  3. Specifying different "myconfig.h"
3 Posts 2 Posters 1.6k Views 1 Watching
  • greglG
    greglG
    gregl
    If i want to run a second 1.4 gateway for dev/testing purposes, what do i need to do to keep them separate?
    To do this i understand i just need to set different values in myconfig.h.
    This could be a tricky when compiling/updating "prod" sensors or test sensors . You need to shutdown IDE's, modify of copy file and relaunch the IDE.
    So i was wondering if it is possible to set in the sketch which MyConfig.h file is loaded?
    Might it be as simple as specifying it in
    #include <MyConfig_DEV.h>
    Cheers,
    Greg
      No I don't think so. The Arduino IDE build system is very limited. I would have wanted to #define stuff before includes which should have make thing much easier to configure. But it is not possible from what I have googled.
      I keep separate sketch paths when developing and just go to the IDEs "Preferences" and switch where it should look for sketches.
      So I have (on mac):
      Documents/ArduinoDev/libraries
      and
      Documents/Arduino/libraries
      • greglG
        greglG
        gregl
        mmm.. Ok - thanks Hek.
        I was doing similar by having multiple copies of the Arduino IDE - one with 1.3 libs and another with 1.4 but ive recently started using AtmelStudio with VisualMicro plugin. I wonder if i can change within there without restarting the IDE completely...
