  3. Mysensors 2.0 + Relay, DHT, and PIR - No Relay
6 Posts 4 Posters 3.2k Views 3 Watching
  • rhuehnR
    rhuehnR
    rhuehn
    Hello folks:
    I'm trying to put together a powered multi sensor using mysensors 2, that will have a DHT, PIR, and a relay to act as a quick trigger for the garage. ( momentary push ), but I can't seem to get the relay to trigger with the following sketch:
    DHT-Motion, MySensors 2.0.0, motion sensor pin 3, DHT pin 7
    // Enable debug prints
    #define MY_NODE_ID 50         // My Node ID variable
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 7
    #define SENSOR_TEMP_OFFSET -1
    #define CHILD_ID_MO 3
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define CHILD_ID_OPENER 0
    #define CHILD_ID_STATUS 1
    #define TOGGLE_INTERVAL 350  //Tells how many milliseconds the relay will be held closed
    #define CLOSED 0
    #define OPEN 1
    DHT dht;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    MyMessage msgMot(CHILD_ID_MO, V_TRIPPED);
    MyMessage msgOpener(CHILD_ID_OPENER, V_STATUS);
    MyMessage msgStatus(CHILD_ID_STATUS, V_TEXT);
      sendSketchInfo("DHT-Motion_Relay", "1.1");
      present(CHILD_ID_MO, S_MOTION);
      wait(30);
      present(CHILD_ID_HUM, S_HUM);
      wait(30);
      wait(30);
      sendHeartbeat();
      wait(30);
      present(CHILD_ID_OPENER, S_BINARY);
      wait(30);
      present(CHILD_ID_STATUS, S_INFO);
      wait(30);
      pinMode(RELAY_1, OUTPUT);
      digitalWrite(RELAY_1, loadState(RELAY_1)?RELAY_OFF:RELAY_ON);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        wait(50);
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        wait(50);
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
       // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      wait(300);
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, UPDATE_INTERVAL);
      if (message.type==V_LIGHT) {
         // Change relay state
         digitalWrite( RELAY_1, RELAY_ON );
        //Keep the relay on for the amount of time defined by TOGGLE_INTERVAL
        delay( TOGGLE_INTERVAL );
        digitalWrite( RELAY_1, RELAY_OFF );
        //Added this to tell the controller that we shut off the relay
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Can anyone help with where I have gone wrong? Board, NRF, etc all work with the default relay sketch, but when I am combining, I am not having any luck with the relay, everything else appears fine based on serial output:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=50)
    TSM:FPAR
    TSP:MSG:SEND 50-50-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-50 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=50)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-50 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    !TSP:MSG:SEND 50-50-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=ok:DHT-Motion_Relay
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
    TSP:MSG:SEND 50-50-0-0 s=3,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 50-50-0-0 s=10,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 50-50-0-0 s=11,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=ok:2197
    TSP:MSG:SEND 50-50-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:READ 0-0-50 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    TSP:MSG:SEND 50-50-0-0 s=1,c=0,t=36,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 50-50-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-50 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=50, parent=0, distance=1, registration=1
    TSP:MSG:SEND 50-50-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:20.0
    T: 20.00
    TSP:MSG:SEND 50-50-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:23.0
    H: 23.00
    TSP:MSG:SEND 50-50-0-0 s=3,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=ok:0
    • rhuehnR rhuehn
      Hello folks:
      //#define MY_RS485
      #include <DHT.h>
      #define CLOSED 0
      #define OPEN 1
      DHT dht;
      float lastTemp;
      float lastHum;
      bool metric = true;
        wait(30);
        wait(30);
        wait(30);
        sendHeartbeat();
        wait(30);
        wait(30);
        wait(30);
          if (!metric) {
          nNoUpdatesTemp = 0;
          wait(50);
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          wait(50);
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
        wait(300);
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:UPL
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      Node registration=1
      T: 20.00
      H: 23.00
      @rhuehn - what does it look like when you send the trigger command? Do you get anything in the node log?
      • NuubiN
        NuubiN
        Nuubi
        Isn't it so, that this code block makes the node unresponsive for UPDATE_INTERVAL 60 s? The only exception would be the digital input 3 (PIR pin).
          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, UPDATE_INTERVAL); nsert Code Here
        • rhuehnR
          rhuehnR
          rhuehn
          Hello @Nuubi Yes I believe that is exactly why the Relay goes unresponsive. If I remove that sleep block, the PIR floods the gateway, and I am not sure how to get around it? Is there any possible recommendations you could make to the code so that the DHT, PIR AND Relay all work without the PIR flooding the gateway?
          Thanks very much!
          • rhuehnR rhuehn
            Thanks very much!
            @rhuehn - you could with a if statement only send if the value is changed.
            • dbemowskD
              dbemowskD
              I did a similar project that is working well. Mine was powered all the time, so I didn't use the sleep code. The main reason I didn't was so that I could manually control the relay/light when there was no motion detected. It also allowed me to get continuous readings from the LDR so I could use that light level for other things if I ever wanted to.
              Here is a link to my project. https://forum.mysensors.org/topic/5243/driveway-motion-light . Maybe you can get some ideas from my code.
