  3. RPI + ESP8266
RPI + ESP8266
4 Posts 2 Posters 1.6k Views 2 Watching
  • CRFC
    CRFC
    CRF
    wrote on last edited by CRF
    Hi All!
    I am totally new to MySensors. I already have a home IOT smart house network with my own HW and SW, but would like to migrate to a better supported/organized scheme.
    To begin with I have just a few questions.
    Can MySensors work ONLY with RPI(as a controller) and ESP8266 (as sensors)?
    I would run Domoticz on RPI... is there something else that sould run on RPI? What would the gateway be in this case?
    I can not find any example code for ESP8266 sensors. Can you point me to the right direction where I can find some.
    Thank you very much!
    CRF
    • CRFC CRF
      Hi All!
      CRF
      @CRF yes you could run a home automation system with a raspberry pi as controller and esp8266 gateways with locally attached sensors, assuming you have reliable wifi coverage everywhere you want to put sensors.
      I use the Domoticz raspberry pi image which includes some other nice tools such as Node Red.
      Each esp8266 could then be a gateway. All gateways must be added to Domoticz.
      There are no esp8266 sensor examples. But there are no Arduino Uno examples either. Most sensor examples can be run on any mcu.
      • CRFC
        CRFC
        CRF
        Thank you for the explanation. That is good news.
        Where did you find the whole Domoticz image for RPI? I can only see the installation package on Domoticz page.
        • CRFC CRF
          @CRF interesting. Domoticz seems to have removed support for the image. This old page had information https://www.domoticz.com/wiki/index.php?title=Domoticz_RaspberryPi_SD_Image&oldid=216&diff=prev
          I guess installing by running
          sudo curl -L install.domoticz.com | bash
          is the way to go nowadays.
