  3. RS485 bus voltage ?? Can you mix nodes using 3/3v and 5v transceivers ?
2 Posts 2 Posters 2.9k Views 5 Watching
  • RedguyR
    RedguyR
    Redguy
    I am working on setting up a my sensors network consisting of both wired (using RS485) and wireless (NRF or ESP) nodes..
    I just added a sc16is752 to my RPI3 for some much needed additional serial interfaces and am now looking at using those interfaces for RS485. 1 for the RS485 my sensors bus and the other as a modbus interace to mu power monitoring device.
    I grabbed a max485, realized it's a 5v device.. and then it hit me..
    I can either use a level converter or look for a 3.3v rs485 transceiver.. no issue there, that's only local.. But the rs485 bus is meant for many devices..
    What about the rs485 bus voltage ? it has no pull-ups, only the 120ohm terminators on both sides.. but what voltage does it use ?
    Can you run a rs485 bus between devices equiped with rs485 transceiver using a mixed supply voltage of 3.3v and 5v ?
    • RedguyR Redguy
      @Redguy from http://m.electronicdesign.com/what-s-difference-between/what-s-difference-between-rs-232-and-rs-485-serial-interfaces: "A logic 1 is a level greater than –200 mV, and a logic 0 is a level greater than +200 mV. Typical line voltage levels from the line drivers are a minimum of ±1.5 V to a maximum of about ±6 V. "
      So you should be able to mix them as much as you like.
