  3. How to build raspberry gw 2.0.0
12 Posts 4 Posters 3.2k Views 3 Watching
  • H Offline
    H Offline
    Huczas
    wrote on last edited by Huczas
    Hi, just want to create using https://www.mysensors.org/build/raspberry - gateway on raspberry pi in version 2.0.0. I've done git clone then git checkout 2.0.0 - but there isn't .configure file and I don't know how to make it to work for me.
    Can anyone help me?
    Second way is to leave gw in newest version(2.1.1) and upgrade code in my node but I don't know how becouse my node is for version 2.0gw. I can post that code if anyone know how to upgrade it.
    • H Huczas
      Can anyone help me?
      @Huczas the raspberry pi gateway was developed after 2.0 was released, that's why it doesn't exist in 2.0.
      You should not need to change anything in your sketches when upgrading from 2.0 to 2.1.1. Just upgrade the MySensors library and re-upload your sketches. The only exception I am aware of is that sketches using getConfig need to be changed to use getControllerConfig instead but that is easy to fix and is only needed if you get the error described in these threads:
      https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/2
      https://forum.mysensors.org/topic/5865/could-use-a-bid-help-to-get-started/15
      https://forum.mysensors.org/topic/4807/atmospheric-pressure-sensor/12
      H 1 Reply Last reply
        H Offline
        H Offline
        Huczas
        @mfalkvidd libraries in Arduino IDE updatet to 2.1.1 sketch uploaded - no errors.
        in RPi3, latest version of gateway installed and when all is up I get this:
        pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: !TSM:INIT:TSP FAIL
        mysgw: TSM:FAIL:CNT=1
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:FAIL:RE-INIT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:CNT=2
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:CNT=3
        mysgw: TSM:FAIL:PDT
        ^Cmysgw: Received SIGINT
        Do you have any guess on it? For me it looks like nothing is transmitting from node.
        My node code: http://pastebin.com/LCjF5Cm1 maybe something is wrong with that code.
        • H Huczas
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:PDT
          @Huczas the code used for the node should not affect the gateway's ability to initialize the radio. In case you haven't seen it, information on the log messages is available at https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details
          I don't know what could be wrong though. Have no experience with the raspberry pi gateway.
            H Offline
            H Offline
            Huczas
            @mfalkvidd another thing, after changing version of gateway from 1.4 to 2.1.1:
            0_1486205151792_upload-3da97f77-7b96-4c77-a732-c2f831650525
            • P Offline
              P Offline
              pansen
              What's your ./configure command? Can you post a picture/photo of your wiring?
              Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
              • P pansen
                H Offline
                H Offline
                Huczas
                @pansen
                ./configure --my-gateway=serial --my-serial-port=/dev/ttyAMA0 --my-serial-baudrate=115200 --my-transport=nrf24 --my-rf24-irq-pin=15
                Wiring was ok, and was working fine witch gw1.4 so - there is all ok, soldered well.
                0_1486372015325_upload-ed13d19f-5a9c-4daa-853b-08b80fe745d4
                Yesterday I connected gw2.1.1 on arduino uno - blue usb wire - it is working now, nodes are visible in my system, data is comming. If there well be no luck i will live in that way. It's just another thing behinde my speaker.
                • martinhjelmareM Offline
                  martinhjelmare
                  I think you need to configure a virtual serial port.
                  ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                  If the serial gateway doesn't work for you, you can try and configure the ethernet gateway. Is there a reason you want to use the serial gateway?
                    H Offline
                    H Offline
                    Huczas
                    @martinhjelmare don't know difference. Just have node using nrf24 and any configuration that will work would be ok for me.
                    • P Offline
                      P Offline
                      pansen
                      wrote on last edited by pansen
                      For ethernet gateway listening on 0.0.0.0 (i.e. on all interfaces) and port 5003 you can try:
                      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=13 --my-rf24-cs-pin=14
                      Check for
                      • Check for existance of spidev0.0 and replace if necessary
                      • Also check the pin numbers, CE has to be physical pin 8, CN has to be physical pin 10.
                      Also you need the latest dev version from git as far as I know.
                      For more info check my comment here: https://www.mysensors.org/build/orange
                      @martinhjelmare: whats the difference between the virtual one and the "real" one?
                        martinhjelmare
                        Since everything is connected to the RPi and I guess you also run the controller on the same RPi, you don't need any extra hardware, it's just a matter of how you configure the software to interface.
                        If you configure a serial gateway, you configure your controller to connect to the virtual serial port. If you configure an ethernet gateway, you configure your controller to connect to a tcp socket on the correct port on localhost. Of course it depends on the controller what connection options are available.
                        • P pansen
                          Check for
                          martinhjelmare
                          @pansen
                          This is more a guess, but I think the real one (GPIO) is only for the interface between radio and serial gateway program. The virtual is for the interface between serial gateway program and controller. Serial interfaces are exclusive to one program at a time. Someone should verify what I just said though.
