  3. AC dimmer
AC dimmer
7 Posts 4 Posters 4.5k Views 6 Watching
  • v1ckV
    v1ckV
    v1ck
    Hello.
    Im looking for as simple AC dimmer as possible. Is this going to work ?:
    AQH is non-zerro cross and can handle up to 1.2A
    • dbemowskD
      dbemowskD
      Correct me if I'm wrong, but the AQH3223 appears to be a solid state relay chip. How would you use that for dimming? I would think you would need a triac circuit.
      • v1ckV
        v1ckV
        v1ck
        Its actually an Optocoupler.
        dbemowskD 1 Reply Last reply
        • v1ckV v1ck
          dbemowskD
          dbemowskD
          @v1ck Actually it IS NOT an optocoupler. It is in fact an SSR. It IS optically coupled providing galvanic isolation, but it is not an optocoupler. Here is the datasheet. I am not sure if sending a pulse width modulated signal from the arduino would actually dim the output or not with this chip. One other thing. From the looks of the device, it would only be for use with resistive loads, so you couldn't switch anything inductive like a motor.
          • S
            Simple
            hello can i use this module for dimmer lights
            http://www.semesin.com/project/wp-content/uploads/2018/05/Modul-dimmer-lampu-ac-300x274.png
            • S Simple
              dbemowskD
              dbemowskD
              @simple Do you have a link to more information about this part?
              • G
                G
                gianotto
                This is the AC light dimmer on the picture.
                I wonder how to use interrupts to detect cross-zero voltage and manage radio communication.
