  3. Soldering RFM to Sensebender
3 Posts 2 Posters 1.5k Views 1 Watching
  • C
    C
    Chester
    wrote on last edited by Chester
    Hi guys!
    So my shiny little Sensebender gateway arrived today in the post, man am I excited!
    Just had a question, I need to solder the RFM69 to the underside of the module, but I have never done that kind of overlay solder before, and just wanted to check. do I need any insulation between the RFM and the sensebender? Or does the green mask provide for the electrical isolation? So, do I just lay the RFM onto the sensebender and solder the pads?
    And I'm guessing I still need to have the antenna wire soldered on to the RFM, even though there is a corresponding pad on the sensebender underneath the antenna pad on the RFM.
    • tbowmoT
      tbowmoT
      tbowmo
      @Chester
      You can solder the RFM69 module directly on the Sensebender. There is two position pinheader for the antenna (the antenna pad is connected to this).
      • C
        C
        Chester
        Many thanks @tbowmo I'll sit down tonight and fire up the iron, looking forward to freeing up another pro-mini back into the pool for more sensors!! :)
