
    //MySensorsGateway
    // Grant access to the specified system group for the serial device
    #define MY_LINUX_SERIAL_GROUPNAME "tty"
    // MQTT options
    //#define MY_PORT 1883
    //#define MY_MQTT_CLIENT_ID "mysensors-1"
    //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
    //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 12  // Error LED pin
    #define MY_DEFAULT_RX_LED_PIN  16  // Receive LED pin
    #define MY_DEFAULT_TX_LED_PIN  18  // Transmit LED pin
    // Inverse the blinking feature
    // Enable software signing
    //#define MY_SIGNING_SOFT
    // Enable signing related debug
    //#define MY_DEBUG_VERBOSE_SIGNING
    // Enable this to request signatures from nodes that in turn request signatures from gateway
    //#define MY_SIGNING_REQUEST_SIGNATURES
    // Enable this to have gateway require all nodes in the network to sign messages sent to it
    // Note: MY_SIGNING_REQUEST_SIGNATURES must also be set
    //#define MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL
    void presentation() {
    I start the Serial Gateway as follow and it starts successfully
    root@mmm_gateway:/opt/temp/mmm_gateway/MySensors/examples_linux# ./mysGateway -d
    mysGateway: Starting gateway...
    mysGateway: Protocol version - 2.0.1-beta
    mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
    mysGateway: TSF:LRT:OK
    mysGateway: TSM:INIT
    mysGateway: TSM:INIT:TSP OK
    mysGateway: TSM:INIT:GW MODE
    mysGateway: TSM:READY
    mysGateway: MCO:REG:NOT NEEDED
    mysGateway: MCO:BGN:STP
    mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    mysGateway: TSF:MSG:READ,120-120-0,s=1,c=1,t=0,pt=7,l=5,sg=0:26.2
    mysGateway: TSF:MSG:READ,120-120-0,s=2,c=1,t=1,pt=2,l=2,sg=0:38
    mysGateway: TSF:MSG:READ,120-120-0,s=255,c=3,t=0,pt=1,l=1,sg=0:29
    As you can see there is a temperature sensor on a SenseBender
    The /dev/tty device starts up as well and I can see some information in the file
    ^Cpi@mmm_gateway:~ $ sudo tail -f /dev/ttyMySensorsGateway
    0;255;0;0;18;2.0.1-beta
    120;1;1;0;0;26.2
    120;2;1;0;1;38
    120;255;3;0;0;29
    120;1;1;0;0;26.2
    120;2;1;0;1;38
    120;1;1;0;0;26.1
    120;2;1;0;1;38
    120;255;3;0;0;29
    106;255;3;0;0;86
    106;255;4;0;0;FFFFFFFFFFFFFFFF0300
    106;255;0;0;17;2.0.0
    106;255;3;0;11;Sensebender Micro
    106;255;3;0;12;1.4
    106;1;0;0;6;
    106;2;0;0;7;
    120;255;3;0;0;25
    120;255;4;0;0;FFFFFFFFFFFFFFFF0300
    120;255;0;0;17;2.0.0
    120;255;3;0;6;0
    120;255;3;0;11;Sensebender Micro
    120;255;3;0;12;1.4
    120;1;0;0;6;
    120;2;0;0;7;
    The PiDome installation seem to be ok as well, I can stop and start it
    pi@mmm_gateway:~ $ sudo systemctl status pidome-server.service
    ● pidome-server.service - LSB: PiDome Home Automation/Domotica server.
       Loaded: loaded (/etc/init.d/pidome-server)
       Active: active (running) since Sun 2016-11-13 12:09:45 SAST; 9min ago
      Process: 2809 ExecStart=/etc/init.d/pidome-server start (code=exited, status=0/SUCCESS)
       CGroup: /system.slice/pidome-server.service
               ├─ 717 /opt/pidome/pidome-server/jre/bin/java -Xbootclasspath/p:libs/alpn-boot-8.1.7.v20160121.jar -XshowSettings:properties -Dlog4j.configurationFile=config/log4j2.xml -Djava.awt.headless=true -Dfile.encoding=UTF-8 -jar pidome-server.jar
               └─2815 /opt/pidome/pidome-server/jre/bin/java -Xbootclasspath/p:libs/alpn-boot-8.1.7.v20160121.jar -XshowSettings:properties -Dlog4j.configurationFile=config/log4j2.xml -Djava.awt.headless=true -Dfile.encoding=UTF-8 -jar pidome-server.jar
    Nov 13 12:09:45 mmm_gateway pidome-server[2809]: Initializing PiDome server, please wait for server start........ starting up.
    Nov 13 12:09:45 mmm_gateway systemd[1]: Started LSB: PiDome Home Automation/Domotica server..
    pi@mmm_gateway:~ $ sudo systemctl stop pidome-server.service
       Active: inactive (dead) since Sun 2016-11-13 12:19:30 SAST; 4s ago
      Process: 4338 ExecStop=/etc/init.d/pidome-server stop (code=exited, status=0/SUCCESS)
    Nov 13 12:19:30 mmm_gateway systemd[1]: Stopping LSB: PiDome Home Automation/Domotica server....
    Nov 13 12:19:30 mmm_gateway pidome-server[4338]: Stopping PiDome server, please wait... removing PID file /var/run/pidome.pid, done.
    Nov 13 12:19:30 mmm_gateway systemd[1]: Stopped LSB: PiDome Home Automation/Domotica server..
    pi@mmm_gateway:~ $ sudo systemctl start pidome-server.service
       Active: active (running) since Sun 2016-11-13 12:19:46 SAST; 1s ago
      Process: 4372 ExecStart=/etc/init.d/pidome-server start (code=exited, status=0/SUCCESS)
               └─4378 /opt/pidome/pidome-server/jre/bin/java -Xbootclasspath/p:libs/alpn-boot-8.1.7.v20160121.jar -XshowSettings:properties -Dlog4j.configurationFile=config/log4j2.xml -Djava.awt.headless=true -Dfile.encoding=UTF-8 -jar pidome-server.jar
    Nov 13 12:19:46 mmm_gateway pidome-server[4372]: Initializing PiDome server, please wait for server start........ starting up.
    Nov 13 12:19:46 mmm_gateway systemd[1]: Started LSB: PiDome Home Automation/Domotica server..
    pi@mmm_gateway:~ $
    I've defined the custom port, see image
    But the driver just says waiting for gateway, never changes
    Even when I turn on the device discovery and cycle the SenseBenders, nothing happens
    I really like the PiDome interface, but there does not seem to be a lot of information on it, and hence very difficult to troubleshoot, does anyone have an idea on how to fix this please
    Regards
    • E
      E
      esawyja
      Some errors in the logfile on the PiDome that I do not have a clue what they are about
      root@mmm_gateway:/opt/pidome/pidome-server/logs/system# tail -f appLog.txt
      	2016-11-13 12:24:40,368 [main] WARN  org.pidome.server.PiDomeServerBoot - Running server with security manager disabled. This is the case as long the server is in alpha state.
      2016-11-13 12:24:40,386 [main] WARN  org.pidome.server.PiDomeServerBoot - There is no default locale present in the config file, will default to: en_GB
      2016-11-13 12:24:40,387 [main] INFO  org.pidome.server.PiDomeServerBoot - Starting server with build: 0.1-SNAPSHOT-2016-09-22.698 on platform: Linux (arm)
      2016-11-13 12:24:40,507 [main] INFO  com.zaxxer.hikari.HikariDataSource - DBConnectionPool_PiDomeServer - is starting.
      2016-11-13 12:24:42,455 [main] INFO  org.pidome.misc.utils.TimeUtils - Setting timezone data: Europe/Amsterdam, 51.950000, 4.449999
      2016-11-13 12:24:42,575 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Initializing RPC
      2016-11-13 12:24:42,897 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: PackageService
      2016-11-13 12:24:42,964 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: DashboardService
      2016-11-13 12:24:42,966 [main] ERROR org.pidome.server.services.http.rpc.PidomeJSONRPC - RPC namespace 'JSONService' has been misconfigured!
      2016-11-13 12:24:42,967 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: JSONService
      2016-11-13 12:24:42,995 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: DataModifierService
      2016-11-13 12:24:43,081 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: LocationService
      2016-11-13 12:24:43,122 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: MessengerService
      2016-11-13 12:24:43,170 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: WeatherService
      2016-11-13 12:24:43,222 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: RemotesService
      2016-11-13 12:24:43,281 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: CategoryService
      2016-11-13 12:24:43,320 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: HardwareService
      2016-11-13 12:24:43,355 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: AccessControllerService
      2016-11-13 12:24:43,442 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: ClientService
      2016-11-13 12:24:43,518 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: UserService
      2016-11-13 12:24:43,536 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: PluginService
      2016-11-13 12:24:43,733 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: DeviceService
      2016-11-13 12:24:43,861 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: MediaService
      2016-11-13 12:24:43,929 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: EventService
      2016-11-13 12:24:43,958 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: UserStatusService
      2016-11-13 12:24:43,997 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: UtilityMeasurementService
      2016-11-13 12:24:44,022 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: GraphService
      2016-11-13 12:24:44,032 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: PlatformService
      2016-11-13 12:24:44,089 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: TriggerService
      2016-11-13 12:24:44,124 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: AutomationRulesService
      2016-11-13 12:24:44,157 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: SystemService
      2016-11-13 12:24:44,195 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: ScenesService
      2016-11-13 12:24:44,226 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: DayPartService
      2016-11-13 12:24:44,272 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: MacroService
      2016-11-13 12:24:44,305 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: PresenceService
      2016-11-13 12:24:44,349 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done initializing RPC namespace: DevicePluginService
      2016-11-13 12:24:44,353 [main] INFO  org.pidome.server.services.http.rpc.PidomeJSONRPC - Done Initializing RPC
      2016-11-13 12:24:44,360 [main] INFO  org.pidome.server.system.extras.SystemExtras - Initializing system extras
      2016-11-13 12:24:44,361 [main] INFO  org.pidome.server.system.extras.SystemExtras - LED notifications setting: false
      2016-11-13 12:24:44,363 [main] INFO  org.pidome.server.system.extras.DataNotificationLeds - Led notification pins are disabled. If you want to enable this got to http://pidome.org on how to enable this.
      2016-11-13 12:24:44,363 [main] INFO  org.pidome.server.system.extras.SystemExtras - Done initializing extras
      2016-11-13 12:24:44,383 [main] INFO  org.pidome.server.system.network.Network - Autodiscovery of network interface addresses
      2016-11-13 12:24:44,409 [main] INFO  org.pidome.server.system.network.Network - Network interface loaded
      2016-11-13 12:24:44,582 [main] INFO  org.pidome.server.system.network.http.HttpServer - Starting 'HTTPS Management Webservice'
      2016-11-13 12:24:46,434 [main] INFO  org.pidome.server.system.network.http.HttpServer - 'HTTPS Management Webservice' started
      2016-11-13 12:24:46,541 [main] INFO  org.pidome.server.services.accesscontrollers.AccesControllersService - Loading access controller devices wrappers
      2016-11-13 12:24:47,112 [main] INFO  org.pidome.server.system.hardware.Hardware - Hardware discovery started
      2016-11-13 12:24:47,131 [main] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Trying to load 'Server information layer' hardware driver using saved configuration.
      2016-11-13 12:24:47,134 [main] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Using vid 'PiDome' and pid 'ServerDevicePeripheral' for loading Server information layer.
      2016-11-13 12:24:47,170 [main] INFO  org.pidome.server.system.hardware.drivers.Drivers - Loading peripheral software driver for: Server information layer
      2016-11-13 12:24:47,217 [main] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:47,590 [main] ERROR org.pidome.server.system.hardware.devices.Devices - Problem with loaded device info: null
      java.lang.NullPointerException
      	at java.io.StringReader.<init>(StringReader.java:50) ~[?:1.8.0_91]
      	at org.json.simple.parser.JSONParser.parse(JSONParser.java:79) ~[json-simple-1.1.1.jar:?]
      	at org.json.simple.parser.JSONParser.parse(JSONParser.java:75) ~[json-simple-1.1.1.jar:?]
      	at org.pidome.server.system.hardware.devices.Devices.loadSingleDeviceInstance(Devices.java:325) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.devices.Devices.loadDriverDevices(Devices.java:224) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.devices.Devices.handleDriverEvent(Devices.java:1752) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.drivers.Drivers._fireDriverEvent(Drivers.java:322) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.drivers.Drivers.setPheripheralSoftwareDriver(Drivers.java:132) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.drivers.Drivers.handlePeripheralEvent(Drivers.java:252) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.Peripherals._firePeripheralEvent(Peripherals.java:513) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.Peripherals.startPeripheralInitialization(Peripherals.java:348) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.Peripherals.finalizeDriverInit(Peripherals.java:207) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.Peripherals.loadDriverByVidPid(Peripherals.java:163) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.Peripherals.loadPeripheralDriver(Peripherals.java:111) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.Peripherals.hardwareChange(Peripherals.java:459) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.Hardware._fireHardwareEvent(Hardware.java:274) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.Hardware.deviceMutation(Hardware.java:236) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.server.ServerDevices._fireDeviceEvent(ServerDevices.java:57) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.server.ServerDevices.start(ServerDevices.java:63) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.Hardware.discoveryDoneHandler(Hardware.java:280) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.HardwareRoot._fireDiscoveryDoneEvent(HardwareRoot.java:85) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.peripherals.server.ServerDevices.discover(ServerDevices.java:46) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.Hardware.discover(Hardware.java:140) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.system.hardware.Hardware.start(Hardware.java:110) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.services.hardware.DeviceService.start(DeviceService.java:925) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.services.ServiceController.startAllServers(ServiceController.java:172) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      	at org.pidome.server.PiDomeServerBoot.main(PiDomeServerBoot.java:123) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      2016-11-13 12:24:47,619 [main] ERROR org.pidome.server.system.hardware.devices.Devices - Device 'org.pidome.driver.device.pidomeServerDevice', not found in packages or instantiation error: Incorrect device specs loaded: null
      2016-11-13 12:24:47,620 [main] INFO  org.pidome.server.system.hardware.drivers.Drivers - Driver NativeServerDriver on Server information layer on port {Internally used device map} is ready for use
      2016-11-13 12:24:47,709 [USB-discovery] INFO  org.pidome.server.system.hardware.Hardware - Started peripherals discovery on USB
      2016-11-13 12:24:47,710 [Serial-discovery] INFO  org.pidome.server.system.hardware.Hardware - Started peripherals discovery on Serial GPIO
      2016-11-13 12:24:47,720 [I2C-discovery] INFO  org.pidome.server.system.hardware.Hardware - Started peripherals discovery on I2C
      2016-11-13 12:24:47,722 [main] INFO  org.pidome.server.system.hardware.peripherals.usb.USBDevices - USB listener started
      2016-11-13 12:24:47,741 [main] INFO  org.pidome.server.system.userstatus.UserStatusService - Set user status to Awake at 13-11-2016 11:24
      2016-11-13 12:24:47,742 [I2C-discovery] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Trying to load 'Raspberry GPIO I2C' hardware driver using saved configuration.
      2016-11-13 12:24:47,743 [I2C-discovery] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Using vid 'PiDome' and pid 'GPIOI2C' for loading Raspberry GPIO I2C.
      2016-11-13 12:24:47,748 [User-defined-serials-discovery] INFO  org.pidome.server.system.hardware.Hardware - Started user defined serial devices discovery
      2016-11-13 12:24:47,809 [main] INFO  org.pidome.server.system.presence.PresenceService - Set presence to Home at 13-11-2016 11:24
      2016-11-13 12:24:47,850 [main] INFO  org.pidome.server.services.clients.socketservice.SocketService - Client display terminal server has started
      2016-11-13 12:24:47,871 [Serial-discovery] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Trying to load 'Raspberry Pi GPIO Serial' hardware driver using saved configuration.
      2016-11-13 12:24:47,873 [Serial-discovery] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Using vid 'PiDome' and pid 'GPIOSerial' for loading Raspberry Pi GPIO Serial.
      2016-11-13 12:24:47,888 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Data modifiers plugin service
      2016-11-13 12:24:47,889 [I2C-discovery] ERROR err - Uncaught exception by Thread[I2C-discovery,5,main]:
      2016-11-13 12:24:47,897 [I2C-discovery] ERROR err - java.lang.NumberFormatException: For input string: "a02082"
      2016-11-13 12:24:47,905 [I2C-discovery] ERROR err - 	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
      2016-11-13 12:24:47,906 [I2C-discovery] ERROR err - 	at java.lang.Integer.parseInt(Integer.java:580)
      2016-11-13 12:24:47,907 [I2C-discovery] ERROR err - 	at java.lang.Integer.parseInt(Integer.java:615)
      2016-11-13 12:24:47,909 [I2C-discovery] ERROR err - 	at org.pidome.driver.peripherals.pidomeNativeI2CBus.PidomeNativeI2CBus.initDriver(PidomeNativeI2CBus.java:47)
      2016-11-13 12:24:47,915 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.PeripheralController.initHardwareDriver(PeripheralController.java:231)
      2016-11-13 12:24:47,924 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.PeripheralController.startPeripheralInitialization(PeripheralController.java:194)
      2016-11-13 12:24:47,926 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.Peripherals.startPeripheralInitialization(Peripherals.java:343)
      2016-11-13 12:24:47,919 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Media plugin service
      2016-11-13 12:24:47,928 [Serial-discovery] INFO  org.pidome.server.system.hardware.Hardware - Done peripherals discovery on Serial GPIO
      2016-11-13 12:24:47,928 [User-defined-serials-discovery] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Trying to load 'MySensors_Serial_Port' hardware driver using saved configuration.
      2016-11-13 12:24:47,929 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.Peripherals.finalizeDriverInit(Peripherals.java:207)
      2016-11-13 12:24:47,931 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.Peripherals.loadDriverByVidPid(Peripherals.java:163)
      2016-11-13 12:24:47,932 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.Peripherals.loadPeripheralDriver(Peripherals.java:111)
      2016-11-13 12:24:47,933 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.Peripherals.hardwareChange(Peripherals.java:459)
      2016-11-13 12:24:47,934 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.Hardware._fireHardwareEvent(Hardware.java:274)
      2016-11-13 12:24:47,935 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.Hardware.deviceMutation(Hardware.java:236)
      2016-11-13 12:24:47,936 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.i2c.I2CDevices._fireDeviceEvent(I2CDevices.java:57)
      2016-11-13 12:24:47,937 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.i2c.I2CDevices.start(I2CDevices.java:63)
      2016-11-13 12:24:47,938 [User-defined-serials-discovery] INFO  org.pidome.driver.peripherals.pidomeNativeUSBSerial.PidomeNativeUSBSerial - Initializing hardware driver: PiDome User custom serial device
      2016-11-13 12:24:47,939 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.Hardware.discoveryDoneHandler(Hardware.java:280)
      2016-11-13 12:24:47,961 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.HardwareRoot._fireDiscoveryDoneEvent(HardwareRoot.java:85)
      2016-11-13 12:24:47,962 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.peripherals.i2c.I2CDevices.discover(I2CDevices.java:46)
      2016-11-13 12:24:47,963 [I2C-discovery] ERROR err - 	at org.pidome.server.system.hardware.Hardware$3.run(Hardware.java:167)
      2016-11-13 12:24:47,973 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Utility usage plugin service
      2016-11-13 12:24:48,007 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Messenger plugin service
      2016-11-13 12:24:48,045 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Remotes plugin service
      2016-11-13 12:24:48,125 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Devices plugin service
      2016-11-13 12:24:48,143 [User-defined-serials-discovery] INFO  org.pidome.driver.peripherals.pidomeNativeUSBSerial.PidomeNativeUSBSerial - Serial running in noOp mode (Connection handled by peripheral software driver instead of peripheral hardware driver) on port '/dev/ttyMySensorsGateway': false
      2016-11-13 12:24:48,145 [User-defined-serials-discovery] INFO  org.pidome.driver.peripherals.pidomeNativeUSBSerial.PidomeNativeUSBSerial - Starting hardware driver: PiDome User custom serial device
      2016-11-13 12:24:48,149 [main] INFO  org.pidome.server.services.plugins.PluginService - Starting plugin service: Weather plugins service
      2016-11-13 12:24:48,162 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.services.plugins.PluginService - Starting 'MQTT Server hook' (PiDome MQTT Broker) with the 'Devices plugin service' plugin service
      2016-11-13 12:24:48,204 [User-defined-serials-discovery] INFO  org.pidome.server.system.hardware.drivers.Drivers - Loading peripheral software driver for: MySensors_Serial_Port
      2016-11-13 12:24:48,223 [PluginService::Start:Weather plugins service] INFO  org.pidome.server.services.plugins.PluginService - Starting 'PiDome Buienradar' (PiDome Buienradar) with the 'Weather plugins service' plugin service
      2016-11-13 12:24:48,394 [User-defined-serials-discovery] INFO  org.pidome.server.system.hardware.drivers.Drivers - Driver NativeMySensorsDriver14 on MySensors_Serial_Port on port /dev/ttyMySensorsGateway is ready for use
      2016-11-13 12:24:48,396 [User-defined-serials-discovery] INFO  org.pidome.server.system.hardware.Hardware - Done user defined serial devices discovery
      2016-11-13 12:24:48,414 [main] INFO  org.pidome.server.services.network.BroadcastService - Broadcast message: '{"SRV":"192.168.1.48","UP":8080,"DP":11000,"UA":"SRV","SSL":true,"DA":"SRV"}'
      2016-11-13 12:24:48,417 [SERVICE:BroadcastServer] INFO  org.pidome.server.services.network.BroadcastService - Started, sending every 7.5 seconds
      2016-11-13 12:24:48,706 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Trying to load 'Emulator for: PiDome MQTT Broker' hardware driver using saved configuration.
      2016-11-13 12:24:48,707 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.peripherals.Peripherals - Using vid 'PiDome' and pid 'HwPluginEmu' for loading Emulator for: PiDome MQTT Broker.
      2016-11-13 12:24:48,730 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.drivers.Drivers - Loading peripheral software driver for: Emulator for: PiDome MQTT Broker
      2016-11-13 12:24:48,789 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.drivers.Drivers - Is emulator plugin, setting plugin links: MQTT Server hook
      2016-11-13 12:24:48,790 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.drivers.Drivers - Is emulator plugin, setting device instance link
      2016-11-13 12:24:48,794 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.drivers.Drivers - Assigning the next installed devices to emulator plugin 'MQTT Server hook': {}
      2016-11-13 12:24:48,797 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.system.hardware.drivers.Drivers - Driver PidomeMQTTBrokerDriver on Emulator for: PiDome MQTT Broker on port 71eb159d-9539-49fb-82be-3a74ac94dc0b is ready for use
      2016-11-13 12:24:48,896 [PluginService::Start:Devices plugin service] INFO  io.moquette.server.Server - Persistent store file:
      2016-11-13 12:24:48,899 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,097 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,142 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,189 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,208 [DisplayClientSocketSSL] ERROR org.pidome.server.services.clients.socketservice.SocketService - Message server could not be started
      java.net.BindException: Address already in use
      	at java.net.PlainSocketImpl.socketBind(Native Method) ~[?:1.8.0_91]
      	at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387) ~[?:1.8.0_91]
      	at java.net.ServerSocket.bind(ServerSocket.java:375) ~[?:1.8.0_91]
      	at java.net.ServerSocket.<init>(ServerSocket.java:237) ~[?:1.8.0_91]
      	at javax.net.ssl.SSLServerSocket.<init>(SSLServerSocket.java:181) ~[?:1.8.0_91]
      	at sun.security.ssl.SSLServerSocketImpl.<init>(SSLServerSocketImpl.java:140) ~[?:1.8.0_91]
      	at sun.security.ssl.SSLServerSocketFactoryImpl.createServerSocket(SSLServerSocketFactoryImpl.java:95) ~[?:1.8.0_91]
      	at org.pidome.server.services.clients.socketservice.SocketService$1.run(SocketService.java:106) [pidome-server.jar:0.1-SNAPSHOT-2016-09-22.698]
      2016-11-13 12:24:49,239 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,271 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,339 [USB-discovery] INFO  org.pidome.server.system.hardware.peripherals.usb.USBDevices - USB listener started
      2016-11-13 12:24:49,340 [USB-discovery] INFO  org.pidome.server.system.hardware.Hardware - Done peripherals discovery on USB
      2016-11-13 12:24:49,352 [Thread-18] ERROR org.pidome.server.system.hardware.devices.Devices - Device sql error: no such column: 'modifiers'
      2016-11-13 12:24:49,355 [Rasp USB Monitor] INFO  org.pidome.server.system.hardware.peripherals.usb.linux.RaspUsb - Usb listener started
      2016-11-13 12:24:49,464 [Thread-18] INFO  org.pidome.server.services.automations.AutomationRules - Loaded rule: CPU usage
      2016-11-13 12:24:49,930 [PluginService::Start:Devices plugin service] INFO  io.moquette.spi.impl.SimpleMessaging - Starting without ACL definition
      2016-11-13 12:24:49,981 [PluginService::Start:Devices plugin service] INFO  io.moquette.server.netty.NettyAcceptor - Server binded host: 192.168.1.48, port: 1883
      2016-11-13 12:24:49,991 [PluginService::Start:Devices plugin service] ERROR org.pidome.plugins.mqtt.pidomeMQTTBroker.PluginBrokerRunner - Could not start MQTT Service using port 1883: Address already in use
      	at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_91]
      	at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_91]
      	at sun.nio.ch.Net.bind(Net.java:425) ~[?:1.8.0_91]
      	at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:1.8.0_91]
      	at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74) ~[?:1.8.0_91]
      	at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:125) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:543) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1254) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:488) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:473) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:965) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:243) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:360) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:339) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:374) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:742) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:145) ~[netty-all-4.1.0.Final.jar:4.1.0.Final]
      	at java.lang.Thread.run(Thread.java:745) ~[?:1.8.0_91]
      2016-11-13 12:24:49,997 [PluginService::Start:Devices plugin service] INFO  org.pidome.server.services.plugins.PluginService - Started plugin: MQTT Server hook
      2016-11-13 12:24:50,313 [PluginService::Start:Weather plugins service] INFO  org.pidome.server.services.plugins.PluginService - Started plugin: PiDome Buienradar
      2016-11-13 12:25:00,582 [TriggerTimeRun::11:25] INFO  org.pidome.server.services.triggerservice.TriggerEvent - Executing trigger actions for trigger: Set Morning
      2016-11-13 12:25:00,589 [TriggerTimeRun::11:25] INFO  org.pidome.server.system.dayparts.DayPartsService - Set daypart to Morning at 13-11-2016 11:25
      • E
        E
        esawyja
        I guess PiDome is dead? I see no more activity on PiDome?
          Maybe you get more luck by posting on the PIDome forum?
          http://forum.pidome.org/
          E 1 Reply Last reply
            E
            E
            esawyja
            @hek Thanks will do
