  3. 'MySensors' does not name a type
6 Posts 3 Posters 4.0k Views 2 Watching
  • A
    A
    adrian_kbb73
    hello, i'm new in arduino and in das forum
    and i have this error in code
    i hope they can help me.
    /////////error//////////////
    exit status 1
    A 1 Reply Last reply
    • Sander StolkS
      Sander StolkS
      Sander Stolk
      Maybe post the code so that people can see what is wrong with your code
      • A adrian_kbb73
        exit status 1
        A
        A
        adrian_kbb73
        @adrian_kbb73
        #define MY_RADIO_RFM69
        #define MY_RFM69_FREQUENCY RF69_915MHZ
        #define MY_IS_RFM69HW
        #define MY_RF69_IRQ_PIN 2
        #define MY_RF69_SPI_CS 10
        #include <DHT.h>
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        MySensors gw;/// Here I get the error
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
        gw.begin();
        gw.sendSketchInfo("Humidity", "1.0");
        if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
        if (isnan(humidity)) {
        lastHum = humidity;
        Serial.print("H: ");
        Serial.println(humidity);
        gw.sleep(SLEEP_TIME); //sleep a bit
        • Sander StolkS
          Sander StolkS
          Sander Stolk
          This line is not necessary in MYS 2.0
          • Sander StolkS Sander Stolk
            A
            A
            adrian_kbb73
            @Sander-Stolk
            o thank you, i will prove without that line
            • A adrian_kbb73
              @Sander-Stolk
              @adrian_kbb73 Welcome to the MySensors commu ity!
              Most of this code seems to be for MySensors 1.x. It needs to be converted to work with 2.x. A guide is available at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x/
