  3. Arduino with ethernet shield direct connect to openhab without NFR
3 Posts 3 Posters 2.6k Views 1 Watching
  • M Offline
    M Offline
    MarkV
    Is it possible to control / read sensors connected on a arduino directly through ethernet?
    For example arduino Mega with ethernet shield en different sensors connectod on digital and analog i/o pins.
    And can someone make a example or basic program for this???
    • hekH Offline
      hekH Offline
      wrote on last edited by hek
      No, but nothing stops you from emulating the serial protocol over ethernet (like the gateway communicates). This way you could at least reuse the controller code.
      • D Offline
        daulagari
        Depending on what gateway you use, another solution could be to implement an MQTT client on Arduino, see http://knolleary.net/arduino-client-for-mqtt/
