NRF24l01 1.27mm Arduino Pro Mini Adapter board
Not really a project, not my own design but I think this adapter board can be of use to many. The board was published by Kauz on www.thinkering.de.
I breadboard a lot of pro-mini circuits to be MySensor'ized at a later stage and have been using the jModule frequently upto now, The jModule includes a 3.3V LDO and does the job well. However this adapter has the advantage that it breaks out all the pro-mini pin's in their original spot and keeps most of the form factor (you need to use a 3.3V pro-mini).
A few pictures:
The components
The yellow part is a smd tantalum 4.7uF capacitor. I had the smd nRF24l01 already soldered on the board (takes a little exercise).Soldered with pin headers. The author soldered it "trough-hole" without headers.
You need wires from the board to Vcc and Gnd.Comparison with jModule:
Ready for 4 new MySensors projects :-)
A few pictures:
The components
Thanks for posting this! I am just getting past the breadboard/UNO stage and your timing is perfect. So far I have only used NRF24L01+PA+LNA and I want to build smaller units with NRF24L01+.
Would it be possible for you to post your photo ("the components") with higher resolution? There are so many different NRF modules sold and I cannot see the details of the NRF module this adapter board will fit. Also can you share the source/model for the NRF module?
Thanks again,
Tim
Thanks again,
Tim
@Grubstake Here you go. For the nRF24l01 modules search for "smd nRF24l01". I got them here. @gohan these small modules have given me less problems than the large one's.
I marked the pad's where you connect Vcc (+) and Gnd(-) and on the small pads you can solder the capitor. It's where I used the tantalum one but you can probably fit a small electrolytics one (with wire) also.
